Trying to change Canonical Media Name
Message 1 of 1
I am trying to change the Canonical Media Name type in my VBA code, but I keep getting overridden with other values (for reason I don't know why) I also tried passing variables through another sub, but this isn't working either. I was wondering if someone has an idea floating around to by pass this. I have tried using
myLayout.Regen acAllViewports
to update my viewports and
myLayout.RefreshPlotDeviceInfo
to also update my code.
I am currently restructuring this code provided by
Option Explicit
Public Sub PlotTest()
    Dim backPlot As Integer
Dim PaperSize As String backPlot = ThisDrawing.GetVariable("BACKGROUNDPLOT") ThisDrawing.SetVariable "BACKGROUNDPLOT", 0 On Error Resume Next PaperSize = "11x17" PlotToPdf ThisDrawing, "D:\Temp\TestDwgPlot1.pdf", ac0degrees PlotToPdf ThisDrawing, "D:\Temp\TestDwgPlot2.pdf", ac90degrees ThisDrawing.SetVariable "BACKGROUNDPLOT", backPlot End Sub Private Sub PlotToPdf(currentDwg As AcadDocument, pdfFile As String, plotRotation As AcPlotRotation, Papersize As String) Dim myLayout As ACADLayout Dim currentPlot As AcadPlot
Set myLayout = currentDwg.ModelSpace.Layout myLayout.StyleSheet = "monochrome.ctb" myLayout.plotRotation = plotRotation myLayout.ConfigName = "DWG To PDF.pc3" myLayout.CanonicalMediaName = PaperSize myLayout.StandardScale = acScaleToFit myLayout.PlotType = acExtents myLayout.CenterPlot = True Set currentPlot = currentDwg.Plot currentPlot.DisplayPlotPreview acFullPreview If currentPlot.PlotToFile(pdfFile) Then MsgBox pdfFile & " generated successfully." End If End Sub
Replies (0)
