specifying the layout to activate
Message 1 of 9
I'm opening a mechanical desktop file, using VBA, that has several layouts
relating to the model. I need to set the current layout to be the one that I
want to work on, and I want to delete the layouts that I don't need.
I can set the current mode correctly but it defaults to the last layout that
was open when the file was saved.
Does anyone have code to specify the current layout?
Replies (8)
Message 2 of 9
Phil,
Try setting the variable CTAB to the desired layout name just after it
opens the drawing.
Cheers,
Thilak
"Phil Tumelty" wrote in message
news:[email protected]...
I
that
Message 3 of 9
ThisDrawing.ActiveLayout = ThisDrawing.Layouts()
"That's no ordinary rabbit."
http://www.acadx.com
layouts
one that I
layout that
Message 4 of 9
Thanks for that Frank.
The code that you posted expects an index for the layout. Is there any way
to use the layout name ?
Phil
"Frank Oquendo" wrote in message
> layouts
> one that I
> layout that
Message 5 of 9
Yep. Just pass a string containg the layout's name and you'll be set
to go.
any way
> Phil
Message 6 of 9
arcticad
Dim Ctab
Ctab = ThisDrawing.GetVariable("CTAB")
ThisDrawing.ActiveLayout = ThisDrawing.Layouts(Ctab)
(defun botsbuildbots() (botsbuildbots))
Message 7 of 9
buianhtuan.cdt
Sub TB0106CreatNewFromRefDrawing()
    Application.ScreenUpdating = False
    Application.EnableEvents = False
'Setting
    Dim ColumnNo As Integer: ColumnNo = 1
'Set WS
    Dim WS As Worksheet
    Set WS = Sheets("16.GetText")
    Dim EndRow As Integer
    EndRow = WS.Cells(Rows.Count, ColumnNo).End(xlUp).Row
'Creat TextArr
    Dim RNo As Integer
    Dim CNo As Integer
    Dim TextArr() As String
    ReDim TextArr(1 To EndRow, ColumnNo To ColumnNo + 2)
    Dim EachContent As String
    Dim EachType As String
    For RNo = 1 To EndRow
        EachContent = WS.Cells(RNo, ColumnNo)
        EachType = WS.Cells(RNo, ColumnNo + 1)
        TextArr(RNo, ColumnNo) = EachContent
        TextArr(RNo, ColumnNo + 1) = EachType
    Next
'Startup BricsCad
    Dim Thisdrawing As AcadDocument
    Set Thisdrawing = KhoidongAutoCad()
'Active Layout
    Dim EachLayout As AcadLayout
    Dim EachLayoutName As String
    For Each EachLayout In Thisdrawing.Layouts
        EachLayoutName = EachLayout.Name
        If EachLayoutName <> "Model" Then
            Thisdrawing.ActiveLayout = EachLayout
        End If
    Next
'Set SS
    Dim SS As AcadSelectionSet: Set SS = Thisdrawing.SelectionSets.ADD("SS" & Now)
    Dim FT(3) As Integer: Dim FD(3) As Variant
    FT(0) = -4:     FD(0) = "<OR"
    FT(1) = 0:      FD(1) = "TEXT"
    FT(2) = 0:      FD(2) = "MTEXT"
    FT(3) = -4:     FD(3) = "OR>"
'Process
    Dim EachEntity As AcadEntity
    Dim EachMText As AcadMText
    Dim EachText As AcadText
    Dim EachString As String
    For RNo = LBound(TextArr) To UBound(TextArr)
        EachContent = TextArr(RNo, ColumnNo)
        If EachContent = "" Then GoTo Skip
        Thisdrawing.Utility.Prompt (vbCrLf & EachContent)
        SS.SelectOnScreen FT, FD
        If SS.Count <> 1 Then
            SS.Clear
            GoTo Skip
        End If
        For Each EachEntity In SS
            Select Case EachEntity.ObjectName
                Case "AcDbMText"
                    Set EachMText = EachEntity
                    EachString = EachMText.TextString
                Case "AcDbText"
                    Set EachText = EachEntity
                    EachString = EachText.TextString
            End Select
        Next
        TextArr(RNo, ColumnNo + 2) = EachString
        SS.Clear
Skip:
    Next
'Write to Excel
        EachString = TextArr(RNo, ColumnNo + 2)
        WS.Cells(RNo, ColumnNo + 2) = EachString
    Next
    Application.ScreenUpdating = True
    Application.EnableEvents = True
End Sub
Message 8 of 9
buianhtuan.cdt
Sub CreateAfile()
    Dim lk As String
    Dim outem As String
    lk = "D:\"
    lk = lk & "Log_CuttedFromMasterBOM_" & Format(Now, "yymmddhhmmss") & ".txt"
    outem = "2222" & vbNewLine & "333" & vbTab & "4444"
    Dim fso As Object, MyFile  As Object
    Set fso = CreateObject("Scripting.FileSystemObject")
    Set MyFile = fso.CreateTextFile(lk, True, True)
    MyFile.Write outem
    MyFile.Open
'    MyFile.Close
    Set fso = Nothing
End Sub
Message 9 of 9
MakCADD
Use with a userform, combobox and two command buttons
Private Sub CommandButton1_Click()
'set currnet layer
ThisDrawing.ActiveLayout = ThisDrawing.Layouts(ComboBox1.Value)
'you can access other layouts using
    For C = 0 To ComboBox1.ListCount - 1
    If C <> ComboBox1.ListIndex Then ThisDrawing.Layouts(ComboBox1.List(C)).Delete
    Next C
Call update_CMBBox
End Sub
Private Sub CommandButton2_Click()
Unload Me
End Sub
Private Sub UserForm_Initialize()
Dim L As Integer
UserForm1.Caption = "Set Current Layout"
CommandButton1.Caption = "OK"
CommandButton2.Caption = "CANCEL"
'Adding the layout names to list except Model
Call update_CMBBox
End Sub
Sub update_CMBBox()
ComboBox1.Clear
Dim Lay As AcadLayout
For i = 1 To ThisDrawing.Layouts.Count - 1
    For Each Lay In ThisDrawing.Layouts
        If Lay.TabOrder = i Then
        ComboBox1.AddItem Lay.Name
        End If
    Next
Next
ComboBox1.Value = ThisDrawing.ActiveLayout.Name
End Sub
