TextBox not working in VBA
Jedimaster
Jedimaster
I am working in AutoCAD 2010, Windows 7, 64 Bit. I can not edit Userform Textboxes. I can edit in 2007 VBA but not 2010. I read some things about
AcFocusCtrl control and AcFocusCtrl.dll. I can not locate on computer.
norman.yuan
It sounds you use a modeless UserForm, for which you need to use AcFocusCtrl in order for the controls on the form to maintain focus.
However, with 64bit AutoCAD of older version (prior to Acad2014), the VBA is still 32-bit and runnas external process synced with AutoCAD, there are quite some reports that modeless userform works not as expected, even with AcFocusCtrl beign used.
So, if possible, try avoid to show userform as modeless.
Anyway, to get AcFocusCtrl, you righ-click UserForm's toolbox and select "Additional controls...", you then should be able to see "AcFocusCtrl" in the "Additional Controls" dialog box, usually the first item. Check the leading check box and click "OK".
Norman Yuan
Drive CAD With Code
Jedimaster
Worked once I found it. Thank you very much.
Jedimaster
I found out this morning that this may not be a AutoCAD VBA issue.This a recent issue because the forms were working okay. When I added the focus control it caused errors on other machines. I found this may actually be rooted in a Windows Update issue.
VBA Form Controls stop working after December 2014 Updates
http://blogs.technet.com/b/the_microsoft_excel_support_team_blog/archive/2014/12/11/forms-controls-s...
