SelectionSet last / previous
joh.richard
joh.richard
Hi
I need your help with selection
I want to be able to select object and after start the vba, if nothings was selecting pass to the other command
I try this sset.Select acSelectionSetLast, but it only use the last object (1 entitie)
Dim sset	As AcadSelectionSet
'If objects are already selected process them
	Set sset = ThisDrawing.SelectionSets.Add(Now)
	Call ChangeLayer (sset)		'Change the layer already selected entities
'The user selects the objects on the screen
	Set sset = ThisDrawing.SelectionSets.Add("SS1")
        sset.SelectOnScreen      	'user select object on screen
	Call Changelayer (sset)		'Change layer selected entities
And I try sset.Select acSelectionSetPrevious
But if the user didn't select object, the previous object select in this vba is process
I try
Set sset = ThisDrawing.SelectionSets.Add(Now) .delete  or sset.Clear
I don't know how to "clear" the memories
So any suggestion will be welcome. Thanks,
joh.richard
ok, after workaround I got this
Dim PfSS As AcadSelectionSet
    Dim ssetObj As AcadSelectionSet
    Set PfSS = ThisDrawing.PickfirstSelectionSet
    On Error Resume Next
    ssetObj.Delete
    On Error GoTo 0
    If PfSS.Count > 0 Then
        Set ssetObj = PfSS
        Call ChangeLayer(ssetObj)
        ssetObj.Delete
    ThisDrawing.SelectionSets.item("ss2").Delete
    ssetObj2.Erase
    On Error GoTo 0
    Set ssetObj2 = ThisDrawing.SelectionSets.Add("ss2")
    ssetObj2.SelectOnScreen
        Call ChangeLayer(ssetObj2)
    ssetObj2.Clear
End Sub
 But still have problem, If I select object and start the sub, the part of SelectOnScreen don't work!?!?!
Any idea?
joh.richard
    Dim ssetObj2 As AcadSelectionSet
    'PickfirstSelectionSet = Des objets qui sont déjà sélectionnés à l'écran
    ssetObj.Delete
    ssetObj2.Delete
    ThisDrawing.SelectionSets.item("ss1").Delete
    On Error GoTo 0
    'Validation si des objets ont été sélectionnés
        Set ssetObj = PfSS
        Call Lay_PropExstDemo2(ssetObj, sObjLayerExtens)
        ssetObj.Delete
        'clear pickfirst selection ; Je n'ai pas trouvé d'autre moyen pour enlever la selection existante à l'écran que de refaire une selection d'objet
        Set ssetObj = ThisDrawing.SelectionSets.Add("ss1")
        ssetObj.SelectOnScreen
        ssetObj.Clear
        ThisDrawing.Regen acActiveViewport
    'Demander à l'utilisateur de sélectionner des objets
    Call Lay_PropExstDemo2(ssetObj2, sObjLayerExtens)
    ssetObj2.Clear
