Setting Printing Path Problem
09:37 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Everyone,
I have created a VBA that sets the printing config paths (plotter, plot style...) and the application works and sets the paths correctly. The problem is even with the paths set correctly the plots and preview doesn't print or look correctly. It's like the pen table isn't being used where the plot should be all black it plots in degrees of gray. He is the kicker... to "fix" the problem I can simply open and Cancel the Opions dialog box without changing a thing, and the print or preview works perfect. Second, the "fix" works until I restart AutoCAD. We're using AutoCAD 2006, but had the same problem with 04.
I'm pretty new to VBA so please be detailed if you can help.
Thanks, Keith
Thanks, Keith
