Side Screen Menu
Side Screen Menu
Side Screen Menu
What's the VB code for turning on/off the Side Screen Menu in AutoCAD?
Thanks in advance.
AcadPreferencesDisplay.DisplayScreenMenu
wrote in message news:5409723@discussion.autodesk.com...
Thanks in advance.
Thank you for the code.
Would it give a 0 or 1 answer (like an on/off switch)?
It Boolean type (True/False). Since you do it in VB/VBA, you can also assign
it 0 or 1. VB/VBA treats non-zero value as True and zero as False.
wrote in message news:5411210@discussion.autodesk.com...
arcticad
Here is the same thing in Lisp in case you wondered.
(setq axDisplay (vla-Get-Display
(vla-Get-Preferences
(vlax-Get-Acad-Object))))
(vla-Put-DisplayScreenMenu axDisplay :vlax-True)
(defun botsbuildbots() (botsbuildbots))
