showing the ucsicon
showing the ucsicon
Message 1 of 8
showing the ucsicon
i am trying
thisdrawing.activeviewport.ucsiconon = true
and it does not show, why?
Replies (7)
Message 2 of 8
You need to add something like:
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
Don't think about that line of code very much or your head may explode.
Message 3 of 8
I am not quite sure what you mean by your last sentence. However, WHY do I have to do that? That is two lines of code now.
I used ThisDrawing.SendCommand("UCSICON ON ") instead. One line of code.
Andrew
Message 4 of 8
Then you're safe.
In order to get the viewport to show the change. Assigning a value to the .UCSIconOn property sets a bit somewhere but does nothing else. Assigning a value to the .ActiveViewport property causes that value and others to be read and the results displayed. This lets you change several things about a viewport without updating the display after each change.
Message 5 of 8
OK. But is there any benifit to me using this approach instead of the UCSICON one?
Message 6 of 8
There are almost always benefits to avoiding .SendCommand when possible.
Message 7 of 8
sgrya1
This seems to work:
Dim UCSIcon as boolean
If UCSIcon = True Then ThisDrawing.SetVariable "UCSIcon", 1
Message 8 of 8
that's an interesting tip, thanks!
