settext runs slowly
settext runs slowly
mhardine
settext runs slowly
mhardine
I'm using the following to populate a table. Not included here is a step where the record set is counted to determine the number of rows required. The table is then created and the last step is to populate the cells with data.
    'building a set of records from the connection string based on SQL statement
    Set myrs = myConnection.Execute(myss)
varRow = 2
Do Until myrs.EOF
                varSheetNumber = myrs("Sheet_Num")
                varDescription = myrs("Item_Description")
                varRoom = myrs("Room")
                varFloor = myrs("Floor")
                varTitle = myrs("Drawing_Title")
table.SetText varRow, 0, varSheetNumber
table.SetText varRow, 1, varDescription
table.SetText varRow, 2, varRoom
table.SetText varRow, 3, varFloor
table.SetText varRow, 4, varTitle
varRow = varRow + 1
  myrs.MoveNext
  Loop
    'closing dbase connections
    dbclose
    Set myrs = Nothing
    Set myss = Nothing
End If
Now, if i comment out the Table.Settext lines the routine runs in a fraction of a second, even when the recordset contains hundreds of records.
Once I run those lines though, it can take upwards of 10 minutes to populate the table if there are a couple hundred records.
Anyone know why, or have a better way of doing this?
Thanks in advance
mhardine
I timed it more carefully and it took about 1.6 seconds per row. A 220 row table took about 6 minutes to populate. Lots of noise from my laptop as well, and some general freezing up which subsided once the routine competed
andrewpuller3811
Part of a sub I use to insert a table. I have had up to about 150 rows and it occurs instantly (about 1-2 sec). I think the regeneratetablesuppressed, recompute tableblock, titlesuppressed and headersuppressed are what you need to speed it up.
With acTable
        .RegenerateTableSuppressed = True
        .RecomputeTableBlock False
        .TitleSuppressed = False
        .HeaderSuppressed = False
        'call to function to check if table style exists.
        If AWPJ_TableStyleExists(strTableStyleName) Then
            'tablestyle good, so set it to use
            .StyleName = strTableStyleName
        'else 'style doesn't exist so leave set to default
        End If
        .SetTextStyle AcRowType.acTitleRow, strTextStylename
        .SetTextStyle AcRowType.acHeaderRow, strTextStylename
        .SetTextStyle AcRowType.acDataRow, strTextStylename
        .SetColumnWidth 0, intCol1
        .SetColumnWidth 1, intCol2
        .SetColumnWidth 2, intCol3
        .SetColumnWidth 3, intCol4
        .SetColumnWidth 4, intCol5
        .SetColumnWidth 5, intCol6
        ' Title
        .SetCellTextHeight i, j, 3#
        .SetCellAlignment i, j, acMiddleLeft
        .SetRowHeight i, 8#
        .SetCellBackgroundColorNone i, j, True
        col.ColorMethod = AutoCAD.acColorMethodByBlock
        .SetCellContentColor i, j, col
        .SetCellType i, j, acTextCell
        strTitleText = "{\f" & strTextStylename & "|b1|i0|c0|p34;\C0;OWNERS DETAILS}"
        .SetText i, j, strTitleText
        col.SetRGB 255, 0, 0
        For j = 0 To .Columns - 1
            .SetCellGridColor i, j, 4, col
        Next j
        ' header
        i = i + 1
        .SetCellGridColor i, 0, 8, col
        .SetCellGridColor i, .Columns - 1, 2, col
        col.SetRGB 255, 0, 255
            .SetCellTextHeight i, j, 2.5
            .SetRowHeight i, 6.5
            .SetText i, j, strHeaderText(j)
        Next
        ' fill data cells - Row 2 -> last row
        ' interate through strOwnersTable() to fill table
        For i = 0 To .Rows - 3
            .SetRowHeight i + 2, 6.5
            For j = 0 To TableColumns - 1
                .SetCellStyle i + 2, j, "Data"
                .SetCellBackgroundColorNone i + 2, j, True
                .SetCellContentColor i + 2, j, col
                .SetCellTextHeight i + 2, j, 2#
                .SetText i + 2, j, strOwnersTable(j + 1, i + 1)
             Next j
        Next i
        .RegenerateTableSuppressed = False
        .RecomputeTableBlock True
        .Update
    End With    'end With acTable
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
mhardine
That was EXACTLY what the doctor ordered! Thanks a bunch. 720 pages of drawings listed  in 15 seconds!
Thank you very much.
D
mhardine
One more thing, you seem do be doing the same thing as I- pulling stuff from a table in a database, but your method makes me think of mine as somewhat barbaric! I'm relying on first creating a recordset to count the number of rows needed, then creating the table object with the appropriate number of colums and rows, then populating the title and first row, and finally reconnecting to the database and pulling out the recordset to then populate the cells.
Would you be willing to share a bit more of that sub? I'd love to learn a more elegant approach.
Cheers,
D
