Turning Big font off?
Hi
I'm using 2007.
I want to amend existing TextStyles so that the 'Use Big Font' switch in
the Texstyle dialog is turned off.
From the Help it says for the .bigfontfile property that 'This property
cannot be set to NULL or an empty string.'
How do I turn it off?
Thanks for any help
Dave F.
i don't believe you can turn it off.
"Dave F." wrote in message
news:5648889@discussion.autodesk.com...
Hi
I'm using 2007.
Thanks for any help
Dave F.
OK, if that's the case, is there a way to prevent the dialog that
requests alternative to bigfonts from popping up every time I open the dwg?
Cheers
Dave F.
> Hi
> I'm using 2007.
> Thanks for any help
> Dave F.
set it to the default font you are using ... that should shut it up.
news:5649188@discussion.autodesk.com...
Cheers
Dave F.
> Hi
> I'm using 2007.
> Thanks for any help
> Dave F.
