Extract text from AutoCAD to ms excel
ethaya
Message 1 of 19
ethaya
Hello all,
I would like to extract text (custom format which should be extracted alone not all) from AutoCAD to Microsoft excel sheet by VBA. I need a small button in excel. Text has to be extracted omce if i press that button. Kindly help me out regarding the same.
Thanks in advance.
Accepted solutions (3)
Replies (18)
Message 2 of 19
Alfred.NESWADBA
Upload a drawing so we know what you mean by "text" as there are different objects in AutoCAD that can hold textual info (TEXT; MTEXT, ATTRIBUTEREFERENCE,maybe dimensions/leaders too).
And if you already started with your code, then show this code so we know where to continue.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 19
ethaya
Hello Alfred,
Good day,
        Thank you very much for showing interest on my case. I'm using "Text" not MTEXT and other. So, please help me out with the vba codes. And I'm a new person to this script, So I did'nt start to write the codes still now.
Thank you in advance.
Best Regards,
Ethaya.
Message 4 of 19
Alfred.NESWADBA
just as sample, use your Excel VBA and make sure you have referenced the corresponding AutoCAD Type Library (or modify the code to use LateBinding).
The code is without error handling, just to show the basics (I also attached a XLSM here (from Excel 2013)
Option Explicit
Const AcadProgID = "AutoCAD.Application"
Const SelectionObjectTypeName As String = "TEXT"      'to search for TEXT/AcDbText only
Const SelectionSpace As String = "Model"              'to search in modelspace only
Public Sub getTextObjects()
   Dim tAcadApp As AcadApplication
   Dim tAcadDoc As AcadDocument
   On Error Resume Next
   Set tAcadApp = GetObject(, AcadProgID)
   If tAcadApp Is Nothing Then
      Call showMsg("Please start AutoCAD, open your drawing and make sure there is no command active", True)
   Else
      'well, Acad seems to be available for COM-Reqests, see if a document is current/active
      If tAcadApp.ActiveDocument Is Nothing Then
         Call showMsg("Please open your drawing and make sure it's the active document", True)
      Else
         'ok, a drawing is active
         Set tAcadDoc = tAcadApp.ActiveDocument
         Dim tSelSet As AcadSelectionSet
         'filter definition for selection
         Dim tDxfCodes(1) As Integer
         Dim tDxfValues(1) As Variant
         tDxfCodes(0) = 0: tDxfValues(0) = SelectionObjectTypeName    'that's to get only objects of type "TEXT"
         tDxfCodes(1) = 410: tDxfValues(1) = SelectionSpace
         'create the selection
         Set tSelSet = tAcadDoc.SelectionSets.Item("myTempSelSet")
         If tSelSet Is Nothing Then
            'then this selectionset didn't exist yet, so create a new one
            Set tSelSet = tAcadDoc.SelectionSets.Add("myTempSelSet")
         tSelSet.Clear
         'now run the selection
         Err.Clear
         tSelSet.Select acSelectionSetAll, , , tDxfCodes, tDxfValues
         If Err.Number <> 0 Then
            Call showMsg("Some error appeared while trying to select objects" & vbNewLine & Err.Description & vbNewLine & "Function cancelled", True)
         Else
            If tSelSet.Count = 0 Then
               Call showMsg("No objects of type TEXT found", False)
            Else
               'ok, we have objects, so let us now append them to the current workbook
               'I assume here, that Excel and the Workbook is ready and empty (or can be overwritten
               'this routine starts in the ActiveSheet ==> A:1
               Dim tTextObj As AcadText
               Dim tRowIndex As Integer: tRowIndex = 1
               For Each tTextObj In tSelSet
                  Call fillInfoFromText(tTextObj, tRowIndex)
                  tRowIndex = tRowIndex + 1
               Next
End Sub
Private Sub fillInfoFromText(ByRef TextObj As AcadText, ByVal RowIndex As Integer)
   Excel.ActiveSheet.Cells(RowIndex, 1) = TextObj.TextString
   Excel.ActiveSheet.Cells(RowIndex, 2) = TextObj.Layer
End Sub
Private Sub showMsg(ByVal Str As String, ByVal isError As Boolean)
   If isError Then
      Call MsgBox(Str, vbCritical)
   Else
      Call MsgBox(Str)
End Sub
- alfred -
Alfred NESWADBA
Message 5 of 19
ethaya
Hi alfred,
I would appreciate your effort. But I experienced some error with my excel. It says some error that I attached in this. I'm using autocad 2007. Excel reference library says missing 2015 type library. Please help me.
Thank you verymuch.
Best regards,
ETHAYA
Message 6 of 19
Alfred.NESWADBA
please read my post, there I stated:
I wrote that part using AutoCAD 2015, if you don't have 2015 you have to uncheck the AutoCAD 2015 type library and you have to add the type lib from your AutoCAD release.
- alfred -
Alfred NESWADBA
Message 7 of 19
ethaya
Hi Alfred,
Thank you very much for your help.. 🙂
Best regards
Ethaya.
Message 8 of 19
juanjogo
Hello Alfred,
Thank you for sharing.
I have a similar situation, the difference is that I'm searching for MTEXT. I've only used VBA in excel, and I thought that changing the statement
Const SelectionObjectTypeName As String = "MTEXT" would do the trick, but it didn't; also, what does 410 stand for in tDxfCodes(1) = 410?
I would appreciate any comments.
Thank you
Message 9 of 19
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
What exactly does not work? Do you get an exception or just no objects selected or do you get objects selected but not string values from the objects?
(410 . "Model") is a filter definition to only search for objects in modelspace (ignore objects in layouts)
- alfred -
Alfred NESWADBA
Message 10 of 19
juanjogo
Thank you for you reply Alfred,
I wasn't getting any text on the sheet, but I figured it out. I was missing declaring tTextObj as AcadMtext instead of AcadText. I am now getting all the Mtext in the dwg model, but the strings within TextObj.TextString also include text formatting information such as the font and size. Is there a way to acquire only the text and not the formatting information?
Message 11 of 19
Alfred.NESWADBA
Using VB.NET yes, using VBA sorry no.
