Getting Block Insetion point
Hey guys, a thread that's giving me headaches:
- I'm trying, using VBA, to get the insertion point of a block, in order to move it automatically.
I've already read all elements in model space, tested if they were blocks,
got block attibutes, but, when I try to retreive insertionpnt x, y and z,
I only read Zeros.
The next step would move this block to another X,Y position, but a simple "sendcommand MOVE" solves.
Could you please help me?
I can post code here if it would help.
Thx,
Hi thilab,
Posting your code would require less guessing and enable a far more
focussed answer.
Laurie Comerford
> I only read Zeros.
> Thx,
Hey Laurie, its already solved.
Check Code below:
Dim Ar As Variant, i As Long
Ar = Application.GetOpenFilename("Desenhos (*.dwg), *.dwg", , "Selecione o Arquivo dwg", MultiSelect:=True)
If TypeName(Ar) = "Boolean" Then Exit Sub
For t = LBound(Ar) To UBound(Ar)
caminho = Ar(t)
AutoCAD.Documents.Open (caminho)
AutoCAD.Visible = True
Set ThisDrawing = AutoCAD.ActiveDocument
For Each element In ThisDrawing.ModelSpace
If element.EntityType = 7 Then 'Check if its a block.
'Retrieve Insertion point
Var = element.InsertionPoint
MsgBox Var(0)
MsgBox Var(1)
arrayattributes = element.GetAttributes
For i = LBound(arrayattributes) To UBound(arrayattributes)
AttributesCoordinates = arrayattributes(i).InsertionPoint
MsgBox AttributesCoordinates(0)
MsgBox AttributesCoordinates(1)
Next
Next
AutoCAD.ActiveDocument.Close
Next t
Thanks a lot. Edited by: thilab on Apr 14, 2010 11:51 AM
Glad you are up and running.
However, instead of looping through every object in model space, you
should look at the filtering tools. You can create a "selectionset"
which contain nothing but "blockreferences" and then process those.
There have been dozens of examples posted here and there are also
examples in the help files.
You also might wish to check the block name, and also check if the
blocks you are processing also "haveattributes"
Regards
Laurie Comerford
> Check Code below:
> caminho = Ar(t)
> MsgBox Var(0)
> MsgBox Var(1)
> Next
> End If
> Next
> Next t
> Thanks a lot.
