Set error
Set error
Set error
He there
I would like to set TEST to a sub within a module
Dim test(0 To 4) As String
Set test(0) = profielen.profiel4545Z((startsectie + sectionlength),
((profiel13 / 2) + x + 67.5), 133, -(txtframeheight - 190))
the module is called profielen and the sub is called profiel4545Z but when I
try to run It I get the error
"compile error expected function or variable" It is very important that I
get this right.
THX
Wiebe
Set is not used with intrinsic types, it is only
used with Object types. Just remove the 'set'
from your assignment statement and it should work.
AcadXTabs: MDI Document Tabs for AutoCAD
http://www.acadxtabs.com
"Gizmo" wrote in message news:D4DD3E3817FD1AD4D532913475DABF09@in.WebX.maYIadrTaRb...
> He there
> get this right.
> THX
> Wiebe
