Sort an array of text objects Asc by their X and Y insertion point values
Message 1 of 42
example of individual text objects on screen
1 2 3
4 5 6
7 8 9
User selects objects
(objects are place into a selection set, then object in selection set are
placed into an array)
array order might look like this:
2,4,7,8,0,1,5,3,6,9
how do I sort the array by the text objects X,Y insertionpoint values:
1,4,7,2,5,8,3,6,9 (outcome desired)
Replies (41)
Message 2 of 42
Sort the objects by the Y coordinates using any sort algorithm then sort them by the X coordinates using any stable sort algorithm.
Message 3 of 42
Yup, looks good on paper. I haven't figured out how to create/use the sort
algorithms yet.
I did find a good site with many Sorting algorithms here:
http://www.xtremevbtalk.com/showthread.php?t=78889
These might help anyone in the future researching sorting.
Dan
wrote in message news:[email protected]...
Message 4 of 42
Do you need to sort the TextObjects or only the TextString.?How are you planing to sort them, X left or right and Y up or down? If possible what are you trying to accomplish?
Message 5 of 42
Not sure how to clarify more, I will try.
I need to sort Text Object in the following order:
Text X coordinate Ascending
then sort Text by Y coordinate Descending
start:
1 2 3
4 5 6
7 8 9
SSet order: 2,4,7,8,0,1,5,3,6,9
Sorted order:1,4,7,2,5,8,3,6,9
I just want the order to look like it reads. Text Top to bottom, then left
to right.
Thanks again,
Dan
Message 6 of 42
[code]
Sub Stub()
Dim SS As AcadSelectionSet
Dim filType(0) As Integer
Dim filData(0)
'filter data for TEXT
filType(0) = 0
filData(0) = "TEXT"
Set SS = SSAdd("test")
SS.SelectOnScreen filType, filData
Dim coll As New Collection
Dim min, max
Dim ent As AcadEntity
Dim i As Integer
'Iterate SS and add X of lower bound box point
'as collection item and handle of entity as key.
For i = 0 To SS.Count - 1
Set ent = SS(i)
ent.GetBoundingBox min, max
coll.Add min(0), ent.Handle
Next i
'call sort method by Christian d'Heureuse (www.source-code.biz)
'something lighter will do(bubblesort), this is first I found.
Set coll = SortCollection(coll)
'do the same for min Y points...
Call SSRemove("test")
End Sub
Function SSAdd(inName As String) As AcadSelectionSet
On Error Resume Next
With ThisDrawing
.SelectionSets(inName).Delete
Set SSAdd = .SelectionSets.Add(inName)
End With
End Function
Sub SSRemove(inName As String)
ThisDrawing.SelectionSets(inName).Delete
End Sub
' This routine uses the "heap sort" algorithm to sort a VB collection.
' It returns the sorted collection.
' Author: Christian d'Heureuse (www.source-code.biz)
Public Function SortCollection(ByVal c As Collection) As Collection
Dim n As Long: n = c.Count
If n = 0 Then Set SortCollection = New Collection: Exit Function
ReDim Index(0 To n - 1) As Long ' allocate index array
Dim i As Long, m As Long
For i = 0 To n - 1: Index(i) = i + 1: Next ' fill index array
For i = n \ 2 - 1 To 0 Step -1 ' generate ordered
heap
Heapify c, Index, i, n
Next
For m = n To 2 Step -1 ' sort the index array
Exchange Index, 0, m - 1 ' move highest element
to top
Heapify c, Index, 0, m - 1
Next
Dim c2 As New Collection
For i = 0 To n - 1: c2.Add c.Item(Index(i)): Next ' fill output
collection
Set SortCollection = c2
End Function
Private Sub Heapify(ByVal c As Collection, Index() As Long, ByVal i1 As
Long, ByVal n As Long)
' Heap order rule: a >= a[2*i+1] and a >= a[2*i+2]
Dim nDiv2 As Long: nDiv2 = n \ 2
Dim i As Long: i = i1
Do While i < nDiv2
Dim k As Long: k = 2 * i + 1
If k + 1 < n Then
If c.Item(Index(k)) < c.Item(Index(k + 1)) Then k = k + 1
End If
If c.Item(Index(i)) >= c.Item(Index(k)) Then Exit Do
Exchange Index, i, k
i = k
Loop
End Sub
Private Sub Exchange(Index() As Long, ByVal i As Long, ByVal j As Long)
Dim Temp As Long: Temp = Index(i)
Index(i) = Index(j)
Index(j) = Temp
End Sub
[/code]
"Dan" wrote in message
start:
1 2 3
4 5 6
7 8 9
to right.
