Sorting Arrays
Sorting Arrays
Sorting Arrays
Hi to All,
I need to sort the contents of a (2) dimensional (table) array before
sending the data to an Excel spreadsheet. The array has (4) columns and may
hold several thousand rows. I need to sort all the rows by the first column
and then by the second column. Any advise on how to tackle this problem? I
was also wondering if I can programatically sort the data in the spreadsheet
through VBA. If so, which way is better, sort the data before sending it to
Excel or sort the data in Excel programatically.
You could do a test to see which way is better, but I think it's going to
depend on how your sorting code is structured and how long the arrays are.
Here's how to do it in the spreadsheet; you might do a search for 'sorting
algorithm', or something like that on google to see what the code might look
like.
Dim sRange As String
Dim i As Long
i = 1000 'this is your ubound of array, or maximum row number in
spreadsheet
sRange = CStr(1) & ":" & CStr(i + 1)
Rows(sRange).Sort _
Key1:=Cells(1, 1), _
Order1:=xlAscending, _
Header:=xlGuess, _
OrderCustom:=1, _
MatchCase:=False, _
Orientation:=xlTopToBottom
Kevin
"Gordon Reichhardt" wrote in message
news:863948D2509F1D7D91FB31F891D80FEA@in.WebX.maYIadrTaRb...
> Hi to All,
may
column
I
spreadsheet
to
FWIW,
I've heard of sorting arrays by adding them to a listbox, letting VB sort
them, and then retrieving them. Listboxes have a property to auto-sort
added items. I don't know if this could be made to work with 4 columns or
not, or if it will sort your data types properly, but here's some links.
http://groups.google.com/groups?q=vb+listbox+sort&ie=UTF-8&oe=UTF-8&hl=en
James
> Hi to All,
may
column
I
spreadsheet
to
Thanx Kevin,
I've implemented your code in my project and it works but the code only
sorts the first column. I need to have the data sorted by the first column
and then by the second column. How do I do this?
"Kevin Terry" wrote in message
news:F8B1A7342B7418158A5F667DBBED26D5@in.WebX.maYIadrTaRb...
look
> like.
> Dim i As Long
> spreadsheet
> Rows(sRange).Sort _
> Header:=xlGuess, _
> OrderCustom:=1, _
> MatchCase:=False, _
> Kevin
> > Hi to All,
before
> may
> column
problem?
> I
> spreadsheet
it
> to
Never mind, I figured it out. Thanx again for your help.
news:AD725FD2B7433AD14D55E89D6AF487B8@in.WebX.maYIadrTaRb...
> Thanx Kevin,
column
to
are.
'sorting
> look
> > like.
> > Dim i As Long
> > spreadsheet
> > Rows(sRange).Sort _
> > Header:=xlGuess, _
> > OrderCustom:=1, _
> > MatchCase:=False, _
> > Kevin
> > > Hi to All,
> before
and
> > may
> > column
> problem?
> > I
> > spreadsheet
> it
> > to
James,
I think that's only for VB listboxes - not VBA ones.
Kevin
"James Belshan" wrote in message
news:D00FD642FD3AC622974B01F64FF7256D@in.WebX.maYIadrTaRb...
> FWIW,
> James
> > Hi to All,
before
> may
> column
problem?
> I
> spreadsheet
it
> to
I use the listview control to tremendous success. It has sorting properties and alot of other nice features (listbox just looks to 'DCL' -- former 'lisper'). HTH Lanny
