System variables - VBA
Message 1 of 9
I am trying to set up some system variables by VBA. But I couldn´t find the variable name for the MODEL SCALE propertie in the menu ASSIST >> MECHANICAL OPTIONS >>STANDARD.... I am sendind a attached image file showing it... Anyone could help me... thx a lot Luciano
Replies (8)
Message 2 of 9
Hi Luciano, The name of the variable you want is AMSYMSCALE... I think you will have to use SendCommand to change the value... /Rikard "Luciano Gazai" skrev i meddelandet news:40e5706b_1@newsprd01... > I am trying to set up some system variables by VBA. > > But I couldn´t find the variable name for the MODEL SCALE propertie in the > menu ASSIST >> MECHANICAL OPTIONS >>STANDARD.... > > I am sendind a attached image file showing it... > > Anyone could help me... > > thx a lot > Luciano > > >
Message 3 of 9
Thanks Rickard, And you right, I needed to send comand to set it up! "Rikard Nilsson" escreveu na mensagem news:40ea552f_1@newsprd01... > Hi Luciano, > > The name of the variable you want is AMSYMSCALE... > > I think you will have to use SendCommand to change the value... > > /Rikard > > > "Luciano Gazai" skrev i meddelandet > news:40e5706b_1@newsprd01... > > I am trying to set up some system variables by VBA. > > > > But I couldn´t find the variable name for the MODEL SCALE propertie in > the > > menu ASSIST >> MECHANICAL OPTIONS >>STANDARD.... > > > > I am sendind a attached image file showing it... > > > > Anyone could help me... > > > > thx a lot > > Luciano > > > > > > > >
Message 4 of 9
you can try with:
Thisdrawing.sendcommand "(setvar ""AMSYMSCALE""" & Text1.Text & ")" & vbCr & vbCr
Message was edited by: diAb0Lo
Message 5 of 9
Starting with 2000, you can't control the contents of the text window. It saves the last 400 lines. You can only control whether the content is saved to a *.log file. You can clean the current prompt by sending another promt line to the command line, thus forcing the one you don't like further back in the command history. Here's a function I wrote to handle sending prompts Sub CommandLine(msg As String) ThisDrawing.Utility.Prompt (msg & vbCrLf & "Command: ") End Sub To clear the last prompt, use: CommandLine "" -- ---- Ed ---- "diAb0Lo" wrote in message news:9018389.1089133438149.JavaMail.jive@jiveforum1.autodesk.com... you can try with: Thisdrawing.sendcommand "(setvar ""AMSYMSCALE""" & Text1.Text & vbCr & vbCr
Message 6 of 9
what about (defun CmdHistLines( / numlines i) (setq numlines(Getint"\nNumber of lines")) (setq i 0) (setenv"CmdHistLines"(itoa numlines)) ;to test (repeat(atoi(Getenv"CmdHistLines")) (print(setq i(1+ i)))) ) 4000 used to be the upper limit now(a2k5) 2048 seems to be the max "Ed Jobe" wrote in message news:40eae200$1_1@newsprd01... Starting with 2000, you can't control the contents of the text window. It saves the last 400 lines. You can only control whether the content is saved to a *.log file. You can clean the current prompt by sending another promt line to the command line, thus forcing the one you don't like further back in the command history. Here's a function I wrote to handle sending prompts Sub CommandLine(msg As String) ThisDrawing.Utility.Prompt (msg & vbCrLf & "Command: ") End Sub To clear the last prompt, use: CommandLine "" -- ---- Ed ---- "diAb0Lo" wrote in message news:9018389.1089133438149.JavaMail.jive@jiveforum1.autodesk.com... you can try with: Thisdrawing.sendcommand "(setvar ""AMSYMSCALE""" & Text1.Text & vbCr & vbCr
Message 7 of 9
Ed, did you reply to the wrong thread or is my newsreader messing up? Murph
Message 8 of 9
I hope something is not going wrong with the nntp side. This was a reply to "Clean command interface from vba". Maybe Anne can move this reply there? -- ---- Ed ---- "Murph" wrote in message news:40eaeb97$1_1@newsprd01... Ed, did you reply to the wrong thread or is my newsreader messing up? Murph
Message 9 of 9
Ed - There is such heavy HTML coding in your message it wouldn't copy as a quoteback! I hand copied your and MP's messages over to "Clean command interface from vba". From looking at the headers on the two messages they truly do appear to have been put onto "System variables" originally as an answer. I'll keep an extra watch out though for any non-synching messages. --- Anne Brown Discussion Groups Administrator Autodesk, Inc.