Thanks again,
Dan
Message 7 of 42
you have a few lines with word wrap in there...
"Paul Richardson" wrote in message
[code]
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
Dim min, max
Dim i As Integer
Set ent = SS(i)
Next i
End Sub
With ThisDrawing
End With
End Function
End Sub
heap
Next
to top
Next
collection
End Function
Do While i < nDiv2
If k + 1 < n Then
End If
i = k
Loop
End Sub
Index(i) = Index(j)
Index(j) = Temp
End Sub
[/code]
start:
1 2 3
4 5 6
7 8 9
to right.
Thanks again,
Dan
Message 8 of 42
Wow, this is complex! I am looking into it now...
[code]
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
Dim min, max
Dim i As Integer
Set ent = SS(i)
Next i
End Sub
With ThisDrawing
End With
End Function
End Sub
heap
Next
to top
Next
collection
End Function
Do While i < nDiv2
If k + 1 < n Then
End If
i = k
Loop
End Sub
Index(i) = Index(j)
Index(j) = Temp
End Sub
[/code]
start:
1 2 3
4 5 6
7 8 9
to right.
Thanks again,
Dan
Message 9 of 42
This is what I have so far. I am attaching a sample drawing to help make my
intentions clear. Thank you all so much. This is indeed more challenging
than I originally thought.
[code]
Option Explicit
Sub FieldsToTableFinal()
Dim oSsets As AcadSelectionSets
Dim oSset As AcadSelectionSet
Dim oTable As AcadTable
Dim oText As AcadText
Dim j, k, l, m As Long
Dim i, n As Integer
Dim ftype(0) As Integer
Dim fData(0) As Variant
Dim insPt As Variant
Dim tmpStr As String
Dim basePnt As Variant
Dim celltxtchk As String
Dim oMText As AcadMText
Dim SSetSort As Variant
ftype(0) = 0: fData(0) = "TEXT"
ThisDrawing.SelectionSets.Item("FieldsToTable").Delete
Set oSset = ThisDrawing.SelectionSets.Add("FieldsToTable")
On Error GoTo ErrMsg
oSset.SelectOnScreen 'I need to figure out filtering for moth Text &
mText
'I am stuck on this section
For i = 0 To oSset.Count - 1
Set SSetSort(i) = oSset.Item(i)
'SORT Code here?
