setting layer status for active viewport
I am really having problems with this task. I need to: 1. Check to see if a layer is frozen in the active viewport 2. Create a new viewport ( I have this step completed) 3. Set layer status to the stus of step 1 I thought if I set the ViewportDefault = true in step one. By creating a new viewport my layer status would be the same as my original viewport. One other note is that I am not creating my viewport in the same tab. The Viewport is in the same drawing but not the same tab. Any Ideas.
What do you have so far (code)?? -- Matt W There are 3 kinds of people: Those who can count, and those who can't. "Nate Hunter" wrote in message news:40740462$1_3@newsprd01... > I am really having problems with this task. I need to: > > 1. Check to see if a layer is frozen in the active viewport > 2. Create a new viewport ( I have this step completed) > 3. Set layer status to the stus of step 1 > > I thought if I set the ViewportDefault = true in step one. By creating a > new viewport my layer status would be the same as my original viewport. > > One other note is that I am not creating my viewport in the same tab. The > Viewport is in the same drawing but not the same tab. > > Any Ideas. > >
Dim objPViewport As AcadObject Dim XdataType As Variant Dim XdataValue As Variant Dim I As Integer, PT1 As Variant Dim stemp As String ' Get the Xdata from the Viewport PPort.GetXData "ACAD", XdataType, XdataValue For I = LBound(XdataType) To UBound(XdataType) ' Look for frozen Layers in this viewport If XdataType(I) = 1003 Then ' Set the counter AFTER the position of the Layer frozen layer(s) Counter = I + 1 ' If the layer is already in the frozen layers xdata of this viewport then exit this sub program stemp = stemp & XdataValue(I) & vbCrLf End If Next MsgBox stemp "Matt W" wrote in message news:40746150$1_3@newsprd01... What do you have so far (code)?? -- Matt W There are 3 kinds of people: Those who can count, and those who can't. "Nate Hunter" wrote in message news:40740462$1_3@newsprd01... > I am really having problems with this task. I need to: > > 1. Check to see if a layer is frozen in the active viewport > 2. Create a new viewport ( I have this step completed) > 3. Set layer status to the stus of step 1 > > I thought if I set the ViewportDefault = true in step one. By creating a > new viewport my layer status would be the same as my original viewport. > > One other note is that I am not creating my viewport in the same tab. The > Viewport is in the same drawing but not the same tab. > > Any Ideas. > >
