set new UCS in VBA
set new UCS in VBA
set new UCS in VBA
Who can help me????
I want to change the USC in VBA befor I insert a block.
In LISP is used the following code:
(command "UCS" "X" -57)(command "UCS" "Z" 45)
The result was a ucs that is in the SoudEast posision.
I tryed is to do this in VBA by using de following code:
Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPoint,
yAxisPoint, "UCS1")
see also below
unfortunately I get a error that the points are not perpendicular.
For the xAxisPoint and the yAxispoint I copyed the coordinates from the
UCSXDIR and the UCSYDIR
What am I dowing wrong hire??
Ore is there a other way to solve my problem?
Robert
step 1 is going Oke
step 2 is going wrong
Sub Excample_ActiveUCS()
Dim viewportObj As AcadViewport
Dim ucsObj As AcadUCS
Dim origin(0 To 2) As Double
Dim xAxisPoint(0 To 2) As Double
Dim yAxisPoint(0 To 2) As Double
Set viewportObj = ThisDrawing.ActiveViewport
origin(0) = 0
origin(1) = 0
origin(2) = 0
'STEP 1 rotate UCS on X by -57 degrees
xAxisPoint(0) = 1
xAxisPoint(1) = 0
xAxisPoint(2) = 0
yAxisPoint(0) = 0
yAxisPoint(1) = 0.545
yAxisPoint(2) = -0.839
yAxisPoint, "UCS1")
ThisDrawing.ActiveUCS = ucsObj
'STEP 2 rotate UCS on X by -57 degrees and Z by 45 degrees in one time
xAxisPoint(0) = 0.707
xAxisPoint(1) = 0.385
xAxisPoint(2) = -0.593
yAxisPoint(0) = -0.707
yAxisPoint(1) = 0.385
yAxisPoint(2) = -0.593
yAxisPoint, "UCS1")
End Sub
nothing your doing wrong, known
problem.
Work around is to set your new UCS
origin at 0,0 with the new vectors. Then
change the origin property of the new
UCS to where you want it.
gl - Paul
"Robert K" wrote in message
news:5066335@discussion.autodesk.com...
Who can help me????
yAxisPoint, "UCS1")
see also below
Robert
step 1 is going Oke
origin(0) = 0
origin(1) = 0
origin(2) = 0
xAxisPoint(0) = 1
xAxisPoint(1) = 0
xAxisPoint(2) = 0
yAxisPoint(0) = 0
yAxisPoint, "UCS1")
yAxisPoint, "UCS1")
End Sub
