Setting ArcSmoothness
Message 1 of 25
I can't get VBA to set the Arc Smoothness preference which is located at:
Tools-->Options-->Display-->Arc Smoothness
My code is below, but it doesn't work. The Arc Smoothness remains at the default (100) and seems to ignore this code.
Dim acadApp As AcadApplication
Dim ThisDwg As AcadDocument
Set ThisDwg = acadApp.ActiveDocument
ThisDwg.ActiveViewport.ArcSmoothness = 1000
Thanks for your help,
-Tony.
Replies (24)
Message 2 of 25
The value displayed in the Preferences dialog is the VIEWRES system variable
not the arc smoothness. Try this example to see what I mean.
Joe
Public Sub Test()
MsgBox ThisDrawing.ActiveViewport.ArcSmoothness
ThisDrawing.ActiveViewport.ArcSmoothness = 1234
End Sub
wrote in message news:5160646@discussion.autodesk.com...
-Tony.
Message 3 of 25
Joe,
Then perhaps my question should be, "How do I change the ViewRes system variable using VBA?"
The point is that I want to have the effect that changing "ArcSmoothness" within the Tools-->Options-->Display--> menu.
When I change this value to, say, 1000 in a drawing, I get the effect that I want. But I cannot get this effect using
VBA.
Why would they name something
if it doesn't change the preference item with the exact same name?
-Tony.
Message 4 of 25
VIEWRES is a command not a system variable.
Regards - Nathan
Message 5 of 25
Tony, I believe the only way to set this
is using the viewres command.
Saludos, Ing. Jorge Jimenez, SICAD S.A., Costa Rica
-Tony.
Message 6 of 25
Oops, I think I'm wrong about this.
Your code should work but need to set the active viewport again.
For example, this code works
Dim myvport As AcadViewport
Set myvport = ThisDrawing.ActiveViewport
myvport.ArcSmoothness = 3000
ThisDrawing.ActiveViewport = myvport
"Jorge Jimenez" wrote in message
news:5161896@discussion.autodesk.com...
-Tony.
Message 7 of 25
His code works fine, it's just not changing what he thinks it's changing.
Joe
news:5161918@discussion.autodesk.com...
-Tony.
Message 8 of 25
Jorge, you are correct. The key is to reset the Active(P)Viewport to the
modified (P)Viewport object.
Joe, if you run Jorge's code and then run ViewRes, you will see you are
incorrect.
Sub Test()
Dim myVPort As AcadViewport
Set myVPort = ThisDrawing.ActiveViewport
myVPort.ArcSmoothness = 1000 '<- change here
ThisDrawing.ActiveViewport = myVPort
SendCommand "._ViewRes " '<- note command line
End Sub
R. Robert Bell
-Tony.
Message 9 of 25
Whatever you say ...
"R. Robert Bell" wrote in message
news:5162466@discussion.autodesk.com...
incorrect.
Sub Test()
End Sub
R. Robert Bell
-Tony.
Message 10 of 25
Yes, it's changing what he thinks it should be changing.
"Joe Sutphin" wrote in message
news:5161921@discussion.autodesk.com...
Joe
-Tony.
Message 11 of 25
That is definitely not good PR
news:5162636@discussion.autodesk.com...
incorrect.
Sub Test()
End Sub
R. Robert Bell
-Tony.
Message 12 of 25
Oh please accept my apology ...
news:5162924@discussion.autodesk.com...
incorrect.
Sub Test()
End Sub
R. Robert Bell
-Tony.
Message 13 of 25
Ah, the art of the written word !
I'm sure you are a master of the trade
This sounds good:
please accept my apology..
This sounds cynical:
Oh please accept my apology...
But you'll get the benefit of the doubt.
news:5162934@discussion.autodesk.com...
incorrect.
Sub Test()
End Sub
R. Robert Bell
-Tony.
Message 14 of 25
What did you think his code was changing?
Regards - Nathan
Message 15 of 25
Ah, you're a quick study, grasshopper! Not quite quick enough for my taste,
but quick nonetheless.
news:5163026@discussion.autodesk.com...
This sounds good:
incorrect.
Sub Test()
End Sub
R. Robert Bell
-Tony.
Message 16 of 25
Joe
Have you been indoctrinated by aliens?
You sure are not the person I remember you used to be.
Now you're rude, arrogant, but even worse...
....your repeatedly wrong.
Over the previous months you've done a fantastic hatchet job on yourself,
destroying your reputation bit by bit, to the point I would not even
consider looking at your book in my local bookshop let alone purchasing it.
It amazes me how you got a puplishing deal
You're a sad twat.
Dave F.
news:5165054@discussion.autodesk.com...
This sounds good:
incorrect.
Sub Test()
End Sub
R. Robert Bell
-Tony.
Message 17 of 25
I Double# that.
"Dave F." wrote in message
news:5165702@discussion.autodesk.com...
Joe
You're a sad twat.
Dave F.
This sounds good:
incorrect.
Sub Test()
End Sub
R. Robert Bell
-Tony.
Message 18 of 25
what does the # sign do? 🙂 sorry couldn't help it...
gl - Paul
news:5165800@discussion.autodesk.com...
I Double# that.
Joe
You're a sad twat.
Dave F.
This sounds good:
incorrect.
Sub Test()
End Sub
R. Robert Bell
-Tony.
Message 19 of 25
From the looks of your command of the English language I can see why you did
not!
At least I've not sunk to name calling. Also, it's amazing how the last week
or so has turned into months. Hmm, I must not be able to count either.
Joe
Joe
You're a sad twat.
Dave F.
This sounds good:
incorrect.
Sub Test()
End Sub
R. Robert Bell
-Tony.
Message 20 of 25
For professional programmers who know what they are doing, nothing.
"Paul Richardson" wrote in message
news:5166030@discussion.autodesk.com...
gl - Paul
I Double# that.
Joe
You're a sad twat.
Dave F.
This sounds good:
incorrect.
Sub Test()
End Sub
R. Robert Bell
-Tony.
