Set ACADApp = GetObject(, "AutoCAD.Application")
burodemunnynck
Message 1 of 12
burodemunnynck
Hi all,
just downloaded and installed the new autocad2013 64bit. Glad to see there is indeed a vba-enabler after all!
I have a routine in vba, written in earlier versions of autocad. And it won't work anymore: this is where things go wrong:
Also in others programs certain things don't work: creating layers, rotating text, inserting blocks etc
Is there anyone who can help me fixing this, won't be difficult for vba gurus i suppose.
Thanks!
Gr
Frank
Replies (11)
Message 2 of 12
Alfred.NESWADBA
if you are in VBA for AutoCAD (not within Excel or some external prog) you should use:
Dim acadApp as AcadApplication
Set acadApp = ThisDrawing.Application
With your statement (using GetObject...) the operating system scans for the first AutoCAD-process and returns it's ActiveX-connection-object. If you have started more than one AutoCAD you may get the wrong process returned.
Verify in your references that you have set the AutoCAD-specific references to the current (19.0) lib's.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 12
burodemunnynck
Hi Alfred,
thanks for your time spending on this issue!
i still get the same error: run time error '13' - type mismatch
Gr
Frank
Message 4 of 12
Alfred.NESWADBA
have you checked the references? Are they all set for AutoCAD 2013 (then saved the DVB and restarted AutoCAD?)
- alfred -
Alfred NESWADBA
Message 5 of 12
burodemunnynck
which references should be checked? I
These are checked now:
autocad 2013 type library
ole automation
visual basic for applications
In a few vba programs the reference is protected by a password. I can't remember me setting there a password. There is a password however on each vba program.
Gr
Frank
Message 6 of 12
Alfred.NESWADBA
I created now a little test, creating a new layer and a line on this layer.
Start your AutoCAD, load and try my DVB ..... does that work on your pc?
- alfred -
Alfred NESWADBA
Message 7 of 12
burodemunnynck
things now go pretty well with these references checked. By checking the autocad2013 reference, it seems that is no longer possible to run the routine in autocad2012, and autocad doesn't let you check both 2012 and 2013 references.
G
F
Message 8 of 12
burodemunnynck
Alfred,
this works!
But you didn't use this, right?
Dim acadApp As AcadApplication
G
F
Message 9 of 12
Alfred.NESWADBA
if I add these lines:
Private WithEvents acadApp As AcadApplication
Public Sub initAppEvents()
End Sub
Private Sub acadApp_SysVarChanged(ByVal SysvarName As String, ByVal newVal As Variant)
   Call MsgBox("Sysvar changed: " & SysvarName)
End Sub
I have no problem to run  initAppEvents  and I also get then the events fired.
 - alfred -
Alfred NESWADBA
Message 10 of 12
burodemunnynck
Hi Alfred,
everything is working now, thanks a lot!
Gr
F
Message 11 of 12
Works on x32 but don't on x64 Error on "
Application.Update
Sub StartWorkWithDB()
Dim sPath As String
On Error GoTo NoDbOpened
sPath = GetDBName
If OpenMDB(sPath) = False Then GoTo NoDbOpened
  ThisDrawing.SetVariable "sdi", 1
  ThisDrawing.SetVariable "cmdecho", 0
  frmDBUtils.Show
    frmDBUtils.lblInfo.Caption = "Áàçà äàíèõ ï³äêëþ÷åíà"
    frmDBUtils.cbGetCode.Visible = False
    frmDBUtils.cbRegister.Visible = False
Revision
frmDBUtils.LoadAgroType
frmDBUtils.LoadAgro (frmDBUtils.cbxAgroType.Value)
frmDBUtils.cbSelectAgro.Enabled = True
frmDBUtils.cbShowAgro.Enabled = True
frmDBUtils.cbAudit.Enabled = True
 If verifylayer("$Dil") = False Then
   ThisDrawing.Layers.Add ("$Dil")
 End If
 If verifylayer("$laypo") = False Then
   ThisDrawing.Layers.Add ("$laypo")
 End If
 If verifylayer("$kvartal") = False Then
   ThisDrawing.Layers.Add ("$kvartal")
 End If
'Application.Update 'Autocad 2008 - works on x32
'--------tmp
AcadApplication.Update ' dont work
Exit Sub
NoDbOpened:
End Sub
Message 12 of 12
If i dell "Application.Update" I can press the button on my form from 10 click mouse or 1000. I don't know why?