'I need to figure out how to resort this array, and place the
correct order
'back into a SS to use
Next
i = oSset.Count
ThisDrawing.Utility.GetEntity oTable, basePnt, "Select Table to
fill-out:"
k = oTable.Columns
If k <> 2 And k <> 5 Then
Exit Sub
End If
j = i \ k
l = 0
n = 0
For l = 0 To k - 1
For m = 3 To j + 2
celltxtchk = oSset.Item(n).ObjectName
If celltxtchk = "AcDbMText" Then
Set oMText = oSset.Item(n)
MsgBox oMText.TextString
MsgBox oMText.InsertionPoint(1)
tmpStr = CStr(oMText.ObjectID)
End If
If celltxtchk = "AcDbText" Then
Set oText = oSset.Item(n)
MsgBox oText.TextString
MsgBox oText.InsertionPoint(1)
tmpStr = CStr(oText.ObjectID)
End If
tmpStr = "%<\AcObjProp Object(%<\_ObjId " & tmpStr & _
">%).TextString \f " & "" & "%bl2" & "" & ">%"
oTable.SetText m, l, tmpStr
n = n + 1
oTable.Update
Next
Next
oSset.Clear
oSset.Delete
Set oSset = Nothing
Set oSsets = Nothing
Set oTable = Nothing
Exit Sub
ErrMsg:
MsgBox Err.Description
End Sub
[/code]
Dan
[code]
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
Dim min, max
Dim i As Integer
Set ent = SS(i)
Next i
End Sub
With ThisDrawing
End With
End Function
End Sub
heap
Next
to top
Next
collection
End Function
Do While i < nDiv2
If k + 1 < n Then
End If
i = k
Loop
End Sub
Index(i) = Index(j)
Index(j) = Temp
End Sub
[/code]
start:
1 2 3
4 5 6
7 8 9
to right.
Thanks again,
Dan
Message 10 of 42
a Dictionary will work better...I'll write it up hold on.
[code]
Option Explicit
Dim i, n As Integer
Dim basePnt A
s Variant
mText
'SORT Code here?
correct order
Next
i = oSset.Count
fill-out:"
k = oTable.Columns
Exit Sub
End If
j = i \ k
l = 0
n = 0
For l = 0 To k - 1
For m = 3 To j + 2
ObjectName
End If
End If
n = n + 1
oTable.Update
Next
Next
oSset.Clear
oSset.Delete
Set oSset = Nothing
Exit Sub
ErrMsg:
End Sub
[/code]
Dan
"Dan" wrote
in message
[code]
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
Dim min, max
Dim i As Integer
Set ent = SS(i)
Next i
End Sub
With ThisDrawing
End With
End Function
End Sub
For i = n
heap
Next
to top
Next
collection
End Function
Do While i < nDiv2
If k + 1 < n Then
End If
i = k
Loop
End Sub
P
Index(i) = Index(j)
Index(j) = Temp
End Sub
[/code]
start:
1 2 3
4 5 6
7 8 9
SSet or
to right.
Thanks again,
Dan
Message 11 of 42
I really do not understand most of what is happening in the heap sort
method, but I will learn it. I appreciate all the help. This code is much
more advanced than I have ever written. I was hoping to learn some new
tricks, but found a whole new area of coding I can explore.
Thanks again,
Dan
Message 12 of 42
The nice thing is you don't have to know what is going in the sort
methods, just that it returns a sorted something for now...
That being said, here is code to add the x and y insertion coords to a 2d
array,
and then relate a sorted 2d array of insertion points back to entities in
your selection set.
You need a function to sort 2d arrays...google "Sort 2d coordinates" or such
[code]
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
'create 2d array (x,y) same size as your SS
ReDim coords(SS.Count - 1, 1)
Dim txtEnt As AcadText
Dim i As Integer
Set txtEnt = SS(i)
coords(i, 0) = txtEnt.InsertionPoint(0)
coords(i, 1) = txtEnt.InsertionPoint(1)
Next i
'now you have an array of 2d coordinates, do
'a google for a function that will sort 2d
'coordinate arrays.
Dim j As Integer
'relate sorted coords back to your SS ents
'doesn't consider duplicate insertion points
For i = LBound(coords) To UBound(coords)
For j = 0 To SS.Count - 1
Set txtEnt = SS(j)
If txtEnt.InsertionPoint(0) = coords(i, 0) And _
txtEnt.InsertionPoint(1) = coords(i, 1) Then
'add text value to your table
Exit For
End If
Next j
Next i
End Sub
With ThisDrawing
End With
End Function
End Sub
[/code]
Thanks again,
Dan
Message 13 of 42
Thank you so much. I will attemp to incorporate this new code and
information into my routine.
