increase by one or two
Message 1 of 26
lets say I have about 10 finish floor elevations, all different i.e.: FF =
54.5 (just text) and I needed to go back and raise the whole site by one
foot (add 1 to the text) i.e. FF = 55.5 is there a way to do that?
Replies (25)
Message 2 of 26
You could use find and replace but I am sure that's what you want.
"Jon Baker" wrote in message
news:315131483E5B4F5421A793B4406A1F96@in.WebX.maYIadrTaRb...
Message 3 of 26
Here's a VBA routine that will do that. You may need to tweak the settings
to get the final format you want.
To set it up: In AutoCAD hit 'ALT-F11' to enter the VBA editor. Select
'Insert>Module'. Copy and paste this code into the module. Switch back to
AutoCAD. Hit 'ALT-F8'. Highlight the line with 'ad_Add10'. Click 'Run'.
'-- Begin Routine --
Sub ad_Add10()
Dim TextObj As AcadObject
Dim basePnt As Variant
Dim objSelected As Integer
objSelected = 1
Do While objSelected = 1
On Error GoTo exitsub
ThisDrawing.Utility.GetEntity TextObj, basePnt, "Select Text to
Update>> "
If TextObj.ObjectName = "AcDbText" Or TextObj.ObjectName =
"AcDbMText" Then
TextObj.TextString = _
ThisDrawing.Utility.RealToString(Val(TextObj.TextString) + 10#,
acDecimal, 1)
TextObj.TextString = "FF=" & TextObj.TextString
TextObj.TextString = TextObj.TextString & "'"
TextObj.Update
Loop
exitsub:
End Sub
'-- End Routine --
-- Walter -- http://www.ActiveDwg.com
Message 4 of 26
Oops, change the '10#' to '1#'.
Message 5 of 26
Dear Walter,
Along these lines, is anything available to sequence the alphabet? Say I
array grid bubbles of "A" and want to change subsequent "A's" to "B" "C"
"D", etc.... I don't necessarily want a "grid" lisp routine (although
that's something I need also) but more importantly I need the above
solution. I have an integer routine but I am no code writer so I don't know
how to change it up to accept letters.
Thanks for any suggestions!..............................Pat
Walter wrote in message ...
|Sub ad_Add10()
| objSelected = 1
|Update>> "
|"AcDbMText" Then
|acDecimal, 1)
| End If
| TextObj.Update
| Loop
|exitsub:
|End Sub
|'-- End Routine --
Message 6 of 26
Pat,
Here's one way to do it. I know there's an easier way, but give this a try
and tweak it as needed.
'--Begin Routine--
Sub ad_Add1Alpha()
objSelected = 1
Update>> "
"AcDbMText" Then
Select Case TextObj.TextString
Case "A"
TextObj.TextString = "B"
Case "B"
TextObj.TextString = "C"
Case "C"
TextObj.TextString = "D"
Case "D"
TextObj.TextString = "E"
Case "E"
TextObj.TextString = "F"
Case "F"
TextObj.TextString = "G"
Case "G"
TextObj.TextString = "H"
Case "H"
TextObj.TextString = "I"
Case "I"
TextObj.TextString = "J"
Case "J"
TextObj.TextString = "K"
Case "K"
TextObj.TextString = "L"
Case "L"
TextObj.TextString = "M"
Case "M"
TextObj.TextString = "N"
Case "N"
TextObj.TextString = "O"
Case "O"
TextObj.TextString = "P"
Case "P"
TextObj.TextString = "Q"
Case "Q"
TextObj.TextString = "R"
Case "R"
TextObj.TextString = "S"
Case "S"
TextObj.TextString = "T"
Case "T"
TextObj.TextString = "U"
Case "U"
TextObj.TextString = "V"
Case "V"
TextObj.TextString = "W"
Case "W"
TextObj.TextString = "X"
Case "X"
TextObj.TextString = "Y"
Case "Y"
TextObj.TextString = "Z"
Case "Z"
TextObj.TextString = "A"
End Select
TextObj.Update
Loop
exitsub:
End Sub
'--End Routine--
Message 7 of 26
walter, are you GOD??
Message 8 of 26
Of course not (and you better duck, God WILL get you for saying that)...
Just trying to put the available tools to their best use...
Message 9 of 26
hey you may not THE God, but one of the liittler ones sounds good...
