ObjectDBX question
ObjectDBX question
ObjectDBX question
i'm using dbx with standalone vb.  i don't
know where to begin so can someone help me on just opening a file (C:\Test.dwg)
and displaying a msgbox with how many blocks are in the drawing.  do i need
an autocad.acadapplication first or do i make a new dbx document only or
what?  i'm looking for speed here and using the acad object to open
drawings is too slow.
please help, thanks
Rob
W2k,
A2K2, VB6, VB.NET
From Standalone VB, AutoCAD needs to be running, and you
must use the AcadApplication's GetInterfaceObject() method
to create the AxDbDocument instance:
Dim oAcad As AcadApplication
Dom dbxDoc As AxDbDocument
oAcad = GetObject(, "AutoCAD.Application.15")
dbxDoc = oAcad.GetInterfaceObject("ObjectDBX.AxDbDocument")
MsgBox " Block count = " & dbxDoc.Blocks.Count
"Rob Tomson" wrote in message
news:AA178EAF6B388A9F1B08A70BAF1BCB64@in.WebX.maYIadrTaRb...
> i'm using dbx with standalone vb. i don't know where to begin so can
someone help me on just opening a file (C:\Test.dwg) and displaying a msgbox
with how many blocks are in the drawing. do i need an
autocad.acadapplication first or do i make a new dbx document only or what?
i'm looking for speed here and using the acad object to open drawings is too
slow.
> please help, thanks
> Rob
> W2k, A2K2, VB6, VB.NET
I just finished going through what your trying to
do.  I started and finished a vb6.exe using objectDBX then I rewrote it to
use AcadX instead of objectDXB and greatly increased my speed.
Go here for more info or email me directly for
questions
(C:\Test.dwg) and displaying a msgbox with how many blocks are in the
drawing.  do i need an autocad.acadapplication first or do i make a new
dbx document only or what?  i'm looking for speed here and using the
acad object to open drawings is too slow.
please help, thanks
Rob
W2k,
A2K2, VB6, VB.NET
that's what i needed to know, thank you very much!
Rob
"Tony Tanzillo" wrote in message
news:6CF7BFF63F1354CA3B9D2DFBC3832A30@in.WebX.maYIadrTaRb...
msgbox
what?
too
> slow.
> > please help, thanks
> > Rob
will this code still work in VB.net ?
msgbox
what?
too
> slow.
> > please help, thanks
> > Rob
I don't see why not.
news:4B8B88935EE4CDF18E701ACE975DD779@in.WebX.maYIadrTaRb...
because i get the following error:
An unhandled exception of type 'System.Runtime.InteropServices.COMException'
occurred in AutoCAD Test.exe
Additional information: Problem in loading application
the error occurs on the line:
what can i do to fix this?
thanks for your help,
Rob
news:264652F47446D49408384E78C7D39AA1@in.WebX.maYIadrTaRb...