Thanks again for all your help. When complete, this will save a tremendous
amount of rework.
Dan
array,
your selection set.
[code]
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
Dim i As Integer
Set txtEnt = SS(i)
Next i
'coordinate arrays.
Dim j As Integer
Set txtEnt = SS(j)
Exit For
End If
Next j
Next i
End Sub
With ThisDrawing
End With
End Function
End Sub
[/code]
Thanks again,
Dan
Message 14 of 42
Here ya go...Very simple I just subtracted the Y insertion
point from the X insertion point and used the difference to
sort.
[code]
Option Explicit
Const dictKey = 1
Const dictItem = 2
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
Dim Dict As Scripting.Dictionary
Set Dict = SSToDictionary(SS)
SortDictionary Dict, dictItem
'iterate sorted collection use Dict.Key to get
'the ents.
Dim i As Integer
Dim txt As AcadText
For i = 0 To Dict.Count - 1
Set txt = ThisDrawing.HandleToObject(Dict.Keys(i))
txt.TextString = i 'test only remove
'add to your table
Next i
End Sub
'Add ss ents to Dictionary using ent.handle as key and ents
'(xIns - yIns) as item.
Function SSToDictionary(inSS As AcadSelectionSet) As Scripting.Dictionary
Dim i As Integer
Dim txt As AcadText
Dim Dict As New Scripting.Dictionary
For i = 0 To inSS.Count - 1
Set txt = inSS(i)
Dict.Add txt.Handle, _
(VBA.Round((CStr(txt.InsertionPoint(0) - txt.InsertionPoint(1))), 2))
Next i
Set SSToDictionary = Dict
End Function
With ThisDrawing
End With
End Function
End Sub
'Modified MSDN Function
Function SortDictionary(objDict, intSort)
' declare our variables
Dim Dict()
Dim objKey
Dim strKey, strItem
Dim X, Y, Z
' get the dictionary count
Z = objDict.Count
' we need more than one item to warrant sorting
If Z > 1 Then
' create an array to store dictionary information
ReDim Dict(Z, 2)
X = 0
' populate the array
For Each objKey In objDict
Dict(X, dictKey) = (objKey)
Dict(X, dictItem) = (objDict(objKey))
X = X + 1
Next
' perform a a shell sort of the string array
For X = 0 To (Z - 2)
For Y = X To (Z - 1)
If Dict(X, intSort) > Dict(Y, intSort) Then
strKey = Dict(X, dictKey)
strItem = Dict(X, dictItem)
Dict(X, dictKey) = Dict(Y, dictKey)
Dict(X, dictItem) = Dict(Y, dictItem)
Dict(Y, dictKey) = strKey
Dict(Y, dictItem) = strItem
End If
Next
Next
' erase the contents of the dictionary object
objDict.RemoveAll
' repopulate the dictionary with the sorted information
For X = 0 To (Z - 1)
objDict.Add Dict(X, dictKey), Dict(X, dictItem)
Next
End If
End Function
[/code]
amount of rework.
Dan
array,
your selection set.
[code]
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
Dim i As Integer
Set txtEnt = SS(i)
Next i
'coordinate arrays.
Dim j As Integer
Set txtEnt = SS(j)
Exit For
End If
Next j
Next i
End Sub
With ThisDrawing
End With
End Function
End Sub
[/code]
Thanks again,
Dan
Message 15 of 42
you need to reference the "microsoft scripting runtime" but the
idea doesn't work anyway...I should have tired it first..
sort.
[code]
Option Explicit
Const dictKey = 1
Const dictItem = 2
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
'the ents.
Dim i As Integer
Dim txt As AcadText
'add to your table
Next i
End Sub
Dim i As Integer
Dim txt As AcadText
Set txt = inSS(i)
Next i
End Function
With ThisDrawing
End With
End Function
End Sub
Dim Dict()
Dim objKey
Dim strKey, strItem
Dim X, Y, Z
Z = objDict.Count
If Z > 1 Then
ReDim Dict(Z, 2)
X = 0
X = X + 1
Next
End If
Next
Next
objDict.RemoveAll
Next
End If
End Function
[/code]
amount of rework.
