to count number of blocks
Message 1 of 9
How can I count the number of blocks I have in my drawing
Replies (8)
Message 2 of 9
Here's something I've had kicking around for
years.  It's not pretty but it should get you going in the right
direction.
Matt W
"Children are like TV sets. When they start acting
weird, whack them across the head with a big rubber basketball shoe."
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
How
Message 3 of 9
Blocks are resident in either modelspace or paperspace (note that they are blocks too) and can be accessed via the blocks collection of your drawing object. The simplistic answer is:
Sub Countblock()
MsgBox "There are " & ThisDrawing.Blocks.Count & " in this drawnig", vbCritical
End Sub
Message 4 of 9
Simplistic enough to be useless. I'm sure the OP wanted the number of *block
insertions* in the drawing.
R. Robert Bell
wrote in message
news:[email protected]...
Sub Countblock()
vbCritical
End Sub
Message 5 of 9
I understand your sarcasm Robert, it is VERY useless, the cout varible. I have yet to find a reasonable way to get the block inserts in a drawing without somehow writting a sub that iterates the intire block array comparing string id's. major pain!
Message 6 of 9
Hi
Pass this parameters of "INSERT" and "*" like this.
NumberofBlockInsertsinDrawing = SelectObjectsOnLayer (ssObjects, "INSERT",
Public Function SelectObjectsOnLayer(ssObs As AcadSelectionSet, spObjectType
As String, spLayer As String) As Long
On Error Resume Next
Dim FilterType(0 To 1) As Integer
Dim FilterData(0 To 1) As Variant
Dim sNumber As String
FilterType(0) = 0: FilterData(0) = spObjectType
FilterType(1) = 8: FilterData(1) = spLayer
' The line below will create an error if the SSET doesn't exist
' or delete it if it does exist.
' The ON Error will allow the program to continue and create the set
ThisDrawing.SelectionSets.Item("SSET").Delete
Set ssObs = ThisDrawing.SelectionSets.Add("SSET")
ssObs.Select acSelectionSetAll, , , FilterType, FilterData
SelectObjectsOnLayer = ssObs.Count
Exit Function
SOLErrorHandler:
Err.Clear
SelectObjectsOnLayer = 0
End Function ' SelectObjectsOnLayer()
Laurie Comerford
CADApps
www.cadapps.com.au
wrote in message news:[email protected]...
Message 7 of 9
fxcastil
see attached file
Message 8 of 9
Is sarcasm required in a public space where we are simply trying to help out?
There is no way to get inserted blocks without iterating through model or paper. It's very easy. Good luck.
Message 9 of 9
>paper
What about the posts above you that mention using filters? You can also add
a specific filter for just paper or modelspace 'Block References'
gl - Paul
wrote in message
out?
