** That command may not be invoked transparently **
sometimes when trying to execute an activex command from visual basic 6.0 to
autocad 2000 i get this message :
and executions halts.
does anybody know what does this mean and how to get around it?
It sounds like you are trying to call an AutoCAD command while another is
running.
Andy Cottrell
Applications Engineer
ExcelTech Computer Services
E-Mail: acottrell@exceltech.net
Dimitris Papadimitriou wrote in message
news:7vlbiu$jpr15@adesknews2.autodesk.com...
to
I had the same problem.
Couldn't really figure out why.
Probably has something to do with the state AutoCAD thinks it's in.
In my VBA code I send a couple of escapes to command line before trying
to interface with the drawing editor.
I haven't had the problem since.
Mark
>6.0 to autocad 2000 i get this message :
I have a Microsoft Intellimouse Explorer with the wheel (middle button)...
My code gives me this error message after double clicking the wheel to
execute a "'_.zoom _e"
How can I make sure A2002 is ready for me to interact with my code?
Rodney
Hello all,
I have found that I sometimes get an error when I try to interface with the
drawing editor from VBA. This error only happens following a middle-button
double-click zoom-extents.
For some reason zooming to extents using this method leaves the document in
a state that doesn't want to respond to VB. It's especially aggravating
because the error shows up at the AutoCAD command prompt and not in a VB
error dialog. It says "** That command may not be invoked transparently **".
I've been able to trap it by examining the "LASTPROMPT" variable.
I have been able to to work around this problem by putting [
ThisDrawing.SendCommand "Zoom 1x " ] in front of my Select call. This
happens even when the Select type isn't a call to SelectOnScreen.
My work-around is a bad hack. I've found it doesn't work in all cases.
Any alternatives?
This is a known problem (and one I'm way too familiar with).
The only workaround I've found, is like the one you use
except I use SendCommand("redraw ").
"Mark Johnston" wrote in message
news:E8F37CDD1B99A80EE3197EEC815C23F5@in.WebX.maYIadrTaRb...
> Hello all,
the
in
> Any alternatives?