Dan
array,
your selection set.
[code]
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
Dim i As Integer
Set txtEnt = SS(i)
Next i
'coordinate arrays.
Dim j As Integer
Set txtEnt = SS(j)
Exit For
End If
Next j
Next i
End Sub
With ThisDrawing
End With
End Function
End Sub
[/code]
Thanks again,
Dan
Message 16 of 42
check out this link, it's in c but should give you
some ideas...
http://www.cedarcreek.umn.edu/tools/declare/sort.d.pdf
sort.
[code]
Option Explicit
Const dictKey = 1
Const dictItem = 2
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
'the ents.
Dim i As Integer
Dim txt As AcadText
'add to your table
Next i
End Sub
Dim i As Integer
Dim txt As AcadText
Set txt = inSS(i)
Next i
End Function
With ThisDrawing
End With
End Function
End Sub
Dim Dict()
Dim objKey
Dim strKey, strItem
Dim X, Y, Z
Z = objDict.Count
If Z > 1 Then
ReDim Dict(Z, 2)
X = 0
X = X + 1
Next
End If
Next
Next
objDict.RemoveAll
Next
End If
End Function
[/code]
amount of rework.
Dan
array,
your selection set.
[code]
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
Dim i As Integer
Set txtEnt = SS(i)
Next i
'coordinate arrays.
Dim j As Integer
Set txtEnt = SS(j)
Exit For
End If
Next j
Next i
End Sub
With ThisDrawing
End With
End Function
End Sub
[/code]
Thanks again,
Dan
Message 17 of 42
Thank you, I will try to read more. I am a newbie at VBA, and this sorting
algorithun code is really unfamiliar to me.
some ideas...
sort.
[code]
Option Explicit
Const dictKey = 1
Const dictItem = 2
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
'the ents.
Dim i As Integer
Dim txt As AcadText
'add to your table
Next i
End Sub
Dim i As Integer
Dim txt As AcadText
Set txt = inSS(i)
Next i
End Function
With ThisDrawing
End With
End Function
End Sub
Dim Dict()
Dim objKey
Dim strKey, strItem
Dim X, Y, Z
Z = objDict.Count
If Z > 1 Then
ReDim Dict(Z, 2)
X = 0
X = X + 1
Next
End If
Next
Next
objDict.RemoveAll
Next
End If
End Function
[/code]
amount of rework.
Dan
array,
your selection set.
[code]
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
Dim i As Integer
Set txtEnt = SS(i)
Next i
'coordinate arrays.
Dim j As Integer
Set txtEnt = SS(j)
Exit For
End If
Next j
Next i
End Sub
With ThisDrawing
End With
End Function
End Sub
[/code]
Thanks again,
Dan
Message 18 of 42
Did you have an opportunity to view my example drawing? I have 1000's of
files with this configuration, I am trying to update.
Fatty was kind enough to assist me with the initial code, but I am still
hung up on the sorting. Did you have an opportunity to run the existing
code? If you select the text object individually, in order, the code works
great, but when I have 164 entities, this will be to tedious, and time
consuming.
Once again, I appreciate your time and efforts.
Dan
some ideas...
sort.
[code]
Option Explicit
Const dictKey = 1
Const dictItem = 2
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
'the ents.
Dim i As Integer
Dim txt As AcadText
'add to your table
Next i
End Sub
Dim i As Integer
Dim txt As AcadText
Set txt = inSS(i)
Next i
End Function
With ThisDrawing
End With
End Function
End Sub
Dim Dict()
Dim objKey
Dim strKey, strItem
Dim X, Y, Z
Z = objDict.Count
If Z > 1 Then
ReDim Dict(Z, 2)
X = 0
X = X + 1
Next
End If
Next
Next
objDict.RemoveAll
Next
End If
End Function
[/code]
amount of rework.