For VBA there are some threads out in www which handle that (like e.g. >>>this one<<<, not tested, only found).
- alfred -
Alfred NESWADBA
Message 12 of 19
juanjogo
Ok, I'll write a VBA routine in excel to filter the text strings in that case.
Thanks for your help
Message 13 of 19
tom
Observer
Observer
Alfred,
I realize I'm reviving an old post, but I'm wondering if you know of a way to do this in reverse. Essentially I'm looking to take cells from within excel and use the data to ideally populate some mtext or a field. I'd prefer not to use regular autocad text nor importing the entire excel worksheet. The idea is to have the excel worksheet become a database of sorts to update project related info. If you know of a post dealing with this please let me know, otherwise I'll start a new thread on this topic.
Thanks!
Message 14 of 19
Alfred.NESWADBA
Sorry, no. I don't know a way (except of development of a tool) that is built into AutoCAD to access Excel data and get a value from a specific row/column.
Even the field function can't access an internal table (long unrepaired bug as shown >>>here<<<).
Maybe you can do that with some development using LISP or other API's, but out-of-the-box I don't see an option.
Sorry, - alfred -
Alfred NESWADBA
Message 15 of 19
Do you mean open excel from AutoCAD?
Or use an excel file that opens an AutoCAD file?
Once you create the COM object
Example Excel.Application.12
you should be able to use all the apps function including
Dim ExcelAppObj as Excel.Application
Set ExcelAppObj = New Excel.Application
ExcelAppObj.Visible = TRUE
ExcelAppObj.Workbooks("Sheet1").Activate
Set ExcelSheet = Excel.ActiveSheet
ExcelSheet.Cells(9, 1).Activate CellValueAt = ActiveCell.Value
Then switch to AutoCAD and populate away
Message 16 of 19
tiwari1211
Can you please share your code where you can only extract Mtext ?
I am very new to VBA and have no idea how to modify the code. Thank you
Message 17 of 19
buianhtuan.cdt
Public Const AppName As String = "AutoCad"
Public Const AppVersion As Integer = 2019
Public IgoreTextList As Variant
Public Const ZuWakuBlockname As String = "HIN1_AS_ENG"
Public Const WSName As String = "ExportText"
Public Const ProcessWSName As String = "Process"
Sub JHS01_ExportText2Excel()
    Application.ScreenUpdating = False
    Application.EnableEvents = False
'Settings
    Dim ClearOldColumnFromLetter As String: ClearOldColumnFromLetter = "C"
    Dim ClearOldColumnToLetter As String: ClearOldColumnToLetter = "N"
'Select Files
    Dim fnameList As Variant
    fnameList = Application.GetOpenFilename(FileFilter:="AutoCad File (*.dwg),*.dwg", Title:="Choose Autocad files", MultiSelect:=True)
    If (vbBoolean = VarType(fnameList)) Then
        MsgBox "No files selected"
        GoTo GTES
'Define VersionAppValue
    Dim GetAppValue As Variant
    Dim AppValue As String
    GetAppValue = JHF03_DefineVersionAppValue(AppName, AppVersion)
    If VarType(GetAppValue) = vbBoolean Then
        MsgBox "Can not define CAD Application Version Value"
        GoTo GTES
    Else
        AppValue = GetAppValue
'Startup Cad Application
    Dim AcadApp As AutoCAD.AcadApplication
    Set AcadApp = JHF04_StartupAutoCad(AppValue)
'Define WS
    Dim WS As Worksheet
    Dim ProcessWS As Worksheet
    Set WS = ThisWorkbook.Sheets(WSName)
    Set ProcessWS = ThisWorkbook.Sheets(ProcessWSName)
'Creat IgoreTextList
    IgoreTextList = JHF01_CrearArrFromWSColumn(WS, 1, 2)
'Clear Old Data and Color
    Call JHF02_Call_ClearDataCellFontColorOfRange(WS, ClearOldColumnFromLetter, ClearOldColumnToLetter, 2)
'Process
    Dim EachFilePath As Variant
    Dim EachFileName As String
    Dim CountFiles As Integer
    Dim EachDrawing As AcadDocument
    Dim EachSS As AcadSelectionSet
    Dim GetEachSS As Boolean
    Dim ProcessErr As Boolean
    Dim EachEndRowRange As Integer
    Dim EachEndRowFilePathColumn As Integer
    Dim ButtonMode As VbMsgBoxStyle
    Dim MsgMain As String
    Dim MsgYes As String
    Dim MsgNo As String
    Dim MsgCancel As String
    Dim Response As VbMsgBoxResult
    Dim Count_Total As Integer
    Dim Count_Finished As Integer
    Dim Count_Err As Integer
    Dim Count_TotalRowImport As Integer
    Dim Count_EachRowImport As Integer
    Count_Total = UBound(fnameList)
    For Each EachFilePath In fnameList
        'Open File(Read Only)
            Set EachDrawing = JHF05_OpenCadFile_AutoCad(AcadApp, EachFilePath, True)
        'Define FileName
            EachFileName = EachDrawing.Name
            EachFileName = Before_(EachFileName, ".")
