Text Style Vertical
Text Style Vertical
Text Style Vertical
How do I tell if a text style has the vertical flag set? I figured out I
can get Backwards, and upsidedown from the TextGenerationFlag value, but I
don't see any where to get the vertical setting.
This is a snip of what I am trying to do.
Sub test()
Dim textStyles As String
Dim TextEntry As AcadTextStyle
textStyles = ""
For Each TextEntry In ThisDrawing.textStyles
textStyles = textStyles + "textstyle" & "," & TextEntry.Name & "," &
TextEntry.fontFile & "," & _
TextEntry.Height & "," & TextEntry.Width & "," &
TextEntry.ObliqueAngle & "," & TextEntry.TextGenerationFlag & vbCrLf
'How do I get the vertical?
Next
MsgBox textStyles
End Sub
Kent Keller
Strobe Data Inc.
www.strobedata.com
Signs of the Times
LOG ON: Makin a wood stove hotter
Kent,
A Text object has a rotation property which I believe is what you are
looking for.
Joe Sutphin
Author of "AutoCAD 2000 VBA Programmers Reference"
ISBN #1861002564 Order it at
http://www.amazon.com/exec/obidos/ASIN/1861002564/o/qid%3D942504788/sr%3D8-1
/002-7788324-2908264
Checkout Sources - the only magazine dedicated to AutoCAD customization
http://vbdesign.hypermart.net/sources/
Kent Keller wrote in message
news:85dfq2$2ek11@adesknews2.autodesk.com...
> Sub test()
> textStyles = ""
> Next
> MsgBox textStyles
> End Sub
> Kent Keller
> Strobe Data Inc.
> www.strobedata.com
> Signs of the Times
Joe
I don't think so, I am not looking at a text object.
What I want to do is check to see if a text style has the vertical
check box checked in the Style dialog box. There doesn't need to
be any text created, and most likely won't be when this is run.
Basically I am trying to take a Textstyle and save it to a *.txt
file so I can recreate the textstyle in another drawing.
Kent Keller
Check out the Mechanical Desktop FAQ @
http://webhome.idirect.com/~dfulford/
"Joe Sutphin" wrote in message
news:85e12m$3p356@adesknews2.autodesk.com...
> Kent,
you are
> looking for.
lando7189
I know this is a REALLY OLD post, but i'm putting this here incase anybody else encounters it.  You must look to see if bitcode 4 is set within DXF group 70 of the style.
HTH - Lanny
Public Function EvalLispExpression(lispStatement As String) As Variant
    On Error Resume Next: DoEvents
    EvalLispExpression = ""
    'Exit Function
    Dim origSDI As Integer
    origSDI = ThisDrawing.GetVariable("SDI")
    If False And origSDI = 1 Then
        ThisDrawing.SetVariable "SDI", 0
    End If
    'Dim vlApp As Object
    If vlApp Is Nothing Then
        Set vlApp = CreateObject("VL.Application.16")
    End If
    Dim vlDoc As Object
    Set vlDoc = vlApp.ActiveDocument
    Dim vlFunc As Object
    Set vlFunc = vlDoc.Functions
    Dim vlRead As Object
    Set vlRead = vlFunc.Item("read")
    Dim vlSym As Object
    Set vlSym = vlRead.funcall(lispStatement)
    Dim vlEval As Object
    Set vlEval = vlFunc.Item("eval")
    Dim RetVal As Variant
    RetVal = vlEval.funcall(vlSym)
    If Err Then RetVal = ""
    Set vlSym = Nothing
    Set vlEval = Nothing
    Set vlRead = Nothing
    Set vlFunc = Nothing
    Set vlDoc = Nothing
    Set vlApp = Nothing
        ThisDrawing.SetVariable "SDI", 1
    End If
    EvalLispExpression = RetVal
End Function
Public Function IsTextStyleVertical(ts As AcadTextStyle) as Boolean
    IsTextStyleVertical = EvalLispExpression("(= (LOGAND 4 (CDR (ASSOC 70 (TBLSEARCH ""STYLE"" """ & ts.Name & """)))) 4)") <> "True"
End Function
