shell a .PPS file
shell a .PPS file
shell a .PPS file
Does anyone know how I can shell a PowerPoint pps file?
I am trying to run the pps from within AutoCAD.
Thanks in advance for your help
If you can guarantee the path of PowerPoint you can use the Shell function, but probably a more robust solution would be to use the Windows API function ShellExecute. This will open the specified file in its associated application (ie like double-clicking the pps file in Windows Explorer). That way it doesn't matter if PowerPoint is a different version or at different paths on different machines.
See Microsoft Knowledgebase Article Q148632 for more information and an example.
Regards
Wayne Ivory
IT Analyst Programmer
Wespine Industries Pty Ltd
This will work in a PGP file:
PPS, START POWERPNT "C:\junk\junk.pps",8,,
And this for a menu button:
^C^CSTART;POWERPNT "C:/junk/junk.pps";
HTH,
Kevin
"Nate Hunter" wrote in message
news:6E1A29E6138C54F6AA5FD35FB8579937@in.WebX.maYIadrTaRb...