        'Select Layout Contain WakuBlock
            Call JHF06X_Call_SelectLayoutContainWakuBlock(EachDrawing, ZuWakuBlockname)
GTSelectText:
        'Clear OldData in ProcessWS
            Call JHF02_Call_ClearDataCellFontColorOfRange(ProcessWS, "A", "L", 2)
        'Select Texts
            GetEachSS = JHF07_SelectOnScreen(EachDrawing, EachSS, "TEXT")
            If GetEachSS = False Then
                GoTo GTCloseFile
        'Get Information of Texts and write to ProcessWS
            Call JHF09X_Call_WriteTextInfoToExcel(EachSS, ProcessWS)
            EachSS.Erase
            EachSS.Delete
        'Arrange Text
            Call JHS02_ArrangeText(ProcessErr)
        'MsgBox when Error
            If ProcessErr = True Then
                ButtonMode = vbYesNoCancel
                MsgMain = "Warning: Can not define Table"
                MsgYes = "Close Current File. Continue"
                MsgNo = "Select Text Again"
                MsgCancel = "Exit Command"
                Call JHF19_Call_MsgBox_SelectMode(ButtonMode, MsgMain, MsgYes, MsgNo, MsgCancel, Response)
                Select Case Response
                    Case vbYes
                        GoTo GTCloseFile
                        Count_Err = Count_Err + 1
                    Case vbNo
                        GoTo GTSelectText
                    Case vbCancel
                        Count_Finished = 0
                        GoTo GTES
                End Select
        'Write FilePath,FileName to WS
            EachEndRowRange = JHF18_DefineEndRowOfRange(WS, "C", "O")
            Call HCF4079_DefineRowEndNo(WS, EachEndRowFilePathColumn, 3)
            WS.Range(WS.Cells(EachEndRowFilePathColumn + 1, 3), WS.Cells(EachEndRowRange, 3)).Value = EachFilePath
            WS.Range(WS.Cells(EachEndRowFilePathColumn + 1, 4), WS.Cells(EachEndRowRange, 4)).Value = EachFileName
        'Count Import Row
            Count_EachRowImport = EachEndRowRange - EachEndRowFilePathColumn
            Count_TotalRowImport = Count_TotalRowImport + Count_EachRowImport
        'Continue Select Text
            MsgMain = "Continue Or More Select Text"
            MsgNo = "More Select Text"
                Case vbYes
                    Count_Finished = Count_Finished + 1
                Case vbNo
                    GoTo GTSelectText
                Case vbCancel
                    Count_Finished = 0
                    GoTo GTES
            End Select
GTCloseFile:
        If AcadApp.Documents.Count > 1 Then
            EachDrawing.Close False
    Next
GTES:
    Application.ScreenUpdating = True
    Application.EnableEvents = True
    MsgBox "Select " & Count_Total & " Files" & vbNewLine & _
            Count_Finished & " / " & Count_Total & "Finished" & vbNewLine & _
            "Imported Total " & Count_TotalRowImport & " Rows" & vbNewLine & _
            Count_Err & " Error"
End Sub
Sub JHS02_ArrangeText(ProcessErr As Boolean)
'Settings
    Dim FinishedColorInder As Integer:      FinishedColorInder = 4
    Dim TextLenCNo As Integer:              TextLenCNo = 9
'Define WS and EndRow
    Dim WS As Worksheet
'Define EndRow of ProcessWS
    Dim EndRow As Integer
    Call HCF4079_DefineRowEndNo(ProcessWS, EndRow, 1)
    If EndRow = 1 Then
        ProcessErr = True
        GoTo GTES
'Define MinTextHeght
    Dim MinTextHeight As Double
    Dim TextHeightRange As Range
    Set TextHeightRange = ProcessWS.Range("J:J")
    MinTextHeight = WorksheetFunction.Min(TextHeightRange)
'Define TableColumnGroup by TextLen
    Dim GetMaxValue As Boolean
    Dim MaxValue As Double
    Dim MaxValue_RNo As Integer
    Dim MaxValue_MinXorY As Double
    Dim MaxValue_MidXorY As Double
    Dim MaxValue_MaxXorY As Double
    Dim RNo As Integer
    Dim EachMidXorY As Double
    Dim EachCompareResult As Boolean
    Do
        GetMaxValue = JHF11_DefineMinMaxValueAndPosition_IgoreColorIndex(ProcessWS, FinishedColorInder, TextLenCNo, 2, EndRow, "Max", MaxValue, MaxValue_RNo)
        If GetMaxValue = False Then
            GoTo GTNS1
        Else
            'Define MaxValue X Value
            MaxValue_MinXorY = ProcessWS.Cells(MaxValue_RNo, 3).Value
            MaxValue_MidXorY = ProcessWS.Cells(MaxValue_RNo, 4).Value
            MaxValue_MaxXorY = ProcessWS.Cells(MaxValue_RNo, 5).Value
            'Fill Color
            Call Func17BSetCellColorIndex(ProcessWS, MaxValue_RNo, TextLenCNo, TextLenCNo, FinishedColorInder)
            Call Func17BSetCellColorIndex(ProcessWS, MaxValue_RNo, 3, 5, FinishedColorInder)
        'Check MaxValue_MinXorY <= EachMidXorY <= MaxValue_MaxXorY
        'Match Value
        'FillColor
        For RNo = 2 To EndRow
            EachCompareResult = JHF12_CompareValueWithMinMax_IgoreColorIndex(ProcessWS, FinishedColorInder, RNo, 4, MaxValue_MinXorY, MaxValue_MaxXorY)
            If EachCompareResult = True Then
                ProcessWS.Cells(RNo, TextLenCNo).Value = MaxValue
                ProcessWS.Cells(RNo, 3).Value = MaxValue_MinXorY
                ProcessWS.Cells(RNo, 4).Value = MaxValue_MidXorY
                ProcessWS.Cells(RNo, 5).Value = MaxValue_MaxXorY