Message 10 of 26
If you will consider third party apps, check out this product:
http://www.4d-technologies.com/text_specialist
The Text Counter (TX_TC) command will allow self-incrementing text and
self-incrementing block attributes to be created.
The Text Processor command will allow selected text to be incremented,
decremented, or processed in various ways.
e-mail me if you have any questions.
Regards
Rakesh
Rakesh Rao
Four Dimension Technologies, Singapore-India
Advanced AutoCAD customization for the Engineering/Mapping/GIS/AEC
Work smart NOT hard - Get your GeoTools @ www.4d-technologies.com/geotools
Message 11 of 26
Dearest Walter,
I'm not a programmer so I'm afraid I'm not sure how to utilize this utility.
Is this an autolisp routine or Visual Basic? I was looking for the "defun
c:xx" line so I don't know how to execute this. A2ki said it loaded
successfully but I don't know what to type at the command prompt.
Will you please walk me one step further?
Your dummy,
Pat
|Pat,
|'--Begin Routine--
|Sub ad_Add1Alpha()
| objSelected = 1
|Update>> "
|"AcDbMText" Then
| Case "A"
| Case "B"
| Case "C"
| Case "D"
| Case "E"
| Case "F"
| Case "G"
| Case "H"
| Case "I"
| Case "J"
| Case "K"
| Case "L"
| Case "M"
| Case "N"
| Case "O"
| Case "P"
| Case "Q"
| Case "R"
| Case "S"
| Case "T"
| Case "U"
| Case "V"
| Case "W"
| Case "X"
| Case "Y"
| Case "Z"
| End Select
| End If
| TextObj.Update
| Loop
|exitsub:
|End Sub
|'--End Routine--
Message 12 of 26
Pat,
It's VBA(Visual Basic for Applications).
'Insert>Module'. Copy and paste this code (between '--Begin Routine--' and
'--End Routine--') into the module. Switch back to AutoCAD. Hit 'ALT-F8'.
Highlight the line with 'ad_Add1Alpha'. Click 'Run'.
'--Begin Routine--
Sub ad_Add1Alpha()
objSelected = 1
Update>> "
"AcDbMText" Then
Case "A"
Case "B"
Case "C"
Case "D"
Case "E"
Case "F"
Case "G"
Case "H"
Case "I"
Case "J"
Case "K"
Case "L"
Case "M"
Case "N"
Case "O"
Case "P"
Case "Q"
Case "R"
Case "S"
Case "T"
Case "U"
Case "V"
Case "W"
Case "X"
Case "Y"
Case "Z"
End Select
TextObj.Update
Loop
exitsub:
End Sub
'--End Routine--
-- Walter -- http://www.ActiveDwg.com --
Message 13 of 26
Walter, thanks so much for the VB lesson! BUT there is a syntax error (see
the isolated text below beginning with |Update>>"). It shows up in red in
VB. Can you determine the problem?
Warmest regards..................................Pat
|Pat,
|'--Begin Routine--
|Sub ad_Add1Alpha()
| objSelected = 1
|Update>> "
|"AcDbMText" Then
| Case "A"
| Case "B"
| Case "C"
| Case "D"
| Case "E"
| Case "F"
| Case "G"
| Case "H"
| Case "I"
| Case "J"
| Case "K"
| Case "L"
| Case "M"
| Case "N"
| Case "O"
| Case "P"
| Case "Q"
| Case "R"
| Case "S"
| Case "T"
| Case "U"
| Case "V"
| Case "W"
| Case "X"
| Case "Y"
| Case "Z"
| End Select
| End If
| TextObj.Update
| Loop
|exitsub:
|End Sub
|'--End Routine--
Message 14 of 26
Pat,
Victim of line wrap.
The:
Update>> "
should be on the same line as:
to read:
TextObj, basePnt, "Select Text to Update>> "
Also:
"AcDbMText" Then
to read:
Or TextObj.ObjectName = "AcDbMText" Then
Message 15 of 26
I was looking through here and came across this thread. I am studying VB at
school to utilize it in AutoCAD so I thought I'd give it a try. I got the same
message as you. Here's the fix:
Put your curser at the left of the red line that is out of alignment (not
indented) and backspace it until it goes up to the previous line with one space
after the last word in that line. If the red goes away you did it correctly.
VB looks at each line as a command. Because of the word wrap in the email,
part of that line was dropped down to the next line. Hope this helps. There
are alot of other cool programs on the activedwg website also.
