Table SetBackgroundColorNone Variable
I have a Table that has every other row set to a color. I would like to set
every other row to background fill = none. this is what I found so far:
myTable.SetBackgroundColorNone y - 1, False
this command sets my table row to color white. does anyone know how to set
it to none.
Nate,
You are using an incorrect method, for starters, and then if you *don't*
want a background, you need to use _True_ for the SetCellBackgroundColorNone
method's argument.
Sub Test()
Dim myTable As AcadTable
With ThisDrawing.ModelSpace
Set myTable = .Item(.Count - 1)
End With
Dim myColor As AcadAcCmColor
Set myColor = New AcadAcCmColor
myColor.ColorIndex = acRed
Dim i As Long, j As Long
For i = 0 To myTable.Rows - 1
If i Mod 2 = 1 Then
For j = 0 To myTable.Columns - 1
myTable.SetCellBackgroundColorNone i, j, False
myTable.SetCellBackgroundColor i, j, myColor
Next j
Else
myTable.SetCellBackgroundColorNone i, j, True
Next j
End If
Next i
End Sub
R. Robert Bell
"Nate Hunter" wrote in message
news:5105348@discussion.autodesk.com...
it to none.
thanks that did the trick
"R. Robert Bell" wrote in message
news:5109446@discussion.autodesk.com...
Nate,
method's argument.
Sub Test()
End With
If i Mod 2 = 1 Then
Next j
Else
Next j
End If
Next i
End Sub
R. Robert Bell
it to none.
