Turning off Single Document Interface
I need to be able to turn off single document interface such that AutoCAD
will be able to access multiple documents. The only problem is that there
is an app loaded that cannot deal with multiple documents. The SDI variable
is set to 3, and when i try to change it, my VBA dies. Does anyone know of
any way i can get AutoCAD to handle multiple documents without having to
unload the application? Any help would be appreciated...
-Rich
Hi Rich,
If the application your referring to is ALDD, then you can't and more
importantly shouldn't.
Laurie Comerford
CADApps
laurie@cadapps.com.au
"Rich Priddy" wrote in message
news:CF533FBFBEBE90C45637D52EBBB318E8@in.WebX.maYIadrTaRb...
variable
of
> -Rich
Actually, i'm not sure what ALDD is, but i'm very familiar with the
application that is being limited to one document, and i'm aware of the
problems that could arise if i switch it back to multiple documents. I'm
not too concerned about that, and i know how to handle everything once i'm
in multi-document mode. It's getting to that point that's giving me the
problem.
-Rich
"Laurie Comerford" wrote in message
news:A87BAA5849CBCEB79E9B3D1218D9E495@in.WebX.maYIadrTaRb...
> Hi Rich,
> Regards,
> Laurie Comerford
> CADApps
AutoCAD
there
> variable
> of
> > -Rich
Maybe I'm not addressing your question but, This works for me to turn
SDI on and off through VB code. I haven't written much code in VBA but
this may be adapted from VB to VBA.
Dim MMode As Integer
MMode = acaddoc.GetVariable("SDI") 'this turns SDI off
If MMode = 1 Then
acaddoc.SetVariable "SDI", 0
End If
MMode = acaddoc.GetVariable("SDI") 'this turns on the SDI
If MMode = 0 Then
acaddoc.SetVariable "SDI", 1
End If
regards,
jm
news:DA43A1709F6E37432A3E1666DA628301@in.WebX.maYIadrTaRb...
> problem.
> -Rich
> > Hi Rich,
> > Regards,
> > Laurie Comerford
> > CADApps
> AutoCAD
> there
> > variable
know
> > of
to
> > > -Rich
