Text Window Access thru VBA
Message 1 of 15
I would like to know if there is a way to access either the command line or the text window through Visual Basic other than the SendCommand method. I would like to post a comment to the command line area and not to a popup dialog box as MsgBox does.
Replies (14)
Message 2 of 15
ThisDrawing.Utility.Prompt "My Message to display goes here"
Will display the message at the command prompt but not pause for user input. You also need CMDECHO to be ON.
Message 3 of 15
Thanks!! It really works!!!
Message 4 of 15
If you want to make it look like the Command: prompt is clear, use ThisDrawing.Utility.Prompt "my message" & vbCrLf & "Command:" HTH, Ed
Message 5 of 15
Thank you. That will come in very handy!
Message 6 of 15
brian_adams
Is there way to capture text from Autocad text window or command line?
Message 7 of 15
norman.yuan
No, not with AutoCAD VBA/COM APIs, AFAIK.
Norman Yuan
Drive CAD With Code
Message 8 of 15
brian_adams
Message 9 of 15
Ed__Jobe
Even if you could, those api's don't apply to AutoCAD's command line.
Ed
How to post your code.
Message 10 of 15
brian_adams
Could it be sollution???
https://forums.autodesk.com/t5/visual-basic-customization/capturing-command-line-output-from-vba/m-p...
I missed some thing it capture emptyness
Message 11 of 15
Ed__Jobe
No, that just writes the output of a command to the system variable USERS1.
Ed
Message 12 of 15
brian_adams
There is some macros that  can capture a lot of things. they works
https://stackoverflow.com/questions/2784367/capture-output-value-from-a-shell-command-in-vba
but any example of text window in AutoCAD
Message 13 of 15
Ed__Jobe
As @norman.yuan already mentioned, not for AutoCAD VBA.
You never stated what you're trying to do. Why do you need to capture the command window text? Perhaps there is an alternative?
Ed
Message 14 of 15
brian_adams
oh this is dream
I want to make material report for AECobject in Autocad Architecture
The only method to calculate  fine is command "Materiallist"
I've made is macro that
1. makes property set deffinition for (AECwall)
2.creates property"material"
3. serching for AECwall in current drawing
4. select it and  run materiallist command for every AECwall
5. MiSSED PART(capture value from command line and filtering it) but filtering not a problam
6. wright it to property
I made chek wrighting ID of every AECwall to property"material"  it works
so there is  another way only I see now
Manually  copy history of autocad window text and copy it to excel file
then  run another script to capture date   and apply it to AECwall
that how it looks now
Sub materiallist()
Dim SchedApp As New AecScheduleApplication
Dim cProps As AecScheduleProperties
Dim PropSetDefs As AecSchedulePropertySetDefs
Dim propsetdef As AecSchedulePropertySetDef
Dim propertyDefs As AecSchedulePropertyDefs
Dim propertydef As AecSchedulePropertyDef
Dim propertyset As AecSchedulePropertySet
Dim propertysets As AecSchedulePropertySets
Dim obj As AcadObject
Dim msg As String
Dim PrSetDefName As String
Dim propertydefname As String
PrSetDefName = "Wall_Materiallist"
propertydefname = "Materiall"
'_______________________________create property set________________________________
On Error Resume Next
' Access the set of property definitions.
Set propsetdef = PropSetDefs(PrSetDefName)
' If set of property definitions isn't created then create it.
If propsetdef Is Nothing Then
PropSetDefs.Add (PrSetDefName)
Set PropSetDefs = SchedApp.PropertySetDefs(ThisDrawing.Database)
' Now add a property definition to the new set of definitions.
Set propertyDefs = propsetdef.propertyDefs
Set propertydef = propertyDefs(propertydefname)
' If set of property definitions name isn't created then create it.
If propertydef Is Nothing Then
propertyDefs.Add (propertydefname)
' Access the definition just created, and set some properties.
propertydef.Description = "materiall from materiallst."
propertydef.Format = "Standard"
propertydef.Type = aecSchedulePropertyTypeText
'_________________________________counting materiallist______________________________________
Dim ent As AcadEntity
Dim geo As AecGeo
Dim wall As AecWall
Dim findObj As AcadObject
Dim point(0 To 2) As Double
Dim sset As AcadSelectionSet
For Each ent In ThisDrawing.ModelSpace
If TypeOf ent Is AecWall Then
Set wall = ent
Set sset = ThisDrawing.SelectionSets.Add("SS10")
ObjectID = wall.ObjectID
Set findObj = ThisDrawing.ObjectIdToObject(ObjectID)
point(0) = wall.Location(0): point(1) = wall.Location(1): point(2) = wall.Location(2)
sset.SelectAtPoint point
If sset.Count > 0 Then
ThisDrawing.Utility.Prompt "ID " & ObjectID
ThisDrawing.SendCommand "Select p " & vbCrLf
ThisDrawing.SendCommand "Materiallist" & vbCr & vbCr
'________________apply property to walls _____________________
Set propertysets = SchedApp.propertysets(wall)
' Add a new property set. Notice that the Add method requires
' a property set definition argument, not a property set.
propertysets.Add propsetdef
'___________________________adding value to property set and_____________________
Dim retval As String
retval = CStr(ObjectID)
Set propertyset = propertysets.Item("Wall_Materiallist")
If Not propSet Is Nothing Then
Set cProps = propertyset.Properties
cProps.Item("Materiall").Value = retval
ThisDrawing.SelectionSets("SS10").Delete
Else
Set ent = Nothing
Next
End Sub
Message 15 of 15
brian_adams