                Call Func17BSetCellColorIndex(ProcessWS, RNo, TextLenCNo, TextLenCNo, FinishedColorInder)
                Call Func17BSetCellColorIndex(ProcessWS, RNo, 3, 5, FinishedColorInder)
        Next
GTNS1:
    Loop While GetMaxValue = True
'Define TableRowGroup by MidY
    Do
        GetMaxValue = JHF11_DefineMinMaxValueAndPosition_IgoreColorIndex(ProcessWS, FinishedColorInder, 7, 2, EndRow, "Max", MaxValue, MaxValue_RNo)
            GoTo GTNS2
        Else
            'Define MaxValue Y Value
            MaxValue_MidXorY = ProcessWS.Cells(MaxValue_RNo, 7).Value
            MaxValue_MinXorY = MaxValue_MidXorY - MinTextHeight
            MaxValue_MaxXorY = MaxValue_MidXorY + MinTextHeight
            ProcessWS.Cells(MaxValue_RNo, 6).Value = MaxValue_MinXorY
            ProcessWS.Cells(MaxValue_RNo, 8).Value = MaxValue_MaxXorY
            'Fill Color
            Call Func17BSetCellColorIndex(ProcessWS, MaxValue_RNo, 6, 8, FinishedColorInder)
        'Match Value
        'FillColor
            EachCompareResult = JHF12_CompareValueWithMinMax_IgoreColorIndex(ProcessWS, FinishedColorInder, RNo, 7, MaxValue_MinXorY, MaxValue_MaxXorY)
                ProcessWS.Cells(RNo, 6).Value = MaxValue_MinXorY
                ProcessWS.Cells(RNo, 7).Value = MaxValue_MidXorY
                ProcessWS.Cells(RNo, 8).Value = MaxValue_MaxXorY
                Call Func17BSetCellColorIndex(ProcessWS, RNo, 6, 8, FinishedColorInder)
        Next
GTNS2:
'Creat List of MidX
    Dim MidXArr As Variant
    MidXArr = JHF13_CreatListValueAndSort_NumberType(ProcessWS, 4, 2, "SortAtoZ")
'Creat List of MidY
    Dim MidYArr As Variant
    MidYArr = JHF13_CreatListValueAndSort_NumberType(ProcessWS, 7, 2, "SortZtoA")
'Write TableRNo to ProcessWS
    Call JHF15X_WriteTableRNoCNoToProcessWS(ProcessWS, MidYArr, 7, 11, 2, EndRow)
'Write TableCNo to ProcessWS
    Call JHF15X_WriteTableRNoCNoToProcessWS(ProcessWS, MidXArr, 4, 12, 2, EndRow)
'Define Table_Total Column,Row
    Dim Table_TotalRow As Double
    Dim Table_TotalColumn As Double
    Table_TotalRow = JHF16_MinMaxValueAtColumnOfWS(ProcessWS, 11, "Max")
    Table_TotalColumn = JHF16_MinMaxValueAtColumnOfWS(ProcessWS, 12, "Max")
'Creat Table_TextString()
    Dim GetTable As Boolean
    Dim Table_TextString() As String
    ReDim Table_TextString(1 To Table_TotalRow, 1 To Table_TotalColumn)
    GetTable = JHF17X_CreatTableVale(ProcessWS, Table_TextString, 2, 2, EndRow)
    If GetTable = False Then
        ProcessErr = True
        GoTo GTES
'Creat Table_Handle()
    Dim Table_Handle() As String
    ReDim Table_Handle(1 To Table_TotalRow, 1 To Table_TotalColumn)
    GetTable = JHF17X_CreatTableVale(ProcessWS, Table_Handle, 1, 2, EndRow)
        ProcessErr = True
        GoTo GTES
'Write Table_Handle to WS
'Write Table_TextString to WS
    Dim WSEndrow As Integer
    Dim WriteRNo As Integer
    Call HCF4079_DefineRowEndNo(WS, WSEndrow, 3)
    Dim EachTextString As String
    Dim EachHandle As String
    Dim WriteCNo_Text As Integer
    Dim WriteCNo_Handle As Integer
    For i = LBound(Table_Handle) To UBound(Table_Handle)
        WriteRNo = WSEndrow + i
        For k = LBound(Table_Handle, 2) To UBound(Table_Handle, 2)
            WriteCNo_Handle = k + 4
            WriteCNo_Text = k + 9
            EachHandle = Table_Handle(i, k)
            EachTextString = Table_TextString(i, k)
            WS.Cells(WriteRNo, WriteCNo_Handle).Value = EachHandle
            WS.Cells(WriteRNo, WriteCNo_Text).Value = EachTextString
        Next
    Next
'Clear OldData In Process WS
'ExitSub
GTES:
End Sub
Sub JHS03_UpdateChange()
        GoTo GTES
    Else
'Define WS
    Dim WS As Worksheet
'Define EndRow
    Call HCF4079_DefineRowEndNo(WS, EndRow, 3)
    If EndRow < 2 Then GoTo GTES
'Creat UpdateArr(FilePath,Handle,Value)
    Dim UpdateArr() As String: Dim aa As Integer
    Dim EachUpdate As String
    Dim Delimited As String: Delimited = "***"
    Dim RNo As Integer
    Dim CNo As Integer
    Dim EachPathRange As Range
    Dim EachPath As String
    Dim EachPathColorIndex As Integer
    Dim EachTextRange As Range
    Dim EachText As String
    Dim EachTextColorIndex As Integer
    Dim UpdateTotal As Integer
    'Check Color of PathFile
        Set EachPathRange = WS.Cells(RNo, 3)
        EachPath = WS.Cells(RNo, 3).Value
        EachPathColorIndex = EachPathRange.Interior.ColorIndex
        If EachPathColorIndex <> 6 Then GoTo GTSkip
         For CNo = 10 To 14
        'Check Color of TextRange
            Set EachTextRange = WS.Cells(RNo, CNo)
            EachTextColorIndex = EachTextRange.Interior.ColorIndex
            If EachTextColorIndex = 6 Then
                EachHandle = WS.Cells(RNo, CNo - 5).Value
                If EachHandle <> "" Then
                    EachText = WS.Cells(RNo, CNo).Value
                    EachUpdate = EachPath & Delimited & EachHandle & Delimited & EachText
                    ReDim Preserve UpdateArr(0 To aa)
                    UpdateArr(aa) = EachUpdate
                    aa = aa + 1
        Next
GTSkip:
    Next
    If aa = 0 Then
        GoTo GTES
    Else
        UpdateTotal = aa
'Update
    Dim EachSplit As Variant
    Dim OldPath As String
    Dim EachObjText As AcadText