Tim
> |Pat,
> |'--Begin Routine--
> |Sub ad_Add1Alpha()
> | objSelected = 1
> |Update>> "
> |"AcDbMText" Then
> | Case "A"
> | Case "B"
> | Case "C"
> | Case "D"
> | Case "E"
> | Case "F"
> | Case "G"
> | Case "H"
> | Case "I"
> | Case "J"
> | Case "K"
> | Case "L"
> | Case "M"
> | Case "N"
> | Case "O"
> | Case "P"
> | Case "Q"
> | Case "R"
> | Case "S"
> | Case "T"
> | Case "U"
> | Case "V"
> | Case "W"
> | Case "X"
> | Case "Y"
> | Case "Z"
> | End Select
> | End If
> | TextObj.Update
> | Loop
> |exitsub:
> |End Sub
> |'--End Routine--
Message 16 of 26
This is NEAT!! Thanks, both of you. I will look into taking a VB course.
Our company bought a suite of 100 courses at our local college, mostly
on-line. VB is one (albeit it's an advanced but I will try to get a basic
course into the lineup). I appreciate your lesson and help very much.
Thanks Walter!!
Sincerely..............................Pat!
Pat Schultz wrote in message
<866EC9FA6A9BAA5C9FBEBB37734333AC@in.WebX.maYIadrTaRb>...
||Pat,
||'--Begin Routine--
||Sub ad_Add1Alpha()
|| objSelected = 1
||Update>> "
||"AcDbMText" Then
|| Case "A"
|| Case "B"
|| Case "C"
|| Case "D"
|| Case "E"
|| Case "F"
|| Case "G"
|| Case "H"
|| Case "I"
|| Case "J"
|| Case "K"
|| Case "L"
|| Case "M"
|| Case "N"
|| Case "O"
|| Case "P"
|| Case "Q"
|| Case "R"
|| Case "S"
|| Case "T"
|| Case "U"
|| Case "V"
|| Case "W"
|| Case "X"
|| Case "Y"
|| Case "Z"
|| End Select
|| End If
|| TextObj.Update
|| Loop
||exitsub:
||End Sub
||'--End Routine--
Message 17 of 26
' Why not use something like the following
' (apologies, have not read entire thread)
' Other code
' Assuming you wish to maintain case ...
Dim AscCode as Integer
AscCode = Asc(TextObj.TextString)
Select Case AsciiCode
Case 97 to 121, 65 to 89
' a - y, A - Y
TextObj.TextString = Chr(AsciiCode + 1)
Case 122, 90
' z, Z
TextObj.TextString = Chr(AsciiCode - 25)
Case else
' not an alpha character, need to
' write code for this scenario
end select
' Other code
' Would certainly reduce
' the amount of code
' sorry I butted in
"Walter" wrote in message
news:CDFAF8DA1049F526EFAAF2E73A6A6723@in.WebX.maYIadrTaRb...
> Pat,
> '--Begin Routine--
> Sub ad_Add1Alpha()
> objSelected = 1
> Update>> "
> "AcDbMText" Then
> Case "A"
> Case "B"
> Case "Z"
> End Select
> End If
> TextObj.Update
> Loop
> exitsub:
> End Sub
> '--End Routine--
Message 18 of 26
Your welcome.
And look at Michael's code. He shows you the 'easier way' I couldn't put my
finger on Friday...
Message 19 of 26
Yep. I knew there was an easier way...
Thanks for the follow-up.
Message 20 of 26
Michael, Thanks, you're not a budinski ! ! However, I cannot run your
routine. I snagged our resident VB guy to try to finish out the routine but
he doesn't know AutoCAD objects and was unable to help me. Could you please
add the prefixes and suffixes so all I have to do is cut & paste and F11 &
F8? Your help is most welcome!
Much appreciated..............................Pat
Michael Puckett wrote in message
<16716218E0562E7F8CC0A73BD4EFA83F@in.WebX.maYIadrTaRb>...
| ' Other code
| ' a - y, A - Y
| Case 122, 90
| ' z, Z
| Case else
| end select
| ' Other code
|' sorry I butted in
|> Pat,
try
|> '--Begin Routine--
|> Sub ad_Add1Alpha()
|> objSelected = 1
|> Update>> "
|> "AcDbMText" Then
|> Case "A"
|> Case "B"
|> Case "Z"
|> End Select
|> End If
|> TextObj.Update
|> Loop
|> exitsub:
|> End Sub
|> '--End Routine--
