Swap Index of Items in a Collection
I have created a collection class with the code below and fill it with objects from another class. I have populated a listbox with the MyObject.Name property of these objects. What I would like to do now is swap the positions of the items in the collection and then repopulate the listbox. Is it possible to change the index of items in a collection? Thanks for any help. Chris Option Explicit Private m_colColumns As Collection Private m_lngKeyNum As Long Public Property Get Count() As Long Count = m_colColumns.Count End Property Public Sub AddColumn(ByRef objColumn As clsColumn) On Error GoTo AddColumnError m_colColumns.Add objColumn, CStr(m_lngKeyNum) 'objColumn.Name m_lngKeyNum = m_lngKeyNum + 1 Exit Sub AddColumnError: If Err.Number = 457 Then MsgBox objColumn.Name & " already exists and was not added. Enter another name." Else MsgBox objColumn.Name & " already exists and was not added." End If End Sub Public Function Item(ByVal v_vntIndex As Variant) As clsColumn On Error Resume Next Set Item = m_colColumns.Item(v_vntIndex) If Err.Number <> 0 Then Set Item = Nothing End If End Function Public Sub Remove(Index As Variant) m_colColumns.Remove (Index) End Sub Private Sub Class_Initialize() Set m_colColumns = New Collection m_lngKeyNum = 1 End Sub Private Sub Class_Terminate() Set m_colColumns = Nothing End Sub Public Property Get NewEnum() As IUnknown Set NewEnum = m_colColumns.[_NewEnum] End Property
Define SWAP. Are you looking to sort the collection? If so, I can post that for you. Otherwise, it is possible, but you'll need to write a function to accommodate. It would be easier to do it with Dictionaries instead of collections -- Mike ___________________________ Mike Tuersley CADalyst's CAD Clinic Rand IMAGINiT Technologies ___________________________ the trick is to realize that there is no spoon...
By SWAP I mean that I would like to be able to change/reorder the index values of certain items in the collection. For instance, I am currently adding items to my collection. I then populate a listbox with info from items of that collection. Later, I may either add or delete items from that collection. I then clear and then refill the listbox to show the current items of the collection. The order in which they are displayed in dependent upon the order in which they were added to the collection. I want to adjust that order. In the past I have had listboxes based on array info. I would use a spin button to reposition the selected item either up or down. Below is an example using arrays (paste into form with Listbox1 and SpinButton1 controls). I now want to do the same thing with a collection. I hope this makes it a little more clear. btw, I read your article in Cadalyst Aug 04 where you mentioned dictionaries and should give them a serious look. Thanks. Chris Option Explicit Private m_MyArray(4) As String Private Sub UserForm_Initialize() m_MyArray(0) = "A" m_MyArray(1) = "B" m_MyArray(2) = "C" m_MyArray(3) = "D" m_MyArray(4) = "E" FillList End Sub Private Sub FillList() Dim i As Integer ListBox1.Clear For i = LBound(m_MyArray) To UBound(m_MyArray) ListBox1.AddItem m_MyArray(i) Next i End Sub Private Sub SpinButton1_SpinDown() Dim iPos As Integer Select Case True Case ListBox1.ListIndex = -1 MsgBox "You must select one!" Case ListBox1.ListIndex = ListBox1.ListCount - 1 MsgBox "You are at the Bottom!" Case Else Swap m_MyArray(ListBox1.ListIndex), m_MyArray(ListBox1.ListIndex + 1) If ListBox1.ListIndex < ListBox1.ListCount - 1 Then iPos = ListBox1.ListIndex + 1 End If FillList ListBox1.ListIndex = iPos End Select End Sub Private Sub SpinButton1_SpinUp() Dim iPos As Integer Select Case True Case ListBox1.ListIndex = -1 MsgBox "You must select one!" Case ListBox1.ListIndex = 0 MsgBox "You are at the Top!" Case Else Swap m_MyArray(ListBox1.ListIndex), m_MyArray(ListBox1.ListIndex - 1) If ListBox1.ListIndex > 0 Then iPos = ListBox1.ListIndex - 1 End If FillList ListBox1.ListIndex = iPos End Select End Sub Public Sub Swap(A As String, B As String) Dim C As String C = A A = B B = C End Sub "Mike Tuersley" wrote in message news:1kiz5m3gnz2fl$.v31t7tspq09a.dlg@40tude.net... > Define SWAP. Are you looking to sort the collection? If so, I can post that > for you. Otherwise, it is possible, but you'll need to write a function to > accommodate. It would be easier to do it with Dictionaries instead of > collections > > -- Mike > ___________________________ > Mike Tuersley > CADalyst's CAD Clinic > Rand IMAGINiT Technologies > ___________________________ > the trick is to realize that there is no spoon...
Here is what I use for what its worth. It is much the same
as yours. I think the listbox and collection are separate
items. Therefore you'll have to remake the collection with the
listbox if you expect the collection to be ordered the same.
Private Sub spinList_Spindown()
BumpItemDn
End Sub
Private Sub spinList_SpinUp()
BumpItemUp
End Sub
Private Sub BumpItemUp()
Dim t As String
With ufQP.lboxFiles2Plot
For x = 0 To .ListCount - 1
If .Selected(x) = True And x > 0 Then
t = .List(x - 1)
.List(x - 1) = .List(x)
.List(x) = t
.Selected(x - 1) = True
.Selected(x) = False
Exit For
End If
Next
End With
End Sub
Private Sub BumpItemDn()
Dim t As String
If .Selected(x) = True And x < .ListCount - 1 Then
t = .List(x + 1)
.List(x + 1) = .List(x)
.List(x) = t
.Selected(x + 1) = True
Exit For
End If
Next
End With
End Sub
Well when you add an item to a collection, you can specify the Before or After item. What you could do is capture the place where the 'move' item should be, remove it, adjust your stored 'insertion point' because all items below the remove will shift up one, then re-insert the 'move' item. So in pseudo code: col.item1 = "Item1" col.item2 = "Item2" col.item3 = 'Item3" -- move 2 to top iNewPlace = 1 col.remove 2 col.add "Item2", Before:=1 Again, not real code but the idea =) -- Mike ___________________________ Mike Tuersley CADalyst's CAD Clinic Rand IMAGINiT Technologies ___________________________ the trick is to realize that there is no spoon...
