forms in vba
forms in vba
Message 1 of 10
forms in vba
I create an vba program that do some action calls a user form, I put data
in it. And the program should finnishe.
But my program stops after excecuting the form.
Next question.
How can I get variabels (DIM) to the form and back.
Thanks a lot
Replies (9)
Message 2 of 10
1. Difficult to help you without seeing what you are doing.
How are you calling the form?
How are you leaving the form?
Show some code.
2. Add a PUBLIC variable in the module section (before any SUB's or
FUNCTION's) of the THISDRAWING code module (e.g. Public strSomeText As
String), then refer to it in the form code via the THISDRAWING object (e.g.
ThisDrawing.strSomeText).
John Goodfellow
irtfnm
use john at goodfellowassoc dot com
"gvanaco" wrote in message
news:5F6E8DC3EAB881994EAD6F370E7A27AD@in.WebX.maYIadrTaRb...
> Next question.
> Thanks a lot
Message 3 of 10
The program is a connection to a excel tabel.
I would selecting one sheet from the excel file.
It works for displaying the sheetnames but I do not nowing how I should
selecting.
"John Goodfellow" wrote in
news:A31531C764B4BE301AB7606C0E963809@in.WebX.maYIadrTaRb:
> Show some code.
> (e.g. ThisDrawing.strSomeText).
> John Goodfellow
> irtfnm
>> data in it. And the program should finnishe.
>> Next question.
>> Thanks a lot
Message 4 of 10
I try a second time
Message 5 of 10
In your module, declare a global variable (example: sSheetName). In the
button click event, transfer the list box value to that variable:
in module:
public sSheetName as string
in form:
Private Sub CommandButton1_Click()
sSheetName = ListBox1.Value
Unload Me
'now call some other routine, or run other code here
End Sub
Kevin
news:9B5C3EF2F361BAE85F7FB4143EAC83A2@in.WebX.maYIadrTaRb...
> selecting.
> > Show some code.
> > John Goodfellow
> > irtfnm
> >> Next question.
> >> Thanks a lot
Message 6 of 10
and if the form disapere, my initial program stays running?
thanks for the help
"Kevin Terry" wrote in
news:607D83D4FDE2C6C9EFAE30BF533D0201@in.WebX.maYIadrTaRb:
the
> in module:
> in form:
> Unload Me
> End Sub
> Kevin
should
>> selecting.
>> > Show some code.
As
object
>> > John Goodfellow
>> > irtfnm
put
>> >> Next question.
>> >> Thanks a lot
Message 7 of 10
That depends on what you want the program to do. You can run code without a
form on screen, and also can continue to run after the form is dismissed.
In a code module:
Public Sub test1()
UserForm1.Show
'now any code in the form's initialize event will run
'press button on form to dismiss form,
'code in button click event runs - make sure there's a Hide statement
for the form in this event
Unload UserForm1
'now you can run some code here, depending on user's input on form
End Sub
Kevin
news:3685FC535499E4DB77DB17AB1EC6B9D9@in.WebX.maYIadrTaRb...
> thanks for the help
> the
> > in module:
> > in form:
> > Unload Me
> > End Sub
> > Kevin
> should
> >> selecting.
> >> > Show some code.
> As
> object
> >> > John Goodfellow
> >> > irtfnm
> put
> >> >> Next question.
> >> >> Thanks a lot
Message 8 of 10
Do you have a little and easy working axample of it where:
in a module the program is working
after an proces there rise a form, tath make a choise
the form dissepear
the program continu.
Maby you have something, so I can see how it's work,
Thanks a lot
news:8ACEBBEA6077C3AA228B2A10FB51521A@in.WebX.maYIadrTaRb:
> without a form on screen, and also can continue to run after the form
> is dismissed.
> In a code module:
> Public Sub test1()
> UserForm1.Show
> statement
> Unload UserForm1
> End Sub
> Kevin
Message 9 of 10
Look in the "sample" folder in the ACADCAD directory, there are a few there
with readme files explaining what they do and how they do it.
Murph
news:3105FEA03D7B9C63E3EE221103276342@in.WebX.maYIadrTaRb...
> the form dissepear
> Thanks a lot
> > is dismissed.
> > In a code module:
> > Public Sub test1()
> > UserForm1.Show
> > statement
> > Unload UserForm1
> > End Sub
> > Kevin
Message 10 of 10
gvanaco wrote in
news:5F6E8DC3EAB881994EAD6F370E7A27AD@in.WebX.maYIadrTaRb:
> Next question.
> Thanks a lot
for my second question I have found the error.
A variable I have to declarate it in the option explicit.
Then stay's my variable working in different sub's
thanks
