Message 1 of 1
ACADM Parts List not updating with new PartRef
I could use a second opinion, or guiding light. I'm trying to create a PartRef and insert it into any existing block. For whatever reason, I can do this manually with AMPARTREF and "BLOCK" option. When I do it via VBA, the Parts List does not update. If I insert ouside of block, maybe free or attached, it updates. If I insert it inside, then close and re-open the drawing it will update if I insert the same block I just attached a PartRef to. If I explode the block it will count that one in the Parts List.
As a secondary problem, inserting outside but attached, I cannot seem to get the same 'pick' to fill the object for that attachment. I can't grasp the difference between 'Object and IMcadObject.
Thanks for any insight in advance!
Public Sub PartRefInBlockRef()
'Get symbol Manager
Dim oSymBBMgr As McadSymbolBBMgr
Set oSymBBMgr = ThisDrawing.Application.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr")
'Set oSymBBMgr = Application.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr")
'Get BOM Manager
Dim oBOMMgr As McadBOMMgr
Set oBOMMgr = oSymBBMgr.bommgr
'Get standard manager
Dim stdMgr As McadStandardMgr
Set stdMgr = oSymBBMgr.StandardMgr
'Get current standard
Dim currentStd As McadStandard
Set currentStd = stdMgr.CurrentStandard
'Get BOM Standard
Dim BOMStd As McadBOMStandard
Set BOMStd = currentStd.BOMStandard
'Get all BOM visible columns from BOM standard
Dim BOMcol As McadColumnDefinitions
Set BOMcol = BOMStd.Columns
'Select Block to insert PartRef in, and origin point
'Dim acmApp As AcadmApplication
'Set acmApp = ThisDrawing.Application.GetInterfaceObject("AcadmAuto.AcadmApplication")
'Dim uti As McadUtility
'Set uti = acmApp.ActiveDocument.Utility
Dim oAcApp As AcadApplication
Set oAcApp = GetObject(, "AutoCAD.Application")
Dim oAcUtil As AcadUtility
Set oAcUtil = oAcApp.ActiveDocument.Utility
Dim pt As Variant
Dim oBlockDef As AcadBlock
Dim oBlockRef As AcadBlockReference
Dim oObject As Object
Dim object As IMcadObject
Dim txtBname As String
oAcUtil.GetEntity oObject, pt
If TypeOf oObject Is AcadBlockReference Then
Set oBlockRef = oObject
Set oBlockDef = ThisDrawing.Blocks(oBlockRef.Name)
'Set object = ???? 'can not use same pick to attach to block
txtBname = oBlockDef.Name
pt = oAcUtil.TranslateCoordinates(oBlockDef.Origin, acUCS, acWorld, False)
Else
Err.Raise 1, "PartRefToBlockRef", "Selected entity was NOT a block"
Dim oPartRef As McadPartReference
'insert PartRef attached to block at block origin
'Set oPartRef = ThisDrawing.ModelSpace.AddCustomObject("AcmPartRef")
'oPartref.AttachGeometry object, pt 'can not use same pick to attach to block
'insert PartRef in block at block origin
Set oPartRef = oBlockDef.AddCustomObject("AcmPartRef")
oPartRef.Origin = pt
Dim pdata(0 To 5, 0 To 1) As String
pdata(0, 0) = "DESCR": pdata(0, 1) = "My Description"
pdata(1, 0) = "STANDARD": pdata(1, 1) = "My Standard"
pdata(2, 0) = "MATERIAL": pdata(2, 1) = "My Material"
pdata(3, 0) = "NOTE": pdata(3, 1) = "My Note"
pdata(4, 0) = "VENDOR": pdata(4, 1) = "My Vendor"
pdata(5, 0) = "NAME": pdata(5, 1) = txtBname
oBOMMgr.SetPartData oPartRef, pdata
End Sub
