Status Bar
Status Bar
Message 1 of 12
Status Bar
Is it possible to show a status bar or something similar while a program is
running? Ideas for either VB6.0 or VBA would be much appreciated.
Replies (11)
Message 2 of 12
I should rephrase my question : I need to display a progress (or status)
bar to show how much time is remaining in a certain procedure.
Randy wrote in message
news:[email protected]...
is
Message 3 of 12
Hi Randy,
In VB6, you can use a splash screen with a progress bar. There are already
activex progress bars built. You can access them by right clicking on an empty
area of the controls page in your toolbox (when a form or splash is being
constructed) and select additional controls. Splash screens in vba with
progress bars are a nice dream that come to programers on a good night, but
they're not yet a reality 😞 I've been close, but never successful. Although,
I haven't tried building a splash screen with progress bar in a dll and
wrapping it in vba,,,,,hhmmmm,,,
-Josh
> is
Message 3 of 12
In VBA, you can right-click on the 'Toolbox' 'Controls' palette, select
'Additional Controls' for additional *installed* controls. Scroll down and
there may be one or two labeled 'Microsoft ProgressBar Control'.
-- Walter -- http://www.ActiveDwg.com
> is
Message 3 of 12
Randy,
You can use the Microsoft ProgressBar Control
I use it in a userform with VB5
I think it is possible with VB6
Bernard
Randy a écrit dans le message :
> is
Message 6 of 12
Attached you will will a splash screen that I made up completely within
AutoCAD VBA. No additional references to a status bar control needed. The
basic idea is to use two labels, one on top of another. Set one labels to be
sunken and the other to be raises. Change the color of the raised label to
what you want. I used blue. Then within your procedure, start the width of
the raised label as 0 and then index the width until completion. Here is
some sample code to place in your procedure. You'll have to do some work in
order for it to work for you.
Public Sub Program_setup()
Dim Steps as Integer
Steps = 5
For i=0 to Steps
Start.Progress.Width = (Start.Label2.Width-2) / Steps * i
DoEvents
'place code you want to execute
Next i
Unload Start
End Sub
"Progress" is the name of the raised label and Label2 is name of sunken
label
When the Splash screen form activates, it will call the Program_setup sub
procedure.
Just show the splash screen and everything should work on its own. The
progress bar on this example will whip across very fast. You may not be able
to notice it.
Hope you like the cheap and dirty trick,
Sergio DeAlbuquerque
President
Matrix Technical Services Inc.
172 N.Bicycle Path
Selden, NY 11784
Ph: 631-736-9001
Fax: 631-696-8538
http://www.matrixengg.com
[email protected]
"CAD services, machine design, and VBA application development"
Message 7 of 12
Steps = 5
For i=0 to Steps
DoEvents
Next i
Unload Start
End Sub
label
procedure.
to notice it.
President
172 N.Bicycle Path
Selden, NY 11784
Ph: 631-736-9001
Fax: 631-696-8538
[email protected]
Message 8 of 12
The man is a giant 🙂  VBdesign
Randy <[email protected]> wrote in message
program
is
Message 9 of 12
Hi Sergio,
It may be cheap and dirty, but I like it. It could have it's uses when copying mutiple files, ect. It
appears that Randall Rath has come up with a solution as well. Check out the link I posted below. 🙂
-Josh
> Steps = 5
> For i=0 to Steps
> DoEvents
> Next i
> Unload Start
> End Sub
> label
> procedure.
> to notice it.
> President
> 172 N.Bicycle Path
> Selden, NY 11784
> Ph: 631-736-9001
> Fax: 631-696-8538
> [email protected]
> Name: Splash Screen.frm
> Splash Screen.frm Type: Visual Basic Form File (application/x-unknown-content-type-VisualBasic.Form)
> Encoding: quoted-printable
Message 10 of 12
Thanks for the complement. I checked out Randall's Code. Of course, he
always lives up to his Wonder Liama name.
Liama's Rule!!!!
President
172 N.Bicycle Path
Selden, NY 11784
Ph: 631-736-9001
Fax: 631-696-8538
[email protected]
Message 11 of 12
er, Sergio, now yer gonna get it. Liama??
Sergio DeAlbuquerque wrote in message
> Liama's Rule!!!!
> President
> 172 N.Bicycle Path
> Selden, NY 11784
> Ph: 631-736-9001
> Fax: 631-696-8538
> [email protected]
Message 12 of 12
Oops, I meant Llama's Rule!!!! Where did that "i" come from? That's why I'm
not the Wonder Llama.
Sorry Randall.
President
172 N.Bicycle Path
Selden, NY 11784
Ph: 631-736-9001
Fax: 631-696-8538
[email protected]
