Skip Corrupted File
Skip Corrupted File
sjmacad
Skip Corrupted File
sjmacad
I am using VB6 to open drawings. However, when it encounters a corrupted file, it displays following error:
"Run-time error '2145320823 (80210089)'
File xx_recover.dwg is corrupted and requires recovery" where xx is a file name.
The program quits after I press OK button.
Is there a way to catch the message before it is displayed so that I can skip the file and continue with the next file?
Any help will be appriciated.
sjm
arcticad
This was discussed here
http://discussion.autodesk.com/forums/thread.jspa?threadID=658684
(defun botsbuildbots() (botsbuildbots))
sjmacad
Thank you for the reply. I looked at the link you provided. The link talks about getting error opening any file. My situation is little different. I am trying to open all files in certain folder. If for any reason there is there is left over corrupted file from previous crash, the program cannot continue. These files generally saved with xxx_recover.dwg where xxx is the original file name. Of course I can check the file name ending with _recover. However, I am trying to avoid any other situation where corrupted file is encountered so I can skip it.
sjm
arcticad
You could check if the drawing was successfully saved to see if the file was viable.
Post one of your drawings and I'll check it to see if my assumption works.
