TreeView Sorting
TreeView Sorting
TreeView Sorting
I've created a TreeView control on a form. I've got the code to populate it
in the form's Initialize event. After the control is populated I set it's
Sorted property to True...it doesn't sort 😞 What overly documented
crucial piece of info am I missing?
TIA
VBA in A2ki on Win2k
Happy Holidays...
Bobby C. Jones
http://www.acadx.com
Hi Bobby:
I use a treeview that gets values from ADO database objects. I use the SORT
method before i populate the treeview...
Dim rstRecords As New ADODB.Recordset
rstRecords .CursorLocation = adUseClient
rstRecords .Open "qryAccessQuery", cnn, adLockReadOnly
rstRecords .Sort = Name
This sorts the treeview on a column called 'Name'. It may not be perfect
but it works for me. good luck.
Sean
"Bobby C. Jones" wrote in message
news:E393F51CB41B2A9002791D3A8A61DFCD@in.WebX.maYIadrTaRb...
it
> TIA
> Happy Holidays...
> Bobby C. Jones
Thanks Sean, Unfortunately my data is not stored in a database...I have sort
functions and I can pre-sort my data before populating the control, but it
appeared that I could have the control sort for me...
Happy Holidays...
Bobby C. Jones
Bobby
If you are adding nodes with something like
Set nodEntry = TreeView1.Nodes.Add(sColor, tvwChild, sCompLoc, sComponent, "Thaw")
then you can simply add after it
nodEntry.Sorted = True
Works for me
Kent Keller
http://kwikmcad.topcities.com/
news:9E59BB8A82EB372394AA5E1C996000E5@in.WebX.maYIadrTaRb...
> Happy Holidays...
> Bobby C. Jones
That's the winner! Thanks Kent.
Happy Holidays...
Bobby C. Jones
