Tool>Display>Order
Tool>Display>Order
Tool>Display>Order
I would like to write a VBA routine to duplicate the Tool->Display
Order->Bring To Front command.
I would like to build a selection set based on certain filters and then
Bring them to the front 🙂
any idea on how to change an entities display order?
Thank you for your time and have a good day
Ed__Jobe
Display order is controlled by the order in which entities are created. The only permanent way to change it is to recreate the ents to be displayed on top. A common method is to copy the ents at the same location and erase the originals.
Ed
How to post your code.
Hi Mike
did you find a solution? i do this in lsp but have a need to use vba code to do the same thing. - thanks, nancy - nancym@astroshapes.com
correct me if i'm wrong, but... doesn't a call to the draworder command work too.
I use "draworder" & lsp....
(setq ss_wo (ssget "X" '((8 . "wo*"))))
(setq ss_se (ssget "X" '((2 . "se"))))
(command "draworder" "all" "r" ss_se "" "f")
(command "wipeout" "frame" "on")
(command "draworder" ss_wo "" "a" ss_se)
(command "wipeout" "frame" "off")
well... that's the basic idea. I need to do the same thing in vba. my problem is that i'm not real good at the "ssget" part. can anyone help?
Thanks, Nancy nancym@astroshapes.com
