Delete a block in a drawing
Hello !
First Happy new year
Second Thanks for the answers on other topics
Third my today's problem
If I know the coordinate of the insertion point of a block How can I delete it ?
Regards
selectionset w/ 0 and 10 and "insert" and the blockref.insertionpoint
fxcastil
Group codes by number
Group code Description
0 Text string indicating the entity type (fixed)
10 Primary point; this is the start point of a line or text entity, center of a circle, and so on
DXF: X value of the primary point (followed by Y and Z value codes 20 and 30)
20, 30 DXF™: Y and Z values of the primary point
To further exoand on Bryco 's response here are the dxf group codes for a creating a selection set with a block Reference (Insert) tyoe and the insertion point.
Fred Castillo
I am sorry but I undestood nothing.
Perhaps my first message wasn't clear enough.
So I repeat my question :
With a vba code, how can I delete a block used in a drawing if i know the coordinates of this block in my drawing ?
You use a selection set (Do a search) to find an "Insert" which is the dxf reference name for a block reference (Which is the item you want, not a block). The search can use more than one criteria, so "10" is the dxf number for the insertionpoint
I am not sure to understand every thing without a sample code.
I will try to find something in the VBA acad help file with informations you gave me.
