This seems to work fine...For testing I just
change textstring to it's order. Needs some
refactoring, I'll leave that to you.
Add a reference to "Microsoft Scripting Runtime"
[code]
Option Explicit
Const dictKey = 1
Const dictItem = 2
Sub Stub()
Dim SS As AcadSelectionSet
Dim filType(0) As Integer
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
Set SS = SSAdd("test")
SS.SelectOnScreen filType, filData
Dim tempDict As New Scripting.Dictionary
Dim finalDict As New Scripting.Dictionary
Dim dict As Scripting.Dictionary
Set dict = TextSSToDictionary(SS)
SortDictionary dict, dictItem, True
Dim i As Integer, j As Integer
Dim txt As AcadText
'TODO refactor...
For i = 0 To dict.count - 1
Set txt = ThisDrawing.HandleToObject(dict.Keys(i))
tempDict.Add dict.Keys(i), txt.InsertionPoint(0)
If i <> dict.count - 1 Then
If dict.Items(i) <> dict.Items(i + 1) Then
SortDictionary tempDict, dictItem
For j = 0 To tempDict.count - 1
finalDict.Add tempDict.Keys(j), tempDict.Items(j)
Next j
tempDict.RemoveAll
End If
End If
Next i
'add last group
Next j
'TODO refactor...
'TEST
For i = 0 To finalDict.count - 1
Set txt = ThisDrawing.HandleToObject(finalDict.Keys(i))
txt.TextString = i
Next i
'TEST
Call SSRemove("test")
End Sub
Function TextSSToDictionary(inSS As AcadSelectionSet) As
Dim i As Integer
Dim txt As AcadText
Dim dict As New Scripting.Dictionary
For i = 0 To inSS.count - 1
Set txt = inSS(i)
dict.Add txt.Handle, txt.InsertionPoint(1)
Next i
Set TextSSToDictionary = dict
End Function
Function SSAdd(inName As String) As AcadSelectionSet
On Error Resume Next
With ThisDrawing
.SelectionSets(inName).Delete
Set SSAdd = .SelectionSets.Add(inName)
End With
End Function
Sub SSRemove(inName As String)
ThisDrawing.SelectionSets(inName).Delete
End Sub
Function SortDictionary(objDict, intSort, Optional decending As Boolean)
' declare our variables
Dim strDict()
Dim objKey
Dim strKey, strItem
Dim X, Y, Z
' get the dictionary count
Z = objDict.count
' we need more than one item to warrant sorting
If Z > 1 Then
' create an array to store dictionary information
ReDim strDict(Z, 2)
X = 0
' populate the string array
For Each objKey In objDict
strDict(X, dictKey) = CStr(objKey)
strDict(X, dictItem) = CStr(objDict(objKey))
X = X + 1
Next
' perform a a shell sort of the string array
For X = 0 To (Z - 2)
For Y = X To (Z - 1)
If StrComp(strDict(X, intSort), strDict(Y, intSort), vbTextCompare)
> 0 Then
strKey = strDict(X, dictKey)
strItem = strDict(X, dictItem)
strDict(X, dictKey) = strDict(Y, dictKey)
strDict(X, dictItem) = strDict(Y, dictItem)
strDict(Y, dictKey) = strKey
strDict(Y, dictItem) = strItem
End If
Next
Next
' erase the contents of the dictionary object
objDict.RemoveAll
' repopulate the dictionary with the sorted information
Dim lower As Double: lower = 0
Dim upper As Double: upper = (Z - 1)
Dim stp As Integer: stp = 1
'accending or decending
Select Case decending
Case True
lower = upper
upper = 0
stp = -1
End Select
For X = lower To upper Step stp
objDict.Add strDict(X, dictKey), CDbl(strDict(X, dictItem))
Next
End If
End Function
[/code]
"Dan"
wrote in message
news:[email protected]...
example of individual text objects on screen
1 2 3
4 5 6
7 8 9
User selects objects
(objects are place into a selection set, then object in selection set are
placed into an array)
array order might look like this:
2,4,7,8,0,1,5,3,6,9
how do I sort the array by the text objects X,Y insertionpoint values:
1,4,7,2,5,8,3,6,9 (outcome desired)
