setting multi text heights in an mtext object
a.kouchakzadeh
a.kouchakzadeh
Hello every one
Norman, Ed big thumbs up to you guys for yer previous help
I was wondering how is it possible to set multi text heights in a single MTEXT object?
This is the code I got:
Dim gn As AcadMText
Dim gx As String
Dim sx As String
Dim fx as string
Dim width As Integer
width = 23812
Dim Insp(2) As Double
Insp(0) = 38271
Insp(1) = 4460
sx = "\B\LThis is\b \l an example"
gx = vbNewLine & vbNewLine & "Hello \Bworld"
fx = sx & gx
Set gn = ThisDrawing.ModelSpace.AddMText(Insp, width, fx)
gn.Layer = "details"
gn.StyleName = "nsd-details txt"
gn.Height = 317
Problem is, I want sx text height to be 100
and gx to be 317
any ideas Norman and Ed?
PS: \B and \L makes the text Bold and Underlined. really cool
@Norman_Yuan
@Ed__Jobe
Norman_Yuan
AFAIK, there is no direct way (i.e. no API) to change the size (text height) of a portion of the text in a MTEXT. You would need to directly manipulate the markups of the MText content, which are not officially documented.
A way to try it is to manually edit a MTEXT, say, selecting portion of the MText, change it size/height, and then examine the content property in Properties window.
The picture below shows what the MText content would be when a portion of text in a MText is set to different height (much bigger, in this case):
As you can see, the MText's TextHeight property is 2.5, so text in the MText should be 2.5 high. The portion of text circled/selected is set to be 12 in height. That results in the Content property being updated with markup
{\H4.8x;[The Selected Text]}
As I said, the MText markups are not documented officially, but we can very well guess here that "\H4.8x;" here means the selected text in the curly bracket should change its height 4.8 times of the MText's TextHeight property (2.5 x 4.8 = 12).
So, in your case, you could try to manipulate the MText's Content property in similar way to achieve what you want.
HTH
Norman Yuan
Drive CAD With Code
a.kouchakzadeh
thanks for the reply sir.
my intention is creating a long MText (general notes for a plan), which is a gonna be alot of trouble if have to make this change manually.
another thing which came across my head is to create separated mtexts and at the end, make them a single m text object.
is this possible to merge different mtexts using VBA?
Norman_Yuan
I do not see there is way to "merge" 2 MText entities into one to achieve what you want to do.
However, if your goal is to set the text height of portion of the MText's text string, it is not difficult to do it in code as my previous reply suggested. I thought my previous reply has enough hint to write some code. Now that you asked again, here is the code sample of doing what I suggested:
Let's say, there is a MText entity, its text string contains "CONTENT", and I want to emphasize it by making its higher much higher than other. The MText's Height property is 2.5 (i.e. the default text height of the text string in the MText is 2.5). Now I want only the word "CONTENT" in the MText's text string to be 13.0 high. See the quite simple code below:
Option Explicit
Public Sub SetMTextHeight()
    Dim ent As AcadEntity
    Dim pt As Variant
    Dim mtxt As AcadMText
    ''On Error Resume Next
    ThisDrawing.Utility.GetEntity ent, pt, vbCr & "Select an MText entity:"
    If Not ent Is Nothing And TypeOf ent Is AcadMText Then
        Set mtxt = ent
        UpdateMText mtxt, "CONTENT", 13#
End Sub
Private Sub UpdateMText(mtext As AcadMText, TextToChange As String, textHeight As Double)
    Dim content As String
    Dim i As Integer
    Dim hFactor As Double
    hFactor = textHeight / mtext.Height
    content = mtext.TextString
    i = InStr(1, content, "{\H", vbTextCompare)
    If i = 0 Then
        content = Replace(content, "CONTENT", "{\H" & Format(hFactor, "##0.0") & "x;CONTENT}")
    mtext.TextString = content
    mtext.Update
End Sub
See the result of running the code in the video clip below:
HTH
Norman Yuan
Drive CAD With Code
a.kouchakzadeh
that was awesome
thank you very much sir
