For professional programmers who know what they are doing, nothing.
"Paul Richardson" wrote in message
news:5166030@discussion.autodesk.com...
what does the # sign do? 🙂 sorry couldn't help it...
gl - Paul
"Jorge Jimenez" wrote in message
news:5165800@discussion.autodesk.com...
I Double# that.
Saludos, Ing. Jorge Jimenez, SICAD S.A., Costa Rica
"Dave F." wrote in message
news:5165702@discussion.autodesk.com...
Joe
Have you been indoctrinated by aliens?
You sure are not the person I remember you used to be.
Now you're rude, arrogant, but even worse...
....your repeatedly wrong.
Over the previous months you've done a fantastic hatchet job on yourself,
destroying your reputation bit by bit, to the point I would not even
consider looking at your book in my local bookshop let alone purchasing it.
It amazes me how you got a puplishing deal
You're a sad twat.
Dave F.
"Joe Sutphin" wrote in message
news:5165054@discussion.autodesk.com...
Ah, you're a quick study, grasshopper! Not quite quick enough for my taste,
but quick nonetheless.
news:5163026@discussion.autodesk.com...
Ah, the art of the written word !
I'm sure you are a master of the trade
This sounds good:
please accept my apology..
This sounds cynical:
Oh please accept my apology...
But you'll get the benefit of the doubt.
news:5162934@discussion.autodesk.com...
Oh please accept my apology ...
news:5162924@discussion.autodesk.com...
That is definitely not good PR
news:5162636@discussion.autodesk.com...
Whatever you say ...
"R. Robert Bell" wrote in message
news:5162466@discussion.autodesk.com...
Jorge, you are correct. The key is to reset the Active(P)Viewport to the
modified (P)Viewport object.
Joe, if you run Jorge's code and then run ViewRes, you will see you are
incorrect.
Sub Test()
Dim myVPort As AcadViewport
Set myVPort = ThisDrawing.ActiveViewport
myVPort.ArcSmoothness = 1000 '<- change here
ThisDrawing.ActiveViewport = myVPort
SendCommand "._ViewRes " '<- note command line
End Sub
R. Robert Bell
news:5161918@discussion.autodesk.com...
Oops, I think I'm wrong about this.
Your code should work but need to set the active viewport again.
For example, this code works
Dim myvport As AcadViewport
Set myvport = ThisDrawing.ActiveViewport
myvport.ArcSmoothness = 3000
ThisDrawing.ActiveViewport = myvport
news:5161896@discussion.autodesk.com...
Tony, I believe the only way to set this
is using the viewres command.
wrote in message news:5160646@discussion.autodesk.com...
I can't get VBA to set the Arc Smoothness preference which is located at:
Tools-->Options-->Display-->Arc Smoothness
My code is below, but it doesn't work. The Arc Smoothness remains at the
default (100) and seems to ignore this code.
Dim acadApp As AcadApplication
Dim ThisDwg As AcadDocument
Set ThisDwg = acadApp.ActiveDocument
ThisDwg.ActiveViewport.ArcSmoothness = 1000
Thanks for your help,
-Tony.
