SelectionSet
SelectionSet
SelectionSet
Hi
Have experienced this problem on 3 or 4 machines. After this line
ssetFrames.Select acSelectionSetAll, , , groupCode, dataCode
where groupCode(0) = 0 and dataCode(0) "INSERT", the selectionset returns with the correct item count. However there are 0 items in the selectionset. Trying to access the items result in an error message "Method ITEM in Acadselectionset failed". After this I can select objects in AutoCAD and continue to work, but the properties palette stops working.
Only way to get this right is re-installing AutoCAD Mechanical.
Anyone else experienced similar?
Can you clarify whether the properties palette
works after closing and restarting AutoCAD or
do you actually have to reinstall it?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:5054748@discussion.autodesk.com...
Hi
Sorry
Properties works on re-start