Dan
array,
your selection set.
[code]
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
Dim i As Integer
Set txtEnt = SS(i)
Next i
'coordinate arrays.
Dim j As Integer
Set txtEnt = SS(j)
Exit For
End If
Next j
Next i
End Sub
With ThisDrawing
End With
End Function
End Sub
[/code]
Thanks again,
Dan
Message 19 of 42
I saw the drawing. I gave you code to sort via dictionary, or collection.
You need to figure out the double sort; most of us are long past the
recursion
semester... your turn.:) Not that recursion is the only way to go.
How about an easy way out. Use Excel model to sort by Column1(x) and
then by Column2(Y).
Use the idea I sent creating a multiple dimension array...
ReDim arr(ss.Count - 1, 2)
(X Y Handle)
Now let Excel sort for you and then use the handle (column3) to get back to
your
entity.
consuming.
Dan
some ideas...
sort.
[code]
Option Explicit
Const dictKey = 1
Const dictItem = 2
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
'the ents.
Dim i As Integer
Dim txt As AcadText
'add to your table
Next i
End Sub
Dim i As Integer
Dim txt As AcadText
Set txt = inSS(i)
Next i
End Function
With ThisDrawing
End With
End Function
End Sub
Dim Dict()
Dim objKey
Dim strKey, strItem
Dim X, Y, Z
Z = objDict.Count
If Z > 1 Then
ReDim Dict(Z, 2)
X = 0
X = X + 1
Next
End If
Next
Next
objDict.RemoveAll
Next
End If
End Function
[/code]
amount of rework.
Dan
array,
your selection set.
[code]
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
Dim i As Integer
Set txtEnt = SS(i)
Next i
'coordinate arrays.
Dim j As Integer
Set txtEnt = SS(j)
Exit For
End If
Next j
Next i
End Sub
With ThisDrawing
End With
End Function
End Sub
[/code]
Thanks again,
Dan
Message 20 of 42
Thank you for your efforts and time. I appreciate it.
I do not understand your examples to begin with, so it is hard to use ideas
and principles from the various code you have provided.
I am self taught at VBA, and rarely given any time to code new routines with
my drafting schedule.
I can and do respect your intentions to help, and teach me, but I am really
clueless about working with arrays.
I have thought about the easy way out by using Excel. Wouldn't it be much
slower?
What did you mean by "use the handle (column3) to get back to your entity."?
Is this the object ID?
BTW, if you use my current code, do you have a clue why the table updates so
slowly?
I am reading up on arrays right now. The developer help isn't much help in
this area that I can see.
Dan
recursion
then by Column2(Y).
(X Y Handle)
your
entity.
consuming.
Dan
some ideas...
sort.
[code]
Option Explicit
Const dictKey = 1
Const dictItem = 2
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
'the ents.
Dim i As Integer
Dim txt As AcadText
'add to your table
Next i
End Sub
Dim i As Integer
Dim txt As AcadText
Set txt = inSS(i)
Next i
End Function
With ThisDrawing
End With
End Function
End Sub
Dim Dict()
Dim objKey
Dim strKey, strItem
Dim X, Y, Z
Z = objDict.Count
If Z > 1 Then
ReDim Dict(Z, 2)
X = 0
X = X + 1
Next
End If
Next
Next
objDict.RemoveAll
Next
End If
End Function
[/code]
amount of rework.
Dan
array,
your selection set.
[code]
Sub Stub()
Dim filData(0)
filType(0) = 0
filData(0) = "TEXT"
Dim i As Integer
Set txtEnt = SS(i)
Next i
'coordinate arrays.
Dim j As Integer
Set txtEnt = SS(j)
Exit For
End If
Next j
Next i
End Sub
With ThisDrawing
End With
End Function
End Sub
[/code]
Thanks again,
Dan