    Dim CountChange As Integer
    For i = LBound(UpdateArr) To UBound(UpdateArr)
        EachUpdate = UpdateArr(i)
        EachSplit = Split(EachUpdate, Delimited)
        EachPath = EachSplit(0)
        EachHandle = EachSplit(1)
        EachText = EachSplit(2)
    'Open File(Write)
        If EachPath <> OldPath Then
            Set EachDrawing = JHF05_OpenCadFile_AutoCad(AcadApp, EachPath, False)
    'Change TextString
        Set EachObjText = EachDrawing.HandleToObject(EachHandle)
        If VarType(EachObjText) <> vbEmpty Then
            EachObjText.TextString = EachText
            CountChange = CountChange + 1
        OldPath = EachPath
    Next
'Reset Color
    Dim ResetColorRange As Range
    Dim ResetRangeStr As String
    ResetRangeStr = "C2:N" & EndRow
    Set ResetColorRange = WS.Range(ResetRangeStr)
    ResetColorRange.Interior.ColorIndex = 0
    MsgBox "Updated " & CountChange & " / " & UpdateTotal
GTES:
End Sub
Function JHF01_CrearArrFromWSColumn(WS As Worksheet, MainColumnNo As Integer, RowFrom As Integer) As Variant
'Defaut Value
    JHF01_CrearArrFromWSColumn = False
'Define EndRow
    EndRow = WS.Cells(Rows.Count, MainColumnNo).End(xlUp).Row
    If EndRow < RowFrom Then Exit Function
'Creat Arr
    Dim Arr() As String: Dim aa As Integer
    Dim RNo As Integer
    Dim EachValue As String
    For RNo = RowFrom To EndRow
        EachValue = WS.Cells(RNo, MainColumnNo).Value
        If EachValue <> "" Then
            ReDim Preserve Arr(0 To aa)
            Arr(aa) = EachValue
            aa = aa + 1
    Next
'Result
    If aa > 0 Then
        JHF01_CrearArrFromWSColumn = Arr
End Function
Function JHF02_Call_ClearDataCellFontColorOfRange(WS As Worksheet, ColumnFromLetter As String, ColumnToLetter As String, RowFrom As Integer)
'Define EndRow
    Dim ColumnFromNo As Integer
    Dim ColumnToNo As Integer
    Dim EachEndRow As Integer
    Dim CNo As Integer
    ColumnFromNo = Func29ConvertColumnLetterToNumber(ColumnFromLetter)
    ColumnToNo = Func29ConvertColumnLetterToNumber(ColumnToLetter)
    For CNo = ColumnFromNo To ColumnToNo
        Call HCF4079_DefineRowEndNo(WS, EachEndRow, CNo)
        If EachEndRow > EndRow Then EndRow = EachEndRow
    Next
'Define ClearRangeStr
    Dim ClearRangeStr As String
    ClearRangeStr = ColumnFromLetter & RowFrom & ":" & ColumnToLetter & EndRow
'Define ClearRange
    Dim ClearRange As Range
    Set ClearRange = WS.Range(ClearRangeStr)
'Clear Old Data
    ClearRange.ClearContents
'Clear Cell Color
    With ClearRange.Interior
        .Pattern = xlNone
        .TintAndShade = 0
        .PatternTintAndShade = 0
    End With
'Clear Font Color
    With ClearRange.Font
        .ColorIndex = xlAutomatic
        .TintAndShade = 0
    End With
End Function
Function JHF03_DefineVersionAppValue(AutoCad_BricsCad As String, VersionNo As Integer) As Variant
'Defaut Value
    JHF03_DefineVersionAppValue = False
'Define AppValue
    Select Case AutoCad_BricsCad
        Case "AutoCad"
            Select Case VersionNo
                Case 2014
                Case 2015
                Case 2016
                Case 2017
                Case 2018
                Case 2019
                    AppValue = "AutoCAD.Application.23"
                Case 2020
                Case Else
                    Exit Function
            End Select
        Case "BricsCad"
                Case 19
                    AppValue = "BricscadApp.AcadApplication"
                Case 2020
                Case Else
                    Exit Function
            End Select
        Case Else
            Exit Function
    End Select
'Result
    If AppValue <> "" Then
        JHF03_DefineVersionAppValue = AppValue
End Function
Function JHF04_StartupAutoCad(AppValue As String) As AutoCAD.AcadApplication
    Set AcadApp = GetObject(, AppValue)
    If err Then
        Set AcadApp = CreateObject(AppValue)
    AppActivate AcadApp.Caption
    AcadApp.Visible = False
    AcadApp.Application.WindowState = acNorm
    AcadApp.ActiveDocument.ActiveSpace = acModelSpace
'Result
    Set JHF04_StartupAutoCad = AcadApp
End Function
Function JHF05_OpenCadFile_AutoCad(AcadApp As AutoCAD.AcadApplication, FilePath As Variant, ReadOnlyMode As Boolean) As AcadDocument
    Dim MyDrawing As AcadDocument
    Dim IsOpenning As Boolean
    If AcadApp.Documents.Count > 0 Then
        For Each EachDrawing In AcadApp.Documents
            If EachDrawing.FullName = FilePath Then
                IsOpenning = True
                Set MyDrawing = EachDrawing
        Next
    Select Case ReadOnlyMode
        Case True
            If IsOpenning = False Then
                Set MyDrawing = AcadApp.Documents.Open(FilePath, ReadOnlyMode)
        Case False
            Else
                MyDrawing.Close False
    End Select
'Result
    Set JHF05_OpenCadFile_AutoCad = MyDrawing
End Function
Function JHF06X_Call_SelectLayoutContainWakuBlock(MyDrawing As AcadDocument, WakuBlockName As String)
    Dim EachLayout As AcadLayout
    Dim AllSelect As AcadSelectionSet
    Set AllSelect = MyDrawing.SelectionSets.ADD("AllSelect" & Now)
    Dim FT(0) As Integer:   Dim FD(0) As Variant
