temporary entity in vba
Dear Sir,
I make a line via AddLine method. But the line is always displayed.
I want to compute the geometric calculation without displaying in vba.
So, I want to make a line and modify it in the background.
How do I use any technique if it is possible?
Thank you.
Yokogawa Techno-Information Service Inc.
HIOKI Nobukazu / Solution Service Division
mailto:n.hioki@yti.co.jp http://www.yti.co.jp
Tel:+81-(0)47-435-3652 Fax:+81-(0)47-435-6150
When you use the Addline command the line is not normally drawn until you
update the screen in some way.
Code like:
Dim Pt1 (0 to 2) as Double
Dim Pt2 (0 to 2) as Double
Set oLine = ThisDrawing.ModelSpace.Addline (Pt1, Pt2)
Pt1(0) = 20
Pt1(1) = 30
Pt2(0) = 100
Pt2(1) = 20
With oLine
.end = Pt2
.Start = Pt1
.Update
End With
is perfectly viable.
Laurie Comerford
CADApps
www.cadapps.com.au
"HIOKI Nobukazu" wrote in message
news:4934607@discussion.autodesk.com...
Dear Sir,
Thank you.
Myline:visible = False
Saludos, Ing. Jorge Jimenez, SICAD S.A., Costa Rica
Dear Sir,
Thank you.
Thanks Lauire and Jorge.
I will try it.
