selection to the DIV command
HI Everyone,
I need to divide a polyline in a number of pieces (using DIV) and put
a block on the divide points.
Using VB ThisDrawing.SendCommand ("DIV" & vbCr & "selection " & vbCr ) not
works.
My question is " how can I pass a selection to the DIV command prompt."
using VB.
Any idea will be very helpfull
Edvin
thisdrawing.sendcommand("DIV" & vbcr & "LAST "& vbcr)>For the last created
entity
thisdrawing.sendcommand("DIV" & vbcr & "PREVIOUS "& vbcr)>For previous
selectionset
all >all entities.
I can make some addition to your question."how can i pass a selectionset to
lisp applications>if its possible"
"sss" wrote in message
news:A493D2E87D8C47C134DF4B0774009D22@in.WebX.maYIadrTaRb...
> HI Everyone,
not
> works.
> using VB.
> Thanks
> Edvin
Hmmmm, I think that DIVIDE command does not accept multiple objects.
One way of passing a selection to DIVIDE using VBA is to do the following:
1. Have the user select an object using VBA,
2. retrieve the handle string of that object and store it in a variable,
3. pass that handle string alongwith the sendcommand as :
(command "divide" (handent <<handlestring>>)
"b" <<no. of segments>> "") & vbcr
sss wrote:
HI Everyone,
" & vbCr ) not
works.
prompt."
using VB.
Edvin
