Slide OCX
Slide OCX
Slide OCX
Has anyone had success using the slide.ocx with acad 2000i?
I am using 2000i and map 2000i without any problems with slide.ocx...
"Bill Brookman" wrote in message
news:ef6b68e.0@WebX.SaUCah8kaAW...
Thanks for your reply,
I'm using slide.ocx version 3.1.0.1 with a2ki and windows 2000. I can
display a slide on a form, but if I try to use the slides double click
event, it locks up autocad. This also happens with the acad view ocx,
however the drawingviewer ocx works fine. I have registered all the ocx's.
Do I need to reference anything else?
This worked fine with acad 2000.
Any thoughts would be appreciated.
"amy" wrote in message
news:092FE41E8F8BCEBE87044FE4D52DA384@in.WebX.SaUCah8kaAW...
I use V 4.5 of Slide.ocx. I got this version from AutoCAD Developer Network
(ADN) so I am not sure if I can email it to you. I am sure if search around
you can get the updated version.
news:3D49CF49306476C833B881F0DCA26E2D@in.WebX.SaUCah8kaAW...
ocx's.
Do you know of any links to the slide.ocx. I've looked on autocad website
as well as the newsgroups, with no luck. I don't know why autodesk wouldn't
include this with the vba package. Does this ocx work with windows 2000? I
think that's the problem.
Any help would be greatly appreciated!
bill brookman
