Set Page Configuration as Current
dbrblg
dbrblg
How do you set a page configuration as current in VBA?
I have a few page setups and I'm finding that invariably these are the wrong ones for when the user goes to plot so to save time, I'd like to change the current page setup so that the user can just hit plot and the configuration is mostly correct and they can make the odd change to suit the current print rather than try to configure everything....
BestFriendCZ
what about this
Sub Test()
    Dim k As AcadPlotConfiguration
    Set k = ThisDrawing.PlotConfigurations.item("SetupName")
    Dim item As AcadLayout
    For Each item In ThisDrawing.Layouts
    If item.ModelType = False Then
        item.CopyFrom k
    Next item
End Sub
Ed__Jobe
The answer is the same as what I gave you previously. Use the Layout's CopyFrom method.
Ed
How to post your code.
