ignorant question...
See I am being honest from the start... I know
precious little about VBA and just a bit more about LISP.  I have books
available to me, but I can not locate what I am looking for in
them.
I have a .dvb file, which I want to activate
from a .pgp file short cut at the command line.
How can I do this?  Can I do
this?
search 'vbarun', 'vbastmt'
do you need this to be in your
pgp? you can create an ascii
file called 'acaddoc.lsp' and place
it in your search path. In this txt
file add lisp programs to call
your
vba
size=2>macros.
sample acaddoc.lsp
(defun c:commandName()
  (vl-vbarun
"x:/path/project.dvb!module.sub/function")
(defun c:commandName2()
Add others as necessary. 'acaddoc.lsp' will
load
automatically as long as it's in your search
path.
gl - Paul
them.
this?
Thanks for your response!
Well, no.  It does not have to be in my .pgp
now that I think about it...
If I can list three different commands in the
acaddoc.lsp to activate the same single .dvb, then I will be okay.
Is that the example you sent me?  It looks
like it...
TIA
your
vba
size=2>macros.
sample acaddoc.lsp
  (vl-vbarun
load
path.
gl - Paul
them.
activate from a .pgp file short cut at the command line.
this?
commands in the acaddoc.lsp to activate the same single .dvb, then >I will be
okay
yes you can.
gl - Paul
okay.
like it...
TIA
place
txt
your
vba
size=2>macros.
sample acaddoc.lsp
  (vl-vbarun
load
path.
gl - Paul
know precious little about VBA and just a bit more about LISP.  I
have books available to me, but I can not locate what I am looking for in
them.
this?
