Print out the values of a PlotConfuration.
Hi
I'm need to print out the values of all the plotconfigurations properties
that is in a drawing.
Is there an easy way to do this?
Do properties have a numerical value to enable cycling through the
plotconfigurations?
Thanks in advance.
Dave F.
Are you talking about (i.e. the paper sizes for different printers) or
something else?
JR
"Dave F" wrote in message
news:9A3D8785028A393DB42C48C5399171F6@in.WebX.maYIadrTaRb...
> Hi
> plotconfigurations?
> Thanks in advance.
> Dave F.
Dave,
You have to know the names of the properties (such as Margins, CenterPlot,
etc) in order to access them. You can cut/paste from the help file if it
speeds things up.... But you *can* cycle through the PlotConfigurations
themselves. Here's a sample of just a couple of the properties.
Sub ListPlotConfigs()
Dim curPC As AcadPlotConfiguration
Dim width As Double, height As Double
' you can replace with .Layouts with .PlotConfigurations
For Each curPC In ThisDrawing.Layouts
MsgBox curPC.CanonicalMediaName, , _
curPC.Name & " -- Canon Media Name"
MsgBox IIf(curPC.CenterPlot, "Plot Centered", _
"Plot Not Centered"), , curPC.Name & " -- Center Plot?"
MsgBox curPC.ConfigName, , _
curPC.Name & " -- Config Name"
curPC.GetPaperSize width, height
MsgBox Format$(width) & " x " & Format$(height), _
, curPC.Name & " -- Paper Size"
Next 'curPC
End Sub