    FT(0) = 0:              FD(0) = "INSERT"
    For Each EachLayout In MyDrawing.Layouts
        AllSelect.Select acSelectionSetAll, , , FT, FD
        If AllSelect.Count <> 0 Then
            AllSelect.Delete
            MyDrawing.ActiveLayout = EachLayout
            Exit Function
    Next
End Function
Function JHF07_SelectOnScreen(Thisdrawing As AcadDocument, SS As AcadSelectionSet, FilterData As String) As Boolean
    Set SS = Thisdrawing.SelectionSets.ADD("SS" & Now)
    FT(0) = 0:              FD(0) = FilterData
    SS.SelectOnScreen FT, FD
    If SS.Count <> 0 Then
        JHF07_SelectOnScreen = True
End Function
Function JHF08_Call_MinMaxMiddleXYOfObject(Entity As AcadEntity, MinX As Double, MidX As Double, MaxX As Double, MinY As Double, MidY As Double, MaxY As Double, RoundMode As Integer)
'Define MinPoint, MaxPoint
    Dim MinPoint As Variant
    Dim MaxPoint As Variant
    Entity.GetBoundingBox MinPoint, MaxPoint
'Define MinX,MaxX,MinY,MaxY
    MinX = MinPoint(0)
    MinY = MinPoint(1)
    MaxX = MaxPoint(0)
    MaxY = MaxPoint(1)
'Define MidX, MidY
    MidX = (MinX + MaxX) / 2
    MidY = (MinY + MaxY) / 2
'Round
    If RoundMode <> 100 Then
        MinX = Round(MinX, RoundMode)
        MidX = Round(MidX, RoundMode)
        MaxX = Round(MaxX, RoundMode)
        MinY = Round(MinY, RoundMode)
        MidY = Round(MidY, RoundMode)
        MaxY = Round(MaxY, RoundMode)
End Function
Function JHF09X_Call_WriteTextInfoToExcel(SS As AcadSelectionSet, ProcessWS As Worksheet)
    Dim WriteRow As Integer
    WriteRow = EndRow + 1
'Define EachValue
    Dim EachText As AcadText
    Dim Each01Handle As String
    Dim Each02TextString As String
    Dim Each03MinX As Double
    Dim Each04MidX As Double
    Dim Each05MaxX As Double
    Dim Each06MinY As Double
    Dim Each07MidY As Double
    Dim Each08MaxY As Double
    Dim Each09Len As Double
    Dim Each10Height As Double
    For Each EachText In SS
        Each01Handle = EachText.Handle
    'Reform TextString
        Each02TextString = EachText.TextString
        Each02TextString = JHF10X_ReFormTextString(Each02TextString)
        If Each02TextString = "" Then GoTo GTSkip
        Call JHF08_Call_MinMaxMiddleXYOfObject(EachText, Each03MinX, Each04MidX, Each05MaxX, Each06MinY, Each07MidY, Each08MaxY, 1)
        Each09Len = Each05MaxX - Each03MinX
        Each10Height = EachText.Height
        Each10Height = Round(Each10Height, 1)
    'Write EachVale to Excel
        ProcessWS.Cells(WriteRow, 1).Value = Each01Handle
        ProcessWS.Cells(WriteRow, 2).Value = Each02TextString
        ProcessWS.Cells(WriteRow, 3).Value = Each03MinX
        ProcessWS.Cells(WriteRow, 4).Value = Each04MidX
        ProcessWS.Cells(WriteRow, 5).Value = Each05MaxX
        ProcessWS.Cells(WriteRow, 6).Value = Each06MinY
        ProcessWS.Cells(WriteRow, 7).Value = Each07MidY
        ProcessWS.Cells(WriteRow, 8).Value = Each08MaxY
        ProcessWS.Cells(WriteRow, 9).Value = Each09Len
        ProcessWS.Cells(WriteRow, 10).Value = Each10Height
        WriteRow = WriteRow + 1
GTSkip:
    Next
End Function
Function JHF10X_ReFormTextString(BeforeValue As String) As String
'Check Input
    If BeforeValue = "" Then Exit Function
'Convert JIS to ASC
    Dim AfterValue As String
    AfterValue = WorksheetFunction.Asc(BeforeValue)
'Clear Space
    AfterValue = WorksheetFunction.Substitute(AfterValue, " ", "")
'Check is in IgoreTextArr
    Dim IsInIgoreList As Boolean
    If VarType(IgoreTextList) = vbBoolean Then
        JHF10X_ReFormTextString = AfterValue
        Exit Function
    Else
        IsInIgoreList = HCF4086_IsInArr1Chieu_NumberOrString(IgoreTextList, AfterValue)
    If IsInIgoreList = True Then
        JHF10X_ReFormTextString = ""
    Else
End Function
Function JHF11_DefineMinMaxValueAndPosition_IgoreColorIndex(WS As Worksheet, ColorIndex As Integer, CNo As Integer, RFrom As Integer, RTo As Integer, MinMaxMode As String, ResultValue As Double, ResultRNo As Integer) As Boolean
'Gan MinValue, MaxValue
    Dim MinValue As Double
    Dim RNo As Integer
    Dim EachValue As Double
    Dim EachColorIndex As Integer
    Dim EachCell As Range
    Dim DefineMinMax As Boolean
    For RNo = RFrom To RTo
        Set EachCell = WS.Cells(RNo, CNo)
        EachColorIndex = EachCell.Interior.ColorIndex
        If ColorIndex <> EachColorIndex Then
            EachValue = EachCell.Value
            MinValue = EachValue
            MaxValue = EachValue
            DefineMinMax = True
            GoTo GTNextStep
    Next
GTNextStep:
    If DefineMinMax = False Then
        Exit Function
'Compare CellValue with Min,Max
    Dim MinRNoPosition As Integer
    Dim MaxRNoPosition As Integer
            If EachValue <= MinValue Then
                MinRNoPosition = RNo
            If EachValue >= MaxValue Then
                MaxRNoPosition = RNo
    Next
'Result
    Select Case MinMaxMode
        Case "Min"
            ResultValue = MinValue
            ResultRNo = MinRNoPosition
        Case "Max"
            ResultValue = MaxValue
            ResultRNo = MaxRNoPosition
    End Select
    JHF11_DefineMinMaxValueAndPosition_IgoreColorIndex = True
End Function
