Here's my code for importing from a template.
Sub ImportMLeaderStyles()
On Error GoTo Err_Control
'Get/Set MultiLeaderStyles in current dwg
Dim oDict As AcadDictionary
Set oDict = ThisDrawing.Dictionaries.Item("ACAD_MLEADERSTYLE")
Dim cDestMLStyles As New Collection
Dim cSourceMLStyles As New Collection
Dim oMLStyle As AcadMLeaderStyle
Dim oDwg As AxDbDocument
Set oDwg = AcadApplication.GetInterfaceObject("ObjectDBX.AxDbDocument.24")
oDwg.xOpen "N:\Applications\AutoCAD\Map 2023\Template\_Engineering.dwt"
Dim bTS As Boolean 'text style exists
Dim oTS As AcadTextStyle
Dim i As Integer
'Check for text style required by mlstyle.
For Each oTS In ThisDrawing.TextStyles
If oTS.Name = "Simplex1" Then bTS = True
Next
If bTS = False Then
Set oTS = ThisDrawing.TextStyles.Add("Simplex1")
oTS.fontFile = "Simplex1.shx"
ThisDrawing.ActiveTextStyle = oTS
For i = 0 To oDict.Count - 1
Dim oObj As AcadObject
Dim bA As Boolean 'anno style exists
Dim bS As Boolean 'standard style exists
Set oObj = oDict.Item(i)
If oObj.ObjectName = "AcDbMLeaderStyle" Then
Set oMLStyle = oObj
Select Case oMLStyle.Name
Case Is = "GS_Annotative"
cDestMLStyles.Add oMLStyle, oMLStyle.Name
bA = True
Case Is = "GS_Standard"
bS = True
End Select
Next i
If bA = False Then
Set oMLStyle = oDict.AddObject("GS_Annotative", "AcDbMLeaderStyle")
If bS = False Then
Set oMLStyle = oDict.AddObject("GS_Standard", "AcDbMLeaderStyle")
'Get MultiLeaderStyles in source dwg
Set oDict = oDwg.Dictionaries.Item("ACAD_MLEADERSTYLE")
Set oMLStyle = oObj
cSourceMLStyles.Add oMLStyle, oMLStyle.Name
Next i
CopyMLeaderStyle cSourceMLStyles("GS_Annotative"), cDestMLStyles("GS_Annotative")
CopyMLeaderStyle cSourceMLStyles("GS_Standard"), cDestMLStyles("GS_Standard")
Cleanup:
Set oDwg = Nothing
Set oDbx = Nothing
Exit_Here:
Exit Sub
Err_Control:
Select Case Err.Number
'Add your Case selections here
'Case Is = 1000
'Handle error
'Err.Clear
'Resume Exit_Here
Case Else
MsgBox Err.Number & ", " & Err.Description, , "ImportMLeaderStyles"
Err.Clear
Resume Exit_Here
End Select
End Sub
Sub CopyMLeaderStyle(oSource As AcadMLeaderStyle, oDest As AcadMLeaderStyle)
With oSource
oDest.AlignSpace = .AlignSpace
oDest.Annotative = .Annotative
oDest.ArrowSize = .ArrowSize
' oDest.ArrowSymbol = .ArrowSymbol
oDest.BitFlags = .BitFlags
' oDest.Block = .Block
oDest.BlockColor = .BlockColor
oDest.BlockConnectionType = .BlockConnectionType
oDest.BlockRotation = .BlockRotation
oDest.BlockScale = .BlockScale
oDest.BreakSize = .BreakSize
oDest.ContentType = .ContentType
oDest.Description = .Description
oDest.DoglegLength = .DoglegLength
oDest.DrawLeaderOrderType = .DrawLeaderOrderType
oDest.DrawMLeaderOrderType = .DrawMLeaderOrderType
oDest.EnableBlockRotation = .EnableBlockRotation
oDest.EnableBlockScale = .EnableBlockScale
oDest.EnableDogleg = .EnableDogleg
oDest.EnableFrameText = .EnableFrameText
oDest.EnableLanding = .EnableLanding
oDest.FirstSegmentAngleConstraint = .FirstSegmentAngleConstraint
oDest.LandingGap = .LandingGap
oDest.LeaderLineColor = .LeaderLineColor
oDest.LeaderLineType = .LeaderLineType
' oDest.LeaderLineTypeId = .LeaderLineTypeId
oDest.LeaderLineWeight = .LeaderLineWeight
oDest.MaxLeaderSegmentsPoints = .MaxLeaderSegmentsPoints
oDest.Name = .Name
oDest.ScaleFactor = .ScaleFactor
oDest.SecondSegmentAngleConstraint = .SecondSegmentAngleConstraint
oDest.TextAlignmentType = .TextAlignmentType
oDest.TextAngleType = .TextAngleType
oDest.TextColor = .TextColor
oDest.TextHeight = .TextHeight
oDest.TextLeftAttachmentType = .TextLeftAttachmentType
oDest.TextRightAttachmentType = .TextRightAttachmentType
oDest.TextString = .TextString
oDest.TextStyle = .TextStyle
End With
Ed
How to
post your code.
