Switch to - Retry
Switch to - Retry
Switch to - Retry
at a certain point of my application, I ask the user to click on the open
AutoCAD document to select two points of a line.
Well, when the user tries to click on the document, it appears the message:
Component request pending...An action cannot be completed,
because the component Draw.dwg is not responding.
Choose "Switch to" to activate the component and correct the
problem.
Switch to Retry
How can I solve this problem?
Thanks in advance
Emanuele
why not just use the "active drawing" ??
Jaime
Marco wrote in message
news:F9C29AD1BF3CC9D0A23C35DEFC6C16C4@in.WebX.maYIadrTaRb...
> Hi,
message:
> problem.
> Switch to Retry
> Thanks in advance
> Emanuele
I think you're suggesting me to do something like this: acdDoc.active
but the document Activation by the "active" property, correctly works only
in VBA,
but not in VB (which I must use...).
Is it there such a similar property to do the same in VB?
Which?
Emanuele
Jaime wrote in message
66C79D595019CAABE3B63869A1263E1C@in.WebX.maYIadrTaRb...
> Jaime
> > Hi,
open
> message:
> > problem.
> > Switch to Retry
> > Thanks in advance
> > Emanuele
no..im sugesting you use the current drawing that is open
and everything you can do in vba you can do in VB i have used acdboc.active
in vb
Jaime
news:F7BFA1887340B11BB28335751C4484CF@in.WebX.maYIadrTaRb...
> in VBA,
> Which?
> Thanks
> Emanuele
> > Jaime
> > > Hi,
> open
> > message:
the
> > > problem.
> > > Switch to Retry
> > > Thanks in advance
> > > Emanuele