Function JHF12_CompareValueWithMinMax_IgoreColorIndex(WS As Worksheet, ColorIndex As Integer, RNo As Integer, CNo As Integer, MinValue As Double, MaxValue As Double) As Boolean
    If EachColorIndex <> ColorIndex Then
        If MinValue <= EachValue And EachValue <= MaxValue Then
            JHF12_CompareValueWithMinMax_IgoreColorIndex = True
End Function
Function JHF13_CreatListValueAndSort_NumberType(WS As Worksheet, ColumnNo As Integer, RFrom As Integer, SortAtoZ_SortZtoA_NoSort As String) As Variant
'Define EndRow
    EndRow = WS.Cells(Rows.Count, ColumnNo).End(xlUp).Row
'Creat ValueArr
    Dim ValueArr() As Variant
    Dim aa As Integer: aa = 1
    Dim RNo As Integer
    Dim IsInArr As Boolean
    For RNo = RFrom To EndRow
        EachValue = WS.Cells(RNo, ColumnNo).Value
        If aa = 1 Then
            IsInArr = False
        Else
            IsInArr = HCF4086_IsInArr1Chieu_NumberOrString(ValueArr, EachValue)
        If IsInArr = False Then
            ReDim Preserve ValueArr(1 To aa)
            ValueArr(aa) = EachValue
            aa = aa + 1
    Next
    If aa = 1 Then
        JHF13_CreatListValueAndSort_NumberType = False
        Exit Function
'Sort
    Select Case SortAtoZ_SortZtoA_NoSort
        Case "SortAtoZ"
            ValueArr = HCF4057_SortArrAtoZ_NumberType(ValueArr)
        Case "SortZtoA"
            ValueArr = JHF14_SortArrZtoA_NumberType(ValueArr)
        Case Else
    End Select
'Resutl
    JHF13_CreatListValueAndSort_NumberType = ValueArr
End Function
Function JHF14_SortArrZtoA_NumberType(Arr As Variant) As Variant
    Dim BackupValue As Double
    Dim CompareValue As Double
    Dim TmpArr As Variant
    TmpArr = Arr
    For i = LBound(TmpArr) To UBound(TmpArr)
        CompareValue = TmpArr(i)
        For k = i To UBound(TmpArr)
            EachValue = TmpArr(k)
            If CompareValue < EachValue Then
                BackupValue = CompareValue
                CompareValue = EachValue
                EachValue = BackupValue
                TmpArr(i) = CompareValue
                TmpArr(k) = EachValue
        Next
    Next
    JHF14_SortArrZtoA_NumberType = TmpArr
End Function
Function JHF15X_WriteTableRNoCNoToProcessWS(WS As Worksheet, ValueList As Variant, ValueCNo As Integer, WriteCNo As Integer, RFrom As Integer, RTo As Integer)
    Dim RNo As Integer
    Dim EachTableRCNo As Variant
        EachValue = WS.Cells(RNo, ValueCNo).Value
        EachTableRCNo = HCF4158_DefinePositionInArr1ChieuWithDelta_Number(ValueList, EachValue, 0)
        If VarType(EachTableRCNo) <> vbBoolean Then
            WS.Cells(RNo, WriteCNo).Value = EachTableRCNo
    Next
End Function
Function JHF16_MinMaxValueAtColumnOfWS(WS As Worksheet, CNo As Integer, MinOrMax As String) As Double
'Define ValueRange
    Dim ValueRange As Range
    Set ValueRange = WS.Columns(CNo)
'Define MinValue MaxValue
    Dim MaxVale As Double
    MinValue = WorksheetFunction.Min(ValueRange)
    MaxValue = WorksheetFunction.Max(ValueRange)
'Result
    Select Case MinOrMax
        Case "Min"
            JHF16_MinMaxValueAtColumnOfWS = MinValue
        Case "Max"
            JHF16_MinMaxValueAtColumnOfWS = MaxValue
        Case Else
            MsgBox "Err: Check value of MinOrMax in function"
    End Select
End Function
Function JHF17X_CreatTableVale(WS As Worksheet, Table() As String, ValueColumnNo As Integer, RFrom As Integer, RTo As Integer) As Boolean
'Defaut Value
    JHF17X_CreatTableVale = False
'Process
    Dim RNo As Integer
    Dim EachTableRNo As Integer
    Dim EachTableCNo As Integer
    Dim EachOldValue As String
        EachValue = WS.Cells(RNo, ValueColumnNo).Value
        EachTableRNo = WS.Cells(RNo, 11).Value
        EachTableCNo = WS.Cells(RNo, 12).Value
        EachOldValue = Table(EachTableRNo, EachTableCNo)
        If EachOldValue <> "" Then
            MsgBox "Err: Duplication TableRNo,TableCNo"
            Exit Function
        Else
            Table(EachTableRNo, EachTableCNo) = EachValue
    Next
'Function Result
    JHF17X_CreatTableVale = True
End Function
Function JHF18_DefineEndRowOfRange(WS As Worksheet, ColumnFromLetter As String, ColumnToLetter As String) As Integer
'Define ColumnFromNo, ColumnToNo
'Define EndRow
    Dim CNo As Integer
    Next
'Function Result
    JHF18_DefineEndRowOfRange = EndRow
End Function
Function JHF19_Call_MsgBox_SelectMode(ButtonMode As VbMsgBoxStyle, MsgMain As String, MsgYes As String, MsgNo As String, MsgCancel As String, Response As VbMsgBoxResult)
    Dim MsgTitle As String: MsgTitle = "(TB VBABoss)"
'Define Msg
    Dim Msg As String
    Select Case ButtonMode
        Case vbYesNo
            Msg = MsgMain & vbNewLine & vbNewLine & _
                  Space(5) & "Yes: " & MsgYes & vbNewLine & _
                  Space(5) & "No: " & MsgNo
        Case vbYesNoCancel
                  Space(5) & "No: " & MsgNo & vbNewLine & _
                  Space(5) & "Cancel: " & MsgCancel
        Case Else
            Exit Function
    End Select
    Response = MsgBox(Msg, ButtonMode, MsgTitle)
End Function
Function JHF20_Call_DefineRFromRToCFromCToOfRange(TargetRange As Range, RRFrom As Integer, RRTo As Integer, RCFrom As Integer, RCTo As Integer)
