AcadBlock vs. AcadBlockReference
Message 1 of 9
I am trying to list the attributes of a Block.
I have code like this:
dim strBlockName as String
strBlockName = "MyBlock"
Now I want to get a AcadBlockRefernce to the block named strBlockName so
that i can use AcadBlockReference.GetAttributes
I can use this to get a Block object
Dim entBlock as AcadBlock
Set entblock = ThisDrawing.Blocks.Item(strBlockName)
But I do not know how to turn this into an AcadBlockReference
Any help is appreciated,
Bob Harden
bob_harden@removespamharden-assoc.com (delete removespam to send message)
Replies (8)
Message 2 of 9
Bob Harden wrote in message <7vlbfs$jpc19@adesknews2.autodesk.com>...
Hello Bob,
You're approaching this from the wrong side. What you are
after is the attributes associated with a block INSTANCE,
not the block DEFINITION, right?
Okay, so first you need to get the block instance (or reference).
You could do this by getting a selection set, or by having the
user pick an instance. If using a selection set, you could let
the user manually select entities, or automatically build the
set.
Does this help?
rdh.
Message 3 of 9
Richard D. Howard [Autodesk GIS] wrote in
message news:7vlc88$joe15@adesknews2.autodesk.com...
> Hello Bob,
> set.
> Does this help?
> rdh.
Message 4 of 9
Richard, I see what you mean. In actuality, I have the name of a block in a
string variable. Now using that name, I want to find out if any attributes
are defined for the block and if they are waht the tag is for the
attributes.
While I could search the drawing database for an instance of the block and
then use get attributes t determine the tags, is there a way to just lookup
a block definition and the associated attribute tags given the block name?
Bob Harden
> Hello Bob,
> set.
> Does this help?
> rdh.
Message 5 of 9
Bob Harden wrote in message <7vlhk6$jof25@adesknews2.autodesk.com>...
Oh - I'm sorry. I misunderstood. I thought you needed the
attributereference information - that is, specific values on
block inserts.
Unfortunately the block object does not provide a nice neat
attribute collection member. Instead, you need to iterate over
each entity in the definition and see if it is an attribute entity.
Here's a little example:
Sub TestAttributes()
On Error Resume Next
Dim strName As String
Dim oBlock As AcadBlock
Dim oEnt As AcadEntity
Dim oAttribute As AcadAttribute
'' get the block name
strName = InputBox("Enter a block name: ")
If "" = strName Then Exit Sub ' exit if no old name
'' get the block definition
Set oBlock = ThisDrawing.Blocks(strName)
If oBlock Is Nothing Then ' exit if not found
MsgBox "Block '" & strName & "' not found"
Exit Sub
'' iterate the block definition
For Each oEnt In oBlock
'' if the entity is an attribute
If oEnt.ObjectName = "AcDbAttributeDefinition" Then
'' cast to an attribute interface
Set oAttribute = oEnt
'' dump some attribute info to the debug window
Debug.Print ""
Debug.Print " Tag: " & oAttribute.TagString
Debug.Print "Prompt: " & oAttribute.PromptString
Debug.Print " Value: " & oAttribute.TextString
Debug.Print " Mode: " & oAttribute.Mode
Next
End Sub
Cheers-
rdh.
Message 6 of 9
Richard, Thanks very much for your valuable help.
Bob Harden
message news:7vnf85$o8p18@adesknews2.autodesk.com...
and
lookup
name?
> block inserts.
> Exit Sub
> End If
> Debug.Print ""
> End If
> Next
> End Sub
> Cheers-
> rdh.
Message 7 of 9
Richard, when I tried the sample code, I got a "Type Mismatch" error at the
line:
I changed the dimensioning to
Dim oEnt as Object
I also changed the line If oEnt.ObjectName =
to If oEnt.EntityName = "AcDbAttributeDefinition" Then
Seems like things are working now.
As I said, Thanks for your valuable help.
Bob Harden
news:7vnq7n$q2m17@adesknews2.autodesk.com...
> Bob Harden
> and
> lookup
> name?
> > block inserts.
> > Exit Sub
> > End If
> > Debug.Print ""
> > End If
> > Next
> > End Sub
> > Cheers-
> > rdh.
Message 8 of 9
Bob Harden wrote in message <7vnsjd$q2n9@adesknews2.autodesk.com>...
>line:
Ah - yes my sample is for Acad2000. Earlier versions will
require the alterations you suggest.
rdh.
Message 9 of 9
Test
