intersectwith block ...HELP HELP HELP
Hi guys,
Here is a small VBA Code .It's a sample of the use of intersect
with a block.
The intersection point(s) Autocad 2002 give are totaly wrong.
Could anybody help me ?
Sub Example_IntersectWith()
' This example creates a line and block and finds the points at
' which they intersect.
' Create the line
Dim lineObj As AcadLine
Dim startPt(0 To 2) As Double
Dim endPt(0 To 2) As Double
startPt(0) = 1: startPt(1) = 1: startPt(2) = 0
endPt(0) = 5: endPt(1) = 5: endPt(2) = 0
Set lineObj = ThisDrawing.ModelSpace.AddLine(startPt, endPt)
' Create the block
Dim blockObj As AcadBlock
Dim insertionPnt(0 To 2) As Double
insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "CircleBlock")
' Add a circle to the block
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 3: center(1) = 3: center(2) = 0
radius = 1
Set circleObj = blockObj.AddCircle(center, radius)
' Insert the block
Dim blockRefObj As AcadBlockReference
insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1#, 1#, 1#, 0)
ZoomExtents
ThisDrawing.Regen (acAllViewports)
' Find the intersection points between the line and the circle
Dim intPoints As Variant
intPoints = lineObj.IntersectWith(blockRefObj, acExtendNone)
' Print all the intersection points
Dim I As Integer, j As Integer, k As Integer
Dim str As String
If VarType(intPoints) <> vbEmpty Then
For I = LBound(intPoints) To UBound(intPoints)
str = "Intersection Point[" & k & "] is: " & intPoints(j) & "," & intPoints(j + 1) & "," & intPoints(j + 2)
MsgBox str, , "IntersectWith Example"
str = ""
I = I + 2
j = j + 3
k = k + 1
Next
End Sub
Many thanks ...
i think youre finding the intersection points of the block's bounding box and the line.
don't put the circle in a block if you want to find the
intersection
To get the intersection of objects nested in a block,
you must explode the block, and run intersectWith on
each resulting entity, and then erase them.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:4934581@discussion.autodesk.com...
Hi guys,
with a block.
' Create the line
' Create the block
radius = 1
' Insert the block
ZoomExtents
Dim str As String
str = ""
I = I + 2
j = j + 3
k = k + 1
Next
End Sub
Many thanks ...