'Define FirstCell, EndCell
    Dim FirstCell As Range
    Dim EndCell As Range
    Set FirstCell = TargetRange.Cells(1, 1)
    Set EndCell = TargetRange.Cells(TargetRange.Rows.Count, TargetRange.Columns.Count)
'Define RRFrom  RRTo RCFrom  RCTo
    RRFrom = FirstCell.Row
    RRTo = EndCell.Row
    RCFrom = FirstCell.Column
    RCTo = EndCell.Column
End Function
Function Func29ConvertColumnLetterToNumber(ColumnLetter As String) As Integer
' Function chuyen ma so cot tu letter sang number
'Convert To Column Number
Dim ColumnNumber As Long
ColumnNumber = Range(ColumnLetter & 1).Column
Func29ConvertColumnLetterToNumber = ColumnNumber
End Function
Function HCF4079_DefineRowEndNo(WS As Worksheet, EndRow As Integer, ColumnNo As Integer)
End Function
Function HCF4086_IsInArr1Chieu_NumberOrString(ListArr As Variant, NeedCheckValue As Variant) As Boolean
    Dim CompareValue As Variant
    For i = LBound(ListArr) To UBound(ListArr)
        CompareValue = ListArr(i)
        If CompareValue = NeedCheckValue Then
            HCF4086_IsInArr1Chieu_NumberOrString = True
            Exit Function
    Next
End Function
Function Func17BSetCellColorIndex(WS As Worksheet, RowNo As Integer, ColumnNoFrom As Integer, ColumnNoTo As Integer, ColorIndex As Integer)
' to mau cho o voi colorindex
For i = ColumnNoFrom To ColumnNoTo
    With WS.Cells(RowNo, i).Interior
            .Pattern = xlSolid
            .PatternColorIndex = xlAutomatic
            .ColorIndex = ColorIndex
            .TintAndShade = 0
    End With
Next
End Function
Function HCF4057_SortArrAtoZ_NumberType(Arr As Variant) As Variant
' Sap xep cac phan tu cua mang theo thu tu tu A den Z
Dim TmpValue As Double
Dim SmallValue As Double
Dim LargeValue As Double
TmpArr = Arr
    SmallValue = TmpArr(i)
        LargeValue = TmpArr(k)
        If SmallValue > LargeValue Then
            TmpValue = SmallValue
            SmallValue = LargeValue
            LargeValue = TmpValue
            TmpArr(i) = SmallValue
            TmpArr(k) = LargeValue
    Next
Next
HCF4057_SortArrAtoZ_NumberType = TmpArr
End Function
Function HCF4158_DefinePositionInArr1ChieuWithDelta_Number(ListArr As Variant, NeedCheckValue As Double, Delta As Double) As Variant
'Defaut Value
    HCF4158_DefinePositionInArr1ChieuWithDelta_Number = False
'Process
        CompareValue = CDbl(CompareValue)
        If Abs(CompareValue - NeedCheckValue) <= Delta Then
            HCF4158_DefinePositionInArr1ChieuWithDelta_Number = i
            Exit Function
    Next
End Function
Function After_(Txt As String, Delimiter As String) As String
    Dim DelimiterPosition As Integer
    DelimiterPosition = InStr(Txt, Delimiter)
    After_ = Right(Txt, Len(Txt) - DelimiterPosition)
End Function
Function Before_(Txt As String, Delimiter As String) As String
    Before_ = Left(Txt, DelimiterPosition - 1)
End Function
Message 18 of 19
buianhtuan.cdt
Private Sub Worksheet_Change(ByVal Target As Range)
    Dim a As Integer
'Define EndRow of Range
    Dim WS As Worksheet
    Set WS = ActiveSheet
    Dim EndRowOfRange As Integer
    EndRowOfRange = JHF18_DefineEndRowOfRange(WS, "J", "N")
'Define ChangeRange
    Dim ChangeRange As Range
    Dim ChangeRangeStr As String
    ChangeRangeStr = "J2:N" & EndRowOfRange
    Set ChangeRange = WS.Range(ChangeRangeStr)
    If Not Intersect(Target, ChangeRange) Is Nothing Then
        'Define RFrom,RTo of Target
            Dim RFrom As Integer
            Dim RTo As Integer
            Dim CFrom As Integer
            Dim CTo As Integer
            Call JHF20_Call_DefineRFromRToCFromCToOfRange(Target, RFrom, RTo, CFrom, CTo)
        'Fill Color of Target is Yellow
            Target.Interior.ColorIndex = 6
        'Fill Color at FilePathColumn
            Dim RNo As Integer
                WS.Cells(RNo, 3).Interior.ColorIndex = 6
            Next
End Sub
Message 19 of 19
buianhtuan.cdt
Sub TBS115_Calendar_SaGyouNichiSuu()
'Define WS
    Call TBFH123_Call_SetWorksheet
'Setting
    Dim NichiSuuColumnNo As Integer:    NichiSuuColumnNo = 26
    Dim MonthColumnNo As Integer:       MonthColumnNo = NichiSuuColumnNo + 2
    Dim MonthRFrom As Integer:          MonthRFrom = 2
    Dim MonthRTo As Integer
    Call HCF4079_DefineRowEndNo(SetupWS, MonthRTo, MonthColumnNo)
    Dim DayCFrom As Integer:            DayCFrom = 29
    Dim DayCTo As Integer:              DayCTo = 59
'Process
    Dim RNo As Integer
    Dim CNo As Integer
    Dim EachMonthValue As String
    Dim EachDayType As String
    Dim EachNichiSuu As Integer
    For RNo = MonthRFrom To MonthRTo
        EachNichiSuu = 31
        EachMonthValue = SetupWS.Cells(RNo, MonthColumnNo).Value
        If EachMonthValue = "" Then GoTo GTNS1
        For CNo = DayCFrom To DayCTo
            EachDayType = SetupWS.Cells(RNo, CNo).Value
            Select Case EachDayType
                Case "休日", "祝日", "X"
                    EachNichiSuu = EachNichiSuu - 1
                Case "奨励日"
                    EachNichiSuu = EachNichiSuu + 1
                Case Else
            End Select
        Next
        SetupWS.Cells(RNo, NichiSuuColumnNo).Value = EachNichiSuu
GTNS1:
    Next
    MsgBox TBMsg02
End Sub
